Like Tree4Likes
Old 08-19-2013, 01:59 PM   #466
I went with the 574 front tires and an additional 1mm shim on the bell crank ball studs for more ackerman. It wasn't a huge affect but it helped.
Old 08-19-2013, 02:44 PM   #467
Solara's Avatar
Trader Rating: 16 (100%+)
Cool....I added the 1mm on the bell crank but I will try 2mm next time....will give a shot on the 574 front tires with softer insert. I will also try the stock SP front springs...and really want to see how to add more caster. Thanks....
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-19-2013, 03:11 PM   #468
Yeah I'm running the SP-1 stock front springs and added 1mm on the ackerman over what was already installed stock so I think that is a 2mm spacer if I remember correctly.
Old 08-20-2013, 12:44 PM   #469
Solara's Avatar
I have to throw away all those Tamiya F103 F104 setup and restart on the SP1.....I have hardly ever remember to use silver or gold springs on the F103 and F104 and when I first used the SP1 stock spring, I was like....that spring is too soft and if the car is carrying the corner with that silver, it will just collapsed in like no time...
But I have to try that just to believe it....
Old 08-20-2013, 02:09 PM   #470
JayL's Avatar
can you limit the front droop more?, that may help if it is weight transfer to the rear
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 08-20-2013, 02:18 PM   #471
I have the battery all the way back and the car has a lot of steering. I had to go from stock SP front springs to Tamiya black. I also went with a Tamiya pitch shock so I could run a softer center spring.
Sydewynder is offline   Reply With Quote
Old 08-20-2013, 03:36 PM   #472
Solara's Avatar
Thanks for all the advise.....I drove Rob King's SP1 before and his car is the fastest on the track and his car has tons of steering.....TOO MUCH that I cannot even drive it except himself (just not the style that I like to drive on a F1 car).....at one point, he has to use the stock Tamiya front tires or the Pardas tires on front just to take off some of the steering.
Couple things I know I can do....softer springs, narrower rear track width...shorter wheel base (which Rob did that and I overlook that..). Camber change to 0.5* Possible checking to see do I really have 10* caster.....3mm ackerman setting.
I have my shorty lipo place FORWARD and hoping that will give me more steering...but may be I will change it to the full lipo and test it. However, placing the lipo at back only do give more rear traction as that is something I have tried on mod with foam tires on 215mm setup on the SP1.
Droop is set to zero now........the past weekend racing (vs 104 Verision 2, VBC and TRF101)....I can hear my car is screaming (front tires) by pushing all the way from middle of corner to exiting corner (ON POWER)....each corner causes me at least a tenth or so and each lap is about 0.4 behind the leader. Car handle just great without any weird acting at corner but just push at off power and push even more on power....I can use more drag brake to slow the car down before entering corner but that is just way too much throttle travel on each turn when running F1....those action will cause alot of time. If it is a 4WD that I can understand...but for 2WD, I should be able to carry on the throttle when it is at middle of corner and exiting corner...
If nothing work.....I will open up the 574 tires with the trued Tamiya foam tires with more air gap as the insert....
Old 08-20-2013, 03:59 PM   #473
I believe I went with only about 20% drag brake...mainly to slow the car down coming out of the sweeper...it was coasting too much for me.
Old 08-20-2013, 08:59 PM   #474
Trader Rating: 37 (100%+)
Add a little weight up front?
Nexus is offline   Reply With Quote
Old 08-20-2013, 11:52 PM   #475
robk's Avatar
Trader Rating: 22 (100%+)
Howard
Make sure the shock ball stud is in antenna hole on the upper deck. You will have to use a Tamiya long shock end.
You can also try stiffer center spring.
Old 08-22-2013, 06:14 AM   #476
Zedsispeho's Avatar
Hello Solara,
I have tested the new sweep racing v2 tires on the SP1 and I found that they would provide me a lot more steering on asphalt than the pit shimizu (without changing my setting).
+ YouTube Video
I hope this helps
Best regards
3 Racing FGX, 21.5T sensored + Esc Hobbyking 80A Turbo.
Team Saxo F1-180 21.5T sensored + Esc Hobbyking 80A Turbo.
Yokomo YRF001 13.5T sensored + Esc Hobbywing 80A Turbo.
Zedsispeho is offline   Reply With Quote
Old 08-22-2013, 07:45 AM   #477
Solara's Avatar
Originally Posted by Zedsispeho View Post
Hello Solara,
I hope this helps
Best regards
Nice, good to know..I was told the V2 is better, I will give that a try....thanks.
Old 08-22-2013, 07:46 AM   #478
Just surveying those running 21.5 w/ rubber tires...
What rear axle spacers are you running to get ride height and what pinion/spur?
Old 08-22-2013, 07:49 AM   #479
Solara's Avatar
I was about the same, but after driving Rob King's car...slowing it down at the corner in order to give more steering does not get me the time to catch up, it need to carry the corner speed in order to pick up exiting corner... it is 2WD afterall and it just cannot pick up like a 4WD.
Originally Posted by robk View Post
Howard
I will have to try that next....again, I overlook your setup, again. Good luck at TCS National.
Old 08-26-2013, 01:06 AM   #480
kschu's Avatar
Send a message via MSN to kschu
anyone run ride R1 f1 preglued tyres here? i ran it and the car too much understeer....
Give the best while u can !
kschu is offline   Reply With Quote
