Speed Passion  F1 car - The SP1 >
Like Tree4Likes
Old 09-22-2013, 08:45 PM
  #571
Korey Harbke's Avatar
Originally Posted by metalnut
So, I had a chance to have a few local F1 guys look over my newly built kit last night. Overall I think I did a good job, but one of them noted a problem: my rear pod droops down past horizontal. I built everything per the manual as far as I can tell, but it looks like the length of the shock lets the pod droop. I have the shock mounted in the hole closest to the rear pod, and I'm using the shortest shock end screwed all the way in. So... what's the best fix here? I can add spacers to the inside of the shock to limit it's travel, or I could try mounting it in the "middle" hole. Have you guys done either, or did I screw something else up that is causing this droop?
For our track I would just put spacers under the piston before building the shock. I always liked the way this car worked with a short and angled shock, so I would't move the shock to the other holes.
Korey Harbke is offline
Old 09-22-2013, 08:46 PM
  #572
You need to limit the shock internally, no you didn't do anything wrong it's a regular part of tuning F1chassis with pod droop
Difuser is offline
Old 09-22-2013, 09:13 PM
  #573
Ya, cannot remember exactly but I do have 1 or 1.5mm spacer inside the shocks as the are way too much droops.
beamcat is offline
Old 09-22-2013, 09:35 PM
  #574
metalnut's Avatar
Trader Rating: 36 (100%+)
Thanks guys! I really appreciate the help. Talk about a crash course in F1 setup I'll add some limiting spacers and get the pod to a nice even horizontal.
metalnut is offline
Old 09-22-2013, 10:38 PM
  #575
Some droop past horizontal is normal...as people above mentioned you use spacers inside the shock to regulate how much droop you have. I run mine with no additional spacers inside because on my track the car pushes and the extra droop allows more weight transfer to the front.
InspGadgt is offline
Old 09-24-2013, 12:27 AM
  #576
Hi, I have a question, you can place the body and wings of Yokomo in this car?
topansky is offline
Old 09-24-2013, 12:54 AM
  #577
the sp1 have lots. talking about at least 3-4mm.
beamcat is offline
Old 09-24-2013, 02:14 AM
  #578
Yup they do...and rubber tires on pan cars push like mad so more is needed than a normal pan car setup.
Old 09-24-2013, 10:06 AM
  #579
Trader Rating: 17 (100%+)
Body yes....wing, not sure....I think all the wings in the market should be all the same setup like the F103 from Tamiya...I am just guessing.
Solara is offline
Old 09-24-2013, 11:07 AM
  #580
metalnut's Avatar
Well, last night I added 3mm (I believe) of shims to the inside of my shock, which almost eliminated all droop. There is a very small amount now, I would say around 1mm. So, if my car ends up pushing too much on carpet, I'll just remove 1mm at a time and see how it improves.
metalnut is offline
Old 09-24-2013, 12:35 PM
  #581
If your shock end is completely tight you can also make small adjustments by loosening the shock end. Usually once I have the big adjustment made(internal limiters) I just adjust by the shock end.
Difuser is offline
Old 09-24-2013, 02:44 PM
  #582
metalnut's Avatar
That's a really good idea, thanks for the tip
metalnut is offline
Old 09-25-2013, 05:18 AM
  #583
thanks
topansky is offline
Old 09-25-2013, 05:16 PM
  #584
Sick !
brushless55 is offline
Old 09-26-2013, 04:51 PM
  #585
clint's Avatar
Trader Rating: 24 (100%+)
Hi guys I may be getting one of these bad boys..question- do the Tamiya wheels and body kits/wings fit without any mods?
clint is offline
