Like Tree4Likes
Old 09-26-2013, 05:06 PM   #586
robk's Avatar
Trader Rating: 22 (100%+)
yes
Old 09-26-2013, 08:20 PM   #587
Originally Posted by clint View Post
Hi guys I may be getting one of these bad boys..question- do the Tamiya wheels and body kits/wings fit without any mods?
Yes, have use both. Rims direct fit. Some body you may need to cut a bit more to clear the side link. No big deal.
roche.hk is offline   Reply With Quote
Old 09-26-2013, 10:22 PM   #588
metalnut's Avatar
Trader Rating: 36 (100%+)
Any news on the aluminum parts? Specifically, are there aluminum versions of the pivot balls and "slotted capture inserts" in the works? In my opinion, those are the only two bad parts about the kit and aluminum versions would make a huge, huge improvement. Pretty please?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 09-27-2013, 04:25 AM   #589
Jorge T's Avatar
^ plus the soft front arms. When is the new plastic available?
RSD MS
Jorge T is offline   Reply With Quote
Old 09-27-2013, 07:18 AM   #590
Solara's Avatar
Trader Rating: 16 (100%+)
The lower hinge pin ball (metal material), carbon mixture plastic parts including the arms and the pivot ball insert (not aluminum but harder plastic) and other aluminum option will be in USA around middle of October.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-27-2013, 08:33 AM   #591
metalnut's Avatar
That is great news! Thank you, Solara
- Ricky Bobby
Old 09-27-2013, 10:38 AM   #592
Solara's Avatar
We are trying to align with the new LM-1 release time....
Old 09-29-2013, 09:53 PM   #593
BadPanda818's Avatar
Trader Rating: 17 (100%+)
My apologies before hand for noobish question. What is the main difference between the reg sp1 and the treyser sp1 besides the red anodized parts. I cannot constitute an extra 90 bucks just so my sp1 is red. Appreciate all replies in advance.
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
Old 09-30-2013, 02:59 AM   #594
Just the color......
Old 09-30-2013, 06:35 AM   #595
Wow and I guess the name aswell. Looks I know ill be leaning towards to. Thanks for the answer.
Old 09-30-2013, 08:27 AM   #596
metalnut's Avatar
LM-1 announcement: http://www.bigsquidrc.com/speed-pass...ns-spec-racer/
Solara, can you tell me how the LM-1 shock is mounted on the battery hold-down brace? There is some sort of white bushing with a top screw, it looks like. I'm asking since the shock is a bit loose on my SP-1, mounted on the two different-sized ball studs (front/back). Is the LM-1 method less sloppy? If so, I assume it can be retrofitted to the SP-1?
- Ricky Bobby
Old 09-30-2013, 09:50 AM   #597
Solara's Avatar
That is the only different.............
Old 09-30-2013, 09:54 AM   #598
Solara's Avatar
Basicly, the way it mount on the LM-1, can be used on SP-1 too...however, it was our Japanese driver testing the LM-1 at Yatabe Arena and he recommend to use a clear rubber o-ring to place above the shock cap with a 3mm screws on top for LIMITING the roll action of the damper due to the FOAM TIRES setting..........
If that is what you prefer to use on SP1, you can try that but it is not required......my 6 months old SP1 is still running the original cap and the ball stud and the play on mine is very very little.
Old 09-30-2013, 01:09 PM   #599
metalnut's Avatar
Interesting, but good to know! The play on mine is noticeable, though I'm not sure how you would define it. I may try to take a quick video of it to show you. I may not be a problem at all, though, I'll find out on Saturday
- Ricky Bobby
Old 10-01-2013, 10:20 AM   #600
hello, I bought a few days ago sp1 but I am finding some difficulty in finding replacements. normally buy through internet sites like Rcmart, TQRracing, I also would like to know where I could find these parts for the car. thanks and regards
topansky is offline   Reply With Quote
