making a track
Old 05-03-2005, 03:31 PM
Mark G's Avatar
Default making a track
im making a track and i was worndring what wood should i use for an on road. 2"4"s or some thing else ?
mark
Mark G is offline
Old 05-03-2005, 03:42 PM
Jimmy Morris's Avatar
Chalk....it's more forgiving then 2x4's.
Jimmy Morris is offline
Old 05-03-2005, 04:27 PM
Mark G's Avatar
but chalk is harder to drive on bec u might lose where ur going and swich lanes un like wood that wont happen
Mark G is offline
Old 05-03-2005, 04:53 PM
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Default track material
Plastic rain gutter turned upside down, overlap it and screw it together. Works great, not to hard on the cars and is cheaper than wood.
Shopkeeper is offline
Old 05-03-2005, 05:13 PM
Mark G's Avatar
where ccan we get that stuff ?
Mark G is offline
Old 05-03-2005, 05:15 PM
drx
drx's Avatar
any home depot or local builders' supply should have it.
drx is offline
Old 05-03-2005, 05:23 PM
i used concrete!! pvc for walls, i took them down though cuz im going to make it wider, right now its only 5 feet wide.
odawg315 is offline
Old 05-07-2005, 11:49 AM
Shop Owner
nnick's Avatar
Do you think it might be problem if a race track is built inside metallic building? Something like these
Nick
nnick is offline
Old 05-07-2005, 11:58 AM
thats would be a great place to build it especially if it rains or snows around your area it get wet
mountaindr3wz is offline
Old 05-08-2005, 09:56 AM
Shop Owner
nnick's Avatar
I know those benefits and are some of the reasons to built something like this, but my question is basically if there is a chance to have interfernces in a building like that!
Thank you
nnick is offline
Old 05-08-2005, 11:18 AM
Redwings's Avatar
TC4_HALO2_MARK
You could try using the flat soccer domes for mostly the cormers and chalk for the straigh aways etc.
Paul
Redwings is offline
Old 05-08-2005, 11:26 AM
Sleighty's Avatar
Thank you
Ive raced in a building with similar amounts of metal in the cealing as some of those buildings. People did get some interference but none more than we would usually get if we had been in a different building. I dont think it would cause a problem
Sleighty is offline
