Like Tree4Likes
Old 11-14-2014, 09:00 PM   #1246
EDWARD2003's Avatar
Just finished the build. I've noticed the rear pod lower plate is not flush with the main chassis. It's 1 mm higher than the main chassis.
Is something wrong?
EDWARD2003 is online now   Reply With Quote
Old 11-15-2014, 01:54 AM   #1247
TryHard's Avatar
Is something wrong?
Nope. Rear pod carbon plate is thinner than the chassi plate (from memory it's 2.5mm vs 3mm for the chassis), hence the 'step'. Not an issue, I just subtracted 0.5mm when setting ride height. So for 5mm f&r, I set the rear pod to 5.5.
HiH
Ed
Old 11-20-2014, 08:56 AM   #1248
Looking to get in to F1 and this one looks promising - where does one purchase the stand alone kit from?
Thanks in advance.
Controversy is offline   Reply With Quote
Old 11-20-2014, 03:34 PM   #1249
hanulec's Avatar
Trader Rating: 27 (100%+)
i get to race against the fastest f1 car in the country this saturday. i cannot wait to report back how my SP1 performs against the new WTF1
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-20-2014, 03:56 PM   #1250
Solara's Avatar
Trader Rating: 16 (100%+)
Good to know that you run one of ours....do let us know. Rob King and Rick Vessell both know this car well enough on carpet...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-20-2014, 03:59 PM   #1251
hanulec's Avatar
at the end of the 2013/2014 carpet season my car was really good locally. real test this weekend..
Old 11-20-2014, 04:11 PM   #1252
JayL's Avatar
Can I ask why you say WTF1 is "fastest car"? Didn't VBC LightningF win IIC?
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-20-2014, 04:22 PM   #1253
hanulec's Avatar
anyone can win (things happen) -- fastest guy tq's
Old 11-20-2014, 07:19 PM   #1254
Hey guys, just picked up the Tresrey version of this car, is there any one that can chime in on somewhat necessary parts to upgrade and have as spares, also best tuning otions ie springs etc, have had a good blast over the entire thread but only have so many fingers on one hand to keep the pages open with lol.
Also, looking for a more modern style body, going to be running F103 foams on the beast, any good advice for this side of the fence, I do quite like the SP body also need wing choices as well.
Cheers in advance
B.C.Ninja is offline   Reply With Quote
Old 11-20-2014, 09:37 PM   #1255
Anyone know where I can get my hands on a new SP1? Looking to get in to F1 for the 2015 season...
Old 11-20-2014, 10:55 PM   #1256
EDWARD2003's Avatar
I'm a little unsure whether or not to run the soft plastic suspension parts with foams on asphalt. Do you think foam tires will generate too much traction causing the plastic to flex to to much?
Also, the differential action is horrid. I'm not sure what's going on there. Maybe, I should switch out the stock metal balls and throw in some ceramics.
Whats the deal with the front top deck that mounts to the back of the servo mount? Does it have any particular function?
The front camber pivot ball and cup setup....ugh... is there an alternative? I was reading earlier thread posts and people were mentioning CRC front knuckles.
Old 11-21-2014, 12:36 AM   #1257
robk's Avatar
Trader Rating: 22 (100%+)
For the diff get a tamiya washer instead of the plain washer from the kit. It will improve action 100%.
I don't know how much difference the battery retainer thing will make. Maybe stiffen the chassis a bit
Crc knuckle s might work. Also use the delrin option pivot balls for the lower arm
Old 11-21-2014, 06:27 AM   #1258
EDWARD2003's Avatar
The kit damper droop is about 2~ mm. Did any of you guys run into this problem? I guess I'll have to add some internal spacers to the shock?
Old 11-21-2014, 10:23 AM   #1259
bigcracing's Avatar
Trader Rating: 32 (100%+)
yes that is what I had to do also is put two associated spacers in the shock my stock droop was more.
bigcracing is offline   Reply With Quote
Old 11-21-2014, 12:23 PM   #1260
Trader Rating: 18 (100%+)
Nevermind.
Sorcerer001 is offline   Reply With Quote
