Like Tree4Likes
Old 06-03-2015, 03:07 AM   #1381
I would have thought battery back would give more steering.?
Closer to the pivot and would allow more weight transfer off power?
This is usually how pan cars work but
I tried both forward and back and it made little difference.
I also added 50g of weight to the nose of the car which helped a little but not a lot.
I am drawing a chassis to have manufactured with transverse battery layout across the back.....right by the pivot.
I am also looking at new centre shock mount to allow a longer shock nearer the front for more steering.
I will not be beaten by a car....I will make it better and will become competitive with this car.
lee150978 is offline   Reply With Quote
Old 06-03-2015, 03:22 AM   #1382
Rob King has changed ball end of shock to long tamiya and mounted to forward hole in top deck. He wrote in blog that makes more grip to rear.
My question is: You looking for more traction in front, perhaps You have too much grip in rear makes understeer?
gt10r5 is offline   Reply With Quote
Old 06-03-2015, 03:30 AM   #1383
I would think this will give more rear grip on power....but more steering off power.
The weight transfer off power will be more front biased and give more steering.
A steeper centre shock angle will do the same.
The car has very good rear traction....but no steering.
This may be too much rear grip....or not enough front. Hard to tell.
Old 06-03-2015, 04:37 AM   #1384
TryHard's Avatar
If your looking for On-power steering... lower the rear shock mount. Recently I went from 4mm to 2mm, and that gave a very very noticeable difference in how much on-power steering the car had. Flatening the shock is like standing one up on a TC, gives a more linear response.
Back when I had to run Ride fronts (with a 104) I always found weight forward to help with the steering, although that was coupled with ESC behind the battery.
I would suggest it is more to do with lack of front, rather than too much rear. R1 fronts are very very hard.
Other suggestions are go soft soft soft on front springs, raise the upper links in the front, soft side springs, and go soft on side shock greese.
Old 06-03-2015, 05:05 AM   #1385
It was off power where I was really struggling, in the slow hairpins and slow speed chicanes. I could just about hold my own in the 2 high speed on power corners but was having to break to get the back to 'step out' just to get around the tighter corners. This made consistent lap times very challenging.
I tried going to 10k in the side damper and the softest front springs I could find. I didn't try raising the upper front links, or raising the side links.
I did run the softest side springs I could find, and tried battery forward and back, weight in the front etc...
As has been mentioned, I think a lot was down to the tyres and their lack of bite. They are very hard.!
We were also on control additive (Hudy carpet) for an asphalt track which made it more interesting!
Old 06-03-2015, 05:32 AM   #1386
TryHard's Avatar
And that's the art... use the brake to your advantage. I would always (and too some extent still do) use a fair bit of brake with my F1, probably a bit more than most. Given the R1 fronts are so hard, adaptating driving style to suit helps a lot....they'll never bite as well as say 571 or 573 pit fronts.
Turn the brake down on the transmitter until you can get it to a consistent level, then use it to help turn-in in the tight stuff. I'm down at 50% on the radio. You want it too slow the car down, without locking up... harder said than done, but it works.
Old 06-03-2015, 05:39 AM   #1387
I have reduced the brakes to about 80%, and will continue to reduce them. It seemed though that the VBC, Xray and Serpent cars would bite better into the corner and they were able to 'throw' the car at a corner at a much higher speed than my post braking amble.
They have found something with the tyres, setup, weight distribution that I am missing.!
I will continue to play around and see what I can figure out.
I have the Tamiya F104 front end to fit, not saying this will resolve the problems, or even make the car any better but it does appear much easier to work on and make changes!
The Speed passion front end is arguably the most authentic looking but also probably the most over complicated with the intermediate plate and mounting system.
Old 06-22-2015, 04:55 PM   #1388
Schs2013's Avatar
Originally Posted by EDWARD2003 View Post
I've got one and willing to ship to Canada. Send me a PM if you're interested.
Got it you are a Awesome seller to deal with thanks EDWARD2003!
VBC Lightning 10LM, WCICS spec M05v2, TA07 USGT 21.5
Schs2013 is offline   Reply With Quote
Old 07-07-2015, 03:18 PM   #1389
Rabbit0317's Avatar
What bodies will fit on this car? Ex: Tamiya F104- F103, Protoform?
R2, Serpent America, DeSoto Racing, Windy City R/C
Rabbit0317 is offline   Reply With Quote
Old 07-08-2015, 09:35 AM   #1390
JayL's Avatar
Protoform 13,14 and Tamiya F104 bodies, F60, MP24
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 07-08-2015, 11:32 AM   #1391
Rabbit0317's Avatar
Thanks!
Old 08-04-2015, 01:54 AM   #1392
BryceVR's Avatar
I'm happy to have just joined your club and am so far VERY impressed by the chassis.
Thank you to all who have contributed, it has made my re-entry into 1/10 so easy.
Smooth roads..
B
BryceVR is offline   Reply With Quote
Old 08-08-2015, 05:07 AM   #1393
antonio_cadiz's Avatar
Originally Posted by robk View Post
Try a 1mm shim under all the balls for the rear links
only rear ball 2 piece? or all balls 4 pieces? only my english
antonio_cadiz is offline   Reply With Quote
Old 08-10-2015, 01:29 AM   #1394
BryceVR's Avatar
Hey there guys, I'm having trouble getting on to Solaras' site Iget a generic no connect screen.
shop.speedpowerrc.com seems to be down.
I get this.
Wanted some tires and a new Motor/ESC set for 17.5t.
Anyone heard from Solara or know what's going on?
Thaanks
Old 08-10-2015, 11:36 AM   #1395
Trader Rating: 37 (100%+)
I get this.
Thaanks
website is back up.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
