Like Tree4Likes
Old 01-20-2014, 09:18 AM   #901
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by aris View Post
Hey guys, is the rear diffuser from tamiya F104 fit on the SP F1?
No, it is not a direct fit, but with some mod, it will fit it easily....took me 2 minutes to drill couple holes, couple countersunk 3mm screw and nuts, done.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-20-2014, 11:29 AM   #902
aris's Avatar
Thank you, Solara!
I'll do the same on mine.
Inferno GT2. (Corvette C7.R)
Fg F1 Sportline (Vodafone Mclaren)
Exotek F1R3,Tamiya F104,
Sakura xi sport USGT
aris is offline   Reply With Quote
Old 01-20-2014, 11:25 PM   #903
Thanks for the offer of parts InspGadgt, I would imagine postage to the UK isn't going to be cheap.
I've e-mailed both Speed Passion & RCmart to see when they will have them back in stock; so I'll get back to you if I get really desperate.
Its the ongoing supply that worries me: I recognise that these things will get made in batches, but Speed Passion need to get bigger batches made.
Ian_R is offline   Reply With Quote
Old 01-21-2014, 12:31 AM   #904
Its not so bad going airmail...just EMS that gets expensive. Also FedEx has a new international offering which isn't too bad.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 01-22-2014, 04:30 AM   #905
InspGadgt,
Speed Passion are currently trying to locate some parts for me; so I'll let you know.
All,
With reference to kingpins unscrewing; has anyone tried a grub screw in the threaded holes in the axle?
Old 01-22-2014, 04:58 AM   #906
nrtv20's Avatar
Originally Posted by Ian_R View Post
InspGadgt,
All,
That's what I do; takes out a lot of slop as well. I would recommend it!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-22-2014, 05:53 AM   #907
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I do as well. 3m x 3 set screws in each side with a dried layer of blue Loctite so it doesn't seize. It stops the king pin from riding up into the pivot ball as well.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-22-2014, 07:28 AM   #908
metalnut's Avatar
Trader Rating: 36 (100%+)
That's actually the recommended method from SpeedPassion in the newer 185mm setup. I recommend a tiny bit of blue threadlock to really keep that grub screw in place.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 01-26-2014, 09:11 PM   #909
metalnut's Avatar
So, I've been struggling with front end grip into corners since the 185mm rebuild with the plastic/carbon arms. Last night Diffuser suggested playing with the shock spring, so I just wanted to mention that Spec-R springs fit the SP shock perfectly. I tried a slightly stiffer spring and things were better, I'm hoping to improve them even further. I also went back to the 10* caster.
- Ricky Bobby
Old 01-27-2014, 05:35 AM   #910
I had fun with mine this weekend. Green tires hurt traction, but the car was predictable and consistent. I could probably have gone to a softer front spring. The tires need a few good practices to come in. The LM-1 on the other hand was glued to the track with the foam tires. Both chassis are very forgiving.
Old 01-27-2014, 07:25 AM   #911
nrtv20's Avatar
Speaking of front springs; how do the standard SP-1 springs rate in the Tamiya world? Silver, gold, Black?
Old 01-28-2014, 09:18 AM   #912
Solara's Avatar
Soft.....very much same as the silver in Tamiya.
Old 01-28-2014, 09:20 AM   #913
Solara's Avatar
I have a request....for those who experienced the steering block, especially the carbon reinforced material....that broke easily with a light impact on the track, can someone post a picture of the block and show me exactly where it break...?
I really don't want to crash my SP1 to recreate the scene myself and hope someone can post a pic of the block and I can find out how to improve the block....thanks.
Old 01-28-2014, 11:26 AM   #914
Steering bridge cracked.... Steering blocks still going strong.
Old 01-28-2014, 02:37 PM   #915
BadPanda818's Avatar
I finally gave in to F1 racing and bought my SP-1. First of all great job with this kit SP. Building the kit wasn't really until I had to assemble the steering components. Yes just like most of all guys that built this kit, I too have stripped that oversized grub screw that holds the ball in place and I noticed that it was binding. screwed it to my power drill and problem fixed. Besides building the steering, everything else was problem free. took the car last Sunday to the track without any body or wings and being a noob in F1, I kept spinning out. After a couple of laps, I finally managed to get the hang of the car and was impressed with the handling. The kit set up gave the car more than enough traction if not too much traction around the track that the rear tires showed uneven wear due to the track being right turn biased. the kit set up with 25 weight oil, 10 degree caster and Tamiya f104 kit tire tires raised a couple of eyebrows around the track. even our F1 guru was impressed with the car. now I am just waiting for my body/ wing set from Tamiya and some shimizu tires and I'll be ready to compete. Again great job SP
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
