Old 09-03-2013, 05:46 PM   #451
Originally Posted by fq06 View Post
Yep.
Easy math. A 1000 mah pack is 1a.
C is a multiplier.
So a 1000 mah pack is 1a and a 5C charge rate on that pack would be 5a.
1x5=5
A 6500 pack @ 5C would be a 32.5a charge.
LoL I know I know, my brain must have computed 5A because I couldn't comprehend a charge rate of 5C.
This has been a fantastic thread!
Chris (Yokomo - Reedy - Sanwa)
TFTR - Templestowe Flat Track Racers - www.tftr.org.au
_________________________________________________
Ignition75 is offline   Reply With Quote
Old 09-03-2013, 06:07 PM   #452
fq06's Avatar
Danny at SMC says 2c is the best balance of speed and quality of charge. You can go to 3c if in a hurry but no more than 3c even if the pack allows it.
I think it really depends on your charger. If you have a PowerLab or comparable, run what you want. If you have a run of the mill charger, stay within his guidelines.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 09-03-2013, 06:27 PM   #453
What's the general consensus on the Orion chargers? I've got the Advantage Touch Pro...
Old 09-03-2013, 07:16 PM   #454
fq06's Avatar
I know a couple guys that have that one and its a good charger as far as a quality charge. But your limitation may be your power supply, and the max 150w charge rate as far as speed goes.
It with do a 12a charge on a 2 cell pack, but the 150w rate will be a limitation for 4 or higher cell count. You may see a max charge amperage of about 10a charging a 4 cell pack where you might see the max 12a charging a 2 cell.
Amps = Watts / Volts
So 150 watts/14.8v (nominal) for a 4 cell= 10.13 amps.
It will do what it will do and make sure your power supply can provide at least 120% of what the charger can ask for at a minimum. You don't want to max out your power supply.
180 watts, 14.5a and 16v minimum for the power supply. Voltage is a wild card, the higher the amps, the lower the voltage it will pull. Wattage and amperage is the most important in the power supply and the decent ones are 18v.
Disclaimer:
This was a brain dump... someone correct me if I'm wrong on any of this.
Old 09-03-2013, 07:32 PM   #455
Great to hear, I'm only charging 2 cell packs, my power supply is the Muchmore Racing Power Master World Edition 2 EVO, they advertise 24 amp constant current.
I'm hoping that's enough...
Old 09-03-2013, 08:14 PM   #456
fq06's Avatar
Your power supplies voltage is 11v to 15v (probably adjustable with a dial), amperage is 24 so 15 x 24 is 360 watts. They don't mention watts, but we'll assume that is the max.
A 12a charge on a 7.4v pack would be 89 watts so your well within range. Even using the peak voltage of 8.4 comes to 100.8.
All good... unless you want to get into 20a+ charging
Old 09-03-2013, 08:25 PM   #457
Hehe I'll be switching from < 1C charging to 1.84C charging, I'll walk before I run...
Down at the local club in Melbourne we are a little bit more conservative, those charging at 10A or above are known as rebels and outlaws. The most I've seen anyone charging at is 16A which is still nowhere near the crazy talk I've been reading on this thread
Old 09-03-2013, 08:56 PM   #458
fq06's Avatar
Talk to the guys flying planes down under. Plane guys are usually leading the pack when it comes to electric power tech and setup.
Enjoy your shorter charge times
Old 09-04-2013, 07:41 PM   #459
Mate I cannot thank you enough for your help on this one and being patient with my n00bness...
Old 09-04-2013, 08:32 PM   #460
fq06's Avatar
No problem, much better when you understand it. That way if nothing else you are buying the right equipment. And know the limitations like not maxing out a power supply and needing to replace it.
Old 09-04-2013, 11:57 PM   #461
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
What power supply is everyone here using with their icharger? ...the people NOT charging at 40A?!
I love this power supply.
http://www.google.com/search?q=alinc...&client=safari
Its only rated for 32 amps but I'm not sure you need to charge TWO batteries at 20 amps anyway since it takes like 45sec to juice a pack at that rate.
They use these for HAM Radios and for those that remember, KO USA sold these for a bit. I've seen these last over 10 years, probably longer than rctech has existed.
Racing4Evo is offline   Reply With Quote
Old 09-05-2013, 03:19 AM   #462
Regional Moderator
CarbonJoe's Avatar
Here is a cheap server power supply: 12v 74A (on 110v AC) or 108A (on 220v). The fan is pretty loud, but you can't beat the price from Ebay. All it takes is a little work.
http://www.rcgroups.com/forums/showthread.php?t=1005309
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-05-2013, 08:23 AM   #463
Trader Rating: 27 (100%+)
http://www.ebay.com/itm/RC-POWER-SUP...item460be98e1e
That's the one I'm using right now. The guy actually posts here on rctech, but I forget his username. I preferred to just pay to have one already done rather than doing a bad job myself.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 09-05-2013, 08:59 AM   #464
Moderator
Clegg's Avatar
For sure, I've never charged without balancing. Many reasons to balance but I don't want to writs a novel (and neither did you understandably).
Only one reason not to balance charge, speed but its not that much faster and not worth it.
I just recently started running 2S batteries (been running 1S for 1/12 since LiPo came to market) and I was shocked to see/hear most people running 2S batteries never balancing.
It does seem funny, people would work so hard to get the best chargers, high charge rates, best batteries... and then ignore a cell imbalance that could significantly shorten the life of the battery (by over charging one of the cells constantly)
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 09-05-2013, 01:31 PM   #465
Trader Rating: 58 (100%+)
I've had good luck with this one...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=200929683709
MC112b is offline   Reply With Quote
