Like Tree4Likes
Old 12-21-2014, 06:54 PM   #1276
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by bigcracing View Post
Has anybody bet rear axle shaft. I tag the wall not hard but just enough bend the axle buy the diff. Any suggestions for a fix what is a better axle to replace it?
Replaced mine with the carbon option axle, Qteq clamp hub and a spacer. The new Tamiya TRF axle looks to have the correct back spacing.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 12-22-2014, 03:42 PM   #1277
zephuros's Avatar
Gotta agree with the above - the carbon axle is a lot more durable than the standard steel one. I also went down to the local machine shop and custom made a hardened steel axle. Good, but a tad heavy. Stick with the carbon one
awww bollox....
zephuros is offline   Reply With Quote
Old 12-22-2014, 07:33 PM   #1278
bigcracing's Avatar
Trader Rating: 32 (100%+)
Has anyone had a hardened titanium axle made for axles?
bigcracing is offline   Reply With Quote
Old 01-03-2015, 08:23 PM   #1279
Schs2013's Avatar
I have not seen one.
Schs2013 is offline   Reply With Quote
Old 01-03-2015, 08:28 PM   #1280
Schs2013's Avatar
Out of curiosity does anyone know if XRAY X1 F1 parts are compatible on the SP-1?
Old 01-06-2015, 06:05 PM   #1281
adriang79's Avatar
Anyone tried some of the parts from the Street Jam SJF01?
It uses the front suspension from the SP1. There is a castor block available with 3, 5, 7 and 9 degree options and aluminium slotted capture inserts for the steering block.
Also their rear axle is different for the same motor pod.
adriang79 is offline   Reply With Quote
Old 01-06-2015, 08:31 PM   #1282
Manny's Avatar
The front suspension mounting plate is slightly different; as you know there is a wide and narrow option mounting hole for the Sp-1 while the Street Jam has only one setting. They don't line up exactly so the castor blocks aren't interchangeable. The aluminum slotted capture inserts install easier than the plastic ones but they aren't slotted so you cannot use a screwdriver to install them. Otherwise, you are right and the suspension parts are identical. I think my Street Jam came with the reinforced plastic parts whereas my Sp-1 came with the regular plastic.
Manny is offline   Reply With Quote
Old 01-06-2015, 08:40 PM   #1283
malcnz's Avatar
The street jam has a 180 and a 200mm setting just like the sp1.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 01-07-2015, 01:39 AM   #1284
SP-1's width settings are 185mm, 190mm, and 200mm.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 01-07-2015, 10:24 AM   #1285
Manny's Avatar
Correct the Street Jam does have adjustable front width settings. What I meant was that the front suspension mounting plate on the Street Jam car only has one set of mounting holes while the Speed Passion car has two. And the holes do not line up.
Old 01-09-2015, 04:52 PM   #1286
blade072's Avatar
Trader Rating: 98 (100%+)
hi all....has anyone tried the xray pivot ball mount set....thinking of ordering one to see if it lines up
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-13-2015, 10:41 AM   #1287
The TRF axle carbon fits, backspacing to the hub side to center with a Shimizu tire on is just @ 95mm. I cut a custom 7mm spacer from my 6mm ID alloy tube stock and the Tamiya clamp hub with a shim or 2 will is right @ 95mm. I think the Qteq hub will be better with more clamping force, so I need to trade hubs with one of the other cars that has one. 190mm, Done!
Old 01-21-2015, 12:58 PM   #1288
Schs2013's Avatar
Do Tamiya F1 front and rear wings fit without any mods to the chassis? or wing?
http://www.tqrcracing.com/shop/produ...w.asp?p_id=822
http://www.tqrcracing.com/shop/produ....asp?p_id=2671
VBC Lightning 10LM, WCICS spec M05v2, TA07 USGT 21.5
Old 01-21-2015, 01:34 PM   #1289
robk's Avatar
Trader Rating: 22 (100%+)
F104 wings bolt on directly
Old 01-21-2015, 02:21 PM   #1290
Schs2013's Avatar
Smile
Great to know. just didn't want to buy something that was require mods to make work.
Just lazy when i get to the wings i guess
