Old 03-14-2013, 04:11 PM   #1
Cool Lipo battery testing
I looked through the list of forums and did not find one specific to batteries. So I'll ask my question here. I have four Promatch 1S 5000mah 40C batteries that are at least 3 years old and have not been used a lot!!!! probably the biggest problem, I also have several Team checkpoint 2S . They have always been stored with a storage charge.
I would like to cycle and test them, like we used to with NIMH'S at a 20 to 25 amp discharge rate. My I Charger will didcharge but at a very low rate
Is there a specific discharger I can buy or is there a home made version I can build, like the old bulb dischargers we all had. My last resort would be to send my Turbo 35 in to get it upgraded.
THEBIGBULL is offline   Reply With Quote
Old 03-14-2013, 05:53 PM   #2
If you are just going to discharge and test you don't need to upgrade the turbo 35 charger. Just set the voltage cut off to a higher voltage. I use 6.8 volts and 30A discharge.
Con is offline   Reply With Quote
SEO by vBSEO 3.5.0
