Like Tree4Likes
Old 04-18-2013, 09:07 AM   #121
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
SP1 in hand! Broke the seal, looked at the manual. I'm sure my curiosity will lead me to investigate more before I make it home tonight.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 04-18-2013, 10:14 AM   #122
JayL's Avatar
So F104 rims work?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 04-18-2013, 12:24 PM   #123
Originally Posted by JayL View Post
So F104 rims work?
Yes. And F103s with the correct bearings.
Old 04-18-2013, 01:02 PM   #124
Taylorm's Avatar
.pics....pics...pics
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 04-18-2013, 01:06 PM   #125
If I wasn't at work! I'll see what I can do for the unboxing.
Old 04-19-2013, 08:40 PM   #126
Nice box
Old 04-19-2013, 08:49 PM   #127
Step 1
Built - the ball links need to have a little bit of material removed inside to allow the screw to thread all the way in. Looks like a little bit of flashing from machining left inside.
Old 04-19-2013, 08:56 PM   #128
Step 2
Built - remove the flashing the the ball again. Run the screw through the lock nut a couple times to make sure it will snug up. Don't over tighten the pillow ball retainer screws. Don't over tighten the pillow ball assembly to the chassis.
Don't freak out, the pod plate is thinner than the main chassis, just make sure pod pivots and rotates free in every direction with no binding.
Old 04-19-2013, 08:59 PM   #129
Motor plate.
Assembled. Put the ride height shims in the bottom for F104 tires, top for F103 tires.
on the pod.
Pretty straight forward.
Old 04-19-2013, 09:09 PM   #130
Axle, pin and outer diff half. Ends up making an axle assembly just like a 12th scale. Very cool.
Assembled.
Select the right right height bearing retainer. I put the 1.5 in mine. Looks to be around 4mm rear ride height.
Old 04-19-2013, 09:17 PM   #131
Add the opposite side bearing, retainer, spacer and wheel adapter.
With the axle locked down, lets build the diff. Pretty straight forward.
Diff was easy to adjust, just slide on some spare rims, check for slip and then put the rest of the wheel adapter together.
Old 04-19-2013, 09:22 PM   #132
Steering rack assembly!
Nice Rack.
At this point deviate from the manual and mount this assembly to the lower chassis. It is impossible to put the 3mm nuts next to the posts on with the lower arms in the way.
Old 04-19-2013, 09:28 PM   #133
Now mount the lower arms per the original instructions. Mine are mounted in the 190mm config: outer hole in the plate matched to inner hole (next to the indicator mark) in the lower arm. The instructions show the assembly in the 200mm config. Add extra 2mm shims under each arm mount point and use 10mm screws in the front mount to make up for the 2mm lost to the spacer. The screw needs to go in 4mm and only 4mm or the caster plate will not mount correctly from the top.
This is where I left off for now. Good luck with your build.
Old 04-20-2013, 05:32 PM   #134
Picking up where I left off. When putting in the upper ball retainer, do not over tighten and strip it. I had to CA the wrench to the part, turn it out, break it off the wrench and then notched both of them to be able use a screw driver just like the CRC cars.
Inline was my choice.
Do NOT add more shims here to decrease the ride height.
Installed! The front end is done. I found that the recommended gap for the front tie rods @ 23 + mm is wrong, too much toe in. Mine are currently at 21.7 or so and now have a little toe out.
Old 04-20-2013, 05:39 PM   #135
Spring retainer/battery stop install. I threaded the retainers all the way onto the 10mm screw. The springs snap on real nice. Just touching the spring, my gap from the top of the retainer to the brace was about 1.5mm for preload.
Damper tube and upper pod brace assembled.
Installed along with the damper tube and upper pod/damper brace. I missed a couple of pictures in between here, sorry.
