Like Tree4Likes
Old 10-20-2013, 08:22 PM   #631
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by simple View Post
Sorry, maybe I wasn't clear, in the second paragraph I was referring to the Associated links, not the springs.
Oh, sorry, I misread what you wrote. Yeah, I totally understand, I don't expect any links to withstand that kind of hit. I was looking at the Tamiya parts tree for the football, as I'm looking for something a little tougher than the SP unit. Ideally the SP carbon reinforced parts will come out soon, but for now I just need to order something to fix my car for the next race day.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 10-20-2013, 08:41 PM   #632
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by metalnut View Post
I had some really bad luck in the main tonight. I got pushed into the pipe during the second lap by a sporadic driver and must have cracked something, as the car started spinning out when trying to steer right. I pulled it, looked it over and didn't see anything wrong, so I tried to drive it again. That was a dumb move, as the car spun out on the straight and then got t-boned really hard. I broke both side links and the football
I'd like to verify, is this the Tamiya parts tree I need to use their football and side links? http://www.tqrcracing.com/shop/produ....asp?p_id=6023
The links that shattered tonight were the Associated ones, so I'd like to give Tamiya a try.
Tamiya links are direct fit, but the football doesn't work. SpeedPassion is getting their new parts in now, so I think the hard plastic should be available soon.
Dammit. In addition to the damage I listed above, it looks like I also bent one of my side springs. Does anyone have the rates of the various springs that come with this kit? I'll have to order some Tamiya (or CRC?) side springs, but I don't know what the kit rates are for the front and side springs. Any ideas?
CRC Red is close to the kit side spring.
Old 10-20-2013, 09:51 PM   #633
Yes, the tamiya side link will fit directly with the associated ball. But for the football both tamiya, associated or even CRC or vbc won't fit....... Need to buy the speedpassion one......
www.beamcat.com
beamcat is offline   Reply With Quote
Old 10-21-2013, 12:20 AM   #634
metalnut's Avatar
Thanks guys! I really appreciate the help.
TQRC is out of stock on CRC side springs... is the Tamiya kit around the same rate range? http://www.tqrcracing.com/shop/produ....asp?p_id=3306
I'm running rubber tires on a CRC carpet track, 21.5 motors.
- Ricky Bobby
Old 10-22-2013, 08:13 AM   #635
Csaari77's Avatar
Trader Rating: 34 (100%+)
I've been looking at this car for a little bit, and I really like the features that are provided in the kit. How tough is the plastic on this car? I've always run F104s and they have proven to take a beating, is this car on par with the Tamiya durability wise? What are some of the weak points out of the box that will need to be upgraded?
Thanks in advance!
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 10-22-2013, 11:00 AM   #636
Thanks in advance!
If you go back further in this thread you will find out some of the weakness. But heres a recap. My biggest gripe about the sp1. Is the side links, they are very flimsy. You can replace them with Associated side links but you have to use the associated pivot balls. The football is also another weak point, but you cannot switch this part to Tamiya or Associated because their too big or small. Speed Passion is releasing carbon reinforced plastics. Or better quality plastics to compensate. Another gripe about it. Is the car is designed out the box to run in the 200mm foam tire category. If you dont want to run that. Then stock up on various shim sizes. Youll need them. You can switch over your f104 front end to this car very easily. For the price it is a good car. I sometimes wish I still had one.
RS_ZACH is offline   Reply With Quote
Old 10-22-2013, 02:08 PM   #637
robk's Avatar
Thanks in advance!
Kit plastic is pretty soft. I put Tamiya carbon side links on, which snap right on direct replacement. Associated links have a different size ball. SpeedPassion has the only football that works, but the new plastic is coming shortly. I have yet to break the stock plastic front end but I don't know what other people have experienced. They are also coming out with delrin lower pivot balls for the front end, which will help a lot. The stock ones are not very good.
That being said, the only thing I replaced right away was the side links. This is honestly the best link car I have driven out of the box, and I was not expecting that. I haven't run everything but I was surprised how much I liked this car right away.
The things you would really want to look at for options are :
Lower pivot ball for front end - this will really be a must have.
Aluminum front suspension mount - this is not a must have but it's easier to make the car narrow (190mm) for pit tires without having to drill on the stock piece.
Hard plastic - mostly for the side links and football. I really don't have a problem with the front end at all, and I have been racing on carpet with hard barriers.
Old 10-22-2013, 02:36 PM   #638
Originally I had a problem with a steering knuckle which the pillow ball pulled right through. I bought a whole bunch of spares because I thought this was going to be a problem part but haven't broken another one since. So maybe 1 set of the knuckles would be good to have as a spare.
My other complaint is the rod ends...they fit too loose and the one on the bell crank kept popping off. For now I've replaced them with standard AE ones and used cotton in the cup to take up the slack and they seem to be holding better. Still looking for one that fits more properly though.
My side links I've bent up a bit but I have yet to break them or the football...knock on wood
Old 10-23-2013, 11:29 AM   #639
Trader Rating: 18 (100%+)
I literally have this car sitting in my shopping cart, ready to submit my order... But now I'm reading that modification is required to run rubber tires? Do I need optional parts? Trying to make sure I have everything in the box so the car will be ready to race ASAP. Does the car come with front and rear wings? And finally - I've got some Pardus premounts in my cart - I assume the F103/F104 wheels work?
Sorcerer001 is offline   Reply With Quote
Old 10-23-2013, 01:26 PM   #640
metalnut's Avatar
* No "modifications" are necessary to run rubber tires if your club doesn't have super strict maximum width rules. With Pit tires, the 190mm setup is a few millimeters wider than 190, which is where some people modified things. If that's not an issue, the only thing you'll have to do is mess around with spacers to get the proper ride height. I'm running Pit rubber tires with no problems and no modifications (other than ride height)
* The car does NOT come with any wings, nor with a body, you have to get those separate. F104 bodies and wings are a direct fit.
* Yes, F104 wheels are a direct fit too
Buy the car, you won't be sorry! But, do yourself a favor and buy the AE balls and links right away, don't even bother with the stock ones.
Balls: https://www.tqrcracing.com/shop/prod....asp?p_id=2020
Links: https://www.tqrcracing.com/shop/prod....asp?p_id=2683
- Ricky Bobby
Old 10-23-2013, 03:23 PM   #641
my apologies on the football comment. I could have sworn we put one in Korey's car early on.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 10-23-2013, 03:25 PM   #642
Thanks for the advice! My local track (Timezone) does follow widely recognized rules when holding larger races, so I'll have to figure out how to narrow it down. Does the car come with spacers to lower chassis height?
Old 10-23-2013, 03:26 PM   #643
robk's Avatar
You shouldn't have to do any modifying for Pardus tires. My car IS modified to be 190mm for Pit tires, and it is like 180 or 182mm with Pardus.
Old 10-23-2013, 03:39 PM   #644
Sorry, I didn't pay attention to the offset - didn't realize the Pardus were narrower. Thanks again for the advice. Just put my order in at TQ - The car, F104 body set, balls (for the car), links, and Pardus tires. I'd heard these tires work pretty well on carpet - they're the IIC spec tire. Is this true? I was running grooved Pits (softs, I think) on my FGX, and it had tons of traction - maybe too much for my driving style.
Old 10-24-2013, 12:45 AM   #645
metalnut's Avatar
Yes, you get plenty of 1mm and 2mm shims to lower the car for rubber tires. When I was shimming mine, though, I didn't follow Solara's path and shimmed a little differently. If you want I can try to take a picture of what I did.
- Ricky Bobby
