Old 05-08-2005, 11:39 AM   #16
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
Default I am making the switching from 27 turn to 19 turn in my touring car. Can anyone give
Gear the c2 conservative like a monster 1 tooth bigger on pinion 48P to start.. if your just getting into 19t,,then I would start there.since you probably have good throttle control... roll throttle from 1/2 to 5/8 open.. never jamm full throttle.. you'll waste jiuce.
reedy 4 mag gear to the moon.. you want this thing to be "molten" when it comes off track.. I'de start it at 5.9 - .5.7.. again throttle controlis the secret.. if your ham fisted full punch kinda guy then set gearing at 6.1-6.2
remember DC motors make full power at 1 rpm not like a nitro motors where you have to spool it up. use as much rpm for any given part of the track... if you try to put out more rpm..lets say in a short chute,..you'll not be able to spin the motor up that high so the rest of your electricity goes into heat;; think of it like a light bulb. burn baby burn.
try it see if youre just as fast down the back straight at 5/8 throttle than full trhottle. light on the throttle keeps the motor efficient and cool.
BadBoyRC is offline   Reply With Quote
PEAKRACING DYNASTY 19 TURN SPEC MOTOR hook6905 R/C Items: For Sale/Trade 5 06-13-2008 08:02 PM
Best gearing for Komodo Dragon 19T spec Pro motor? Porkibear Electric On-Road 29 07-20-2006 10:44 PM
what is the best 19 turn motor (not spec) Apple Electric On-Road 46 02-03-2006 11:27 AM
Gearing issues - HOT motor (reeddy 19t spec.) Captjono Electric On-Road 23 04-03-2005 06:24 PM
Reedy 19-Turn Quad Mag Spec Motor Hebiki Electric On-Road 14 12-28-2004 02:19 PM
SEO by vBSEO 3.5.0
