Old 08-29-2013, 08:00 AM   #421
Mr RCTech's Avatar
Originally Posted by flyernemesis View Post
What is too Hot?
I run only hard lipo packs.
More than 12 degrees above ambient temperature, measured outside of case.
Mr RCTech is offline   Reply With Quote
Old 09-02-2013, 07:28 AM   #422
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Curiosity is starting to get the best of me now. I just started looking into the 20 amp plus chargers. So far I've found:
Icharger
Powerlab 6 or 8
Thunder power dual port
What else is out there that you guys know of? Also what is recommended? Thanks guys.
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
Thanks to the SoCal guys that help me & "Tha Man" Paul Lemieux
Racing TC Class where allowed with what I have.
F. Mendoza is offline   Reply With Quote
Old 09-02-2013, 08:19 AM   #423
Mr RCTech's Avatar
Icharger
Powerlab 6 or 8
New ICharger : (little brother thats cheaper and chargers at 50 amps) $259.99
http://www.hobbytalk.com/bbs1/showpo...04&postcount=1
Old 09-02-2013, 08:36 AM   #424
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
It charges at 30 per side max and 50 if you bridge both sides together in synchronous mode.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 09-02-2013, 01:27 PM   #425
F. Mendoza's Avatar
Thank you gents. I'll look into it.
Old 09-02-2013, 02:16 PM   #426
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
That looks tempting! I might pick one of those up if I can get it a little bit cheaper, around $230 range.
Racing4Evo is offline   Reply With Quote
Old 09-02-2013, 02:31 PM   #427
I just picked up this one , works well so far and you dont need to carry around a power supply'
http://www.hobbypartz.com/75p-ac0620-ac-charger-ii.html
mikpiz is offline   Reply With Quote
Old 09-02-2013, 03:37 PM   #428
Mr RCTech's Avatar
Looks good but it doesn't discharge at 30 amps...
Old 09-02-2013, 04:03 PM   #429
fq06's Avatar
That's probably regenerative discharge where you hook it up to a car battery. It says in broken engrish "when you connect the external capacity resistance, you can use it as the maximum discharge power capacity".
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 09-02-2013, 04:22 PM   #430
Super Moderator
Even then the Thunder is limited to 20 amp discharge as I read it.
Dave H is offline   Reply With Quote
Old 09-02-2013, 05:33 PM   #431
fq06's Avatar
No, your right. 30v/20a with regenerative discharge. 20a is insane anyway for a discharge rate.
My powerlab will do 40 or something but stand alone it will only discharge a 2s pack at a 8 amp rate. Never have bothered to discharge regenerative though.
Old 09-02-2013, 06:51 PM   #432
Mr RCTech's Avatar
Are you sure about that?
I discharge at 30 amps with no problems (one cell).
45 amps with two cell.
But I discharge by heat temperature.
The outside never gets hotter then 12 degrees above ambient temp before i charge.
I have a Venom battery that 2 years old and the IR is in the 2.3 mohm/cell.
No lie.
Old 09-02-2013, 06:56 PM   #433
fq06's Avatar
My powerlab's stats say it will discharge at 10a internal and 40a on regenerative discharge. Never tried regenerative to see though, 8a(ish) is fast enough.
Old 09-02-2013, 07:04 PM   #434
bvoltz's Avatar
Trader Rating: 44 (100%+)
No lie.
Interesting, mine are showing .6 per cell on the iCharger... and all I do is charge, or am I not under reading it correctly? The first time on the iCharger the IR came in around 3.8 per cell....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 09-02-2013, 07:26 PM   #435
fq06's Avatar
On the I charger I think 0.6 is 6.0
6 month old nano-techs read about 6 ohms.
