Like Tree4Likes
Old 08-14-2013, 09:46 AM   #451
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Nexus View Post
You can shop directly with Speed Passion or keep an eye out for TQ RC Racing http://www.tqrcracing.com/ as they should be stocking parts and kits very soon.
We also have a good stock of kits and spares
http://f1paintlab.mybigcommerce.com
And we will be getting the hop ups in as they become available
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 08-14-2013, 10:34 AM   #452
Trader Rating: 37 (100%+)
Awesome...I forgot.
I'll be looking to buy this for my SP-1
http://f1paintlab.mybigcommerce.com/...ferrari-f2012/
Nexus is offline   Reply With Quote
Old 08-14-2013, 10:37 AM   #453
BP SHADOW's Avatar
Awesome...I forgot.
We have plenty of those in stock as well as F60's, McLarens, and F104 Pro bodysets
http://f1rclab.com
Old 08-16-2013, 05:56 AM   #454
Rich Valente's Avatar
Trader Rating: 21 (100%+)
Default SP-1 durability
How is the durability of the SP-1?
Trying to decide between F104 v2 and SP-1 for my 13 year old son. We race on outdoor asphalt and want to run rubber tires.
Now that the SP-1 has been out a few months, thoughts/opinions?
Thanks,
-Rich
Rich Valente is offline   Reply With Quote
Old 08-16-2013, 07:12 AM   #455
BP SHADOW's Avatar
Thanks,
-Rich
Both are good cars, you can't beat the SP1 for the money. I have only run one pack on the carpet, but it ran well. I did clobber the wall a couple of times but nothing broke. I am lending the car to someone this weekend for the UF1 Midwest race in Cincinnati so we will see how it fares outdoors
http://f1rclab.com
Old 08-16-2013, 07:51 AM   #456
Yes, for the money the SP1 looks like an incredible deal.
I'd rather not spend $300-$400 on a TRF101 or anything super high-end (he's only 13) the new Serpent F110 looks nice too, but would like him to have a competitive setup.
Seems like the 104v2 with hopups would be quite a bit more money that the SP1.
Thanks,
-Rich
Old 08-16-2013, 07:55 AM   #457
BP SHADOW's Avatar
Thanks,
-Rich
There is actually a price reduction coming, so a great deal will be even better. And yes as good as the TAMIYA stuff is you will be over $300 for a competitive setup with the V2
http://f1rclab.com
Old 08-18-2013, 06:59 PM   #458
I received my kit the other day, and I am currently about half way done. One thing I noticed though, as the motor pod plate does not sit flush with the main chassis. The problem is the football sits to high up, and makes the center pivot point about .5 to .75mm higher then the main chassis. An easy way to fix this was some sand paper on a piece of glass, and slowly sanded the lower football piece until he pivot ball was at the same height as the pivot balls in the side links. (the way it should be!)
Does anyone know when the carbon (wider) battery holder will be coming out?
Shawn.
Shawn68z is offline   Reply With Quote
Old 08-18-2013, 10:07 PM   #459
Shawn.
The chassis plate is thicker than the rear pod plate by .5mm so it will be .5mm higher at the pod than at the chassis.
Old 08-19-2013, 03:39 AM   #460
Ph3nyx's Avatar
Shawn.
i think you may have put the pivot ball support in a wrong position (flip it maybe ?) , normaly it'll be perfectly aligned
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 08-19-2013, 08:12 AM   #461
Yeah, I guess that would explain it! I didnt even notice the difference in thickness. Assumed (from other pan cars) that the motor plate and main chassis would be the same material. Opps!
Shawn.
Old 08-19-2013, 08:15 AM   #462
Looking for peoples opions on where is the best place to install the battery for this car. I am going to use a 2S Shorty pack, which is 96mm long. It leaves just enough room to install the ESC (juststock), and RX'er inline with the battery.
I was thinking of mounting it aft for better rear grip, but the ESC wires are going to be VERY long.
Has anyone tried mounting the battery foward, and how did it effect your car?
Shawn.
Old 08-19-2013, 09:53 AM   #463
I mounted my electronics on the sides initially to test how the car handles with the battery in several positions. For my car running the battery up front worked best.
Old 08-19-2013, 01:06 PM   #464
See last post on page 27 of this thread.
I have my 2s positioned where the balance port is right under the middle hole of the "upper plate". I've seen several other posted cars with a similar position.
Allows mounting of the receiver in front, between the battery and steering servo. Also allows enough room behind for the esc.
Its a logical position to start with.
For reference, I run on carpet. No traction concerns at all.
simple is offline   Reply With Quote
Old 08-19-2013, 01:55 PM   #465
Solara's Avatar
Trader Rating: 16 (100%+)
This is my setup since day 1...trying to place the lipo more forward for more steering, but still, I need more more more steering...I am still looking for more ON POWER steering running this outdoor with 571 572 combo. I might need to work on the tires....
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
