Who charging 20+ amps or more now??
#137
The cost of enforcement is high. There are rarely enough race directors to patrol voltages, weight, charging, mod rotors in stock stators, stock stators.
As for the hit of 300 to 200 cycles - as soon as my packs hit a certain range of IR they are relegated to practice packs. That is well over 100 cycles but dont keep packs beyond 140+ cycles.
Lot's of craziness in Stock club racing. it's a 17.5 can and it's legal.
#138
Wouldn't it make more sense to limit charge rates at 2c? That means no hot lipo's and as we are all doing it it makes no relative difference in performance.
Let me finish by mentioning, I do not doubt all of your intricat knowledge of lipo charging and behaviour. I just detest that there is a new technology race starting that is completely unnescessary, as the 'advantage' of high amp charging is only an advantage when the rest isn't. Unfortunately we will probably head the expensive way. Again....
High amp charging has been around for a while. Somewhat in the camp of the black art of motor tuning. Most of the guys I compete with do well because they have a complete package - not because they have some trick high amp setup.
It all depends on type of racing and track. Good conversation.
#139
That is part that is a nightmare btw. It isnt stock racing anymore. We might as well be racing mod. I bet if tracks started checking inductance and rotors at stock level - the world order of who is fast in club racing would change.
#140
Team EAM
Hi Julius - At the club race level it seems that most are well below the 2C level regardless if their packs are manufacturer rated above that.
EA
#141
Does anyone know if the Powerlab 8 has adjustable cutoff?
#143
#144
I'll rock up to a meet, and regularly hit my packs with 10amps, usually cause I just want them charged quickly, I'd happily hit them with 20amps, but I was too cheap to buy the 20amp icharger.
I'd say most race packs should easily cope with 2C these days, can't say high amp charging me worries me as much as say charging with a bad quality charger, or maybe charging without balancing connected, and risk a run away cell failure.
These days whenever I read about some LiPo fire etc, I always think of the chargers, and my early B6 type clones, which had the most awful accuracy and terrible calibration.
#145
-Mike
#146
Roar should update their previous rule to 2C or 3C , just to avoid these fires and clubs should also emphasize that racers need to watch their equipment when charging... For that same reason I stay aware of any packs charging in my vicinity, whether it's mine or not : if it starts bloating, I go into action and shut the charger Off and disconnect the pack... I won't lose my stuff because of someone else's negligence. I have seen too many racers chatting, totally oblivious of their packs charging: it's unreal how irresponsible some are !!! I must admit though that I'd prefer having alert racers around me charging at 40amps than distracted types charging at 1C .... 360v2 where I use to race closed because of One of these fires and I hope all other clubs will take notes and enforce charging rules to avoid being closed down ...
You guys push the envelope Racing but I also push the envelope debating here on RCtech.... You call it jabs , I call it a test of your convictions. If you really believe in what you're doing, then you shouldn't have any problem responding to opposite views here, without any emotional rants or nervous breakdowns...
IT'S NOT PERSONAL, IT'S RACING !!!
#147
By the way, even marshalling is dangerous when cars breakdown and get put aside WITHOUT disconnecting the battery from the speed control !!! No battery should be left plugged in when not in use, period .... Abide by these rules and you'll be the perfect marshall... Peace...
#148
apparently it was necessary for someone to put out the fire, as he was on the stand and continued his run!! i haven't seen him there in a while, and i do feel more secure.
#150
Code violations were discovered after the fire department came in because of a lipo fire... Had it not been for that fire, we would've had a great season !
