Like Tree4Likes
Old 08-09-2013, 08:27 AM   #436
antonio_cadiz's Avatar
hello
I need spur gear 18 ball, but can not find,
What spur gear model is good for the sp1?
thanks
antonio_cadiz is offline   Reply With Quote
Old 08-09-2013, 11:06 AM   #437
Xenon makes spur gears with 16 diff balls as does CRC but the CRC ones use a smaller diff ball so you need to space the axle to compensate if it even fits. I haven't tried the CRC one with the SP-1 yet to see if it will even work. To my knowledge no one makes a diff gear with 18 diff balls. Kimbro is probably the most common and works very well with 12 diff balls.
Old 08-09-2013, 11:54 AM   #438
thanks Inspgadt
Old 08-09-2013, 04:26 PM   #439
robk's Avatar
Trader Rating: 22 (100%+)
The spur included with my SP-1 has 18 balls
Old 08-09-2013, 06:08 PM   #440
JayL's Avatar
rob: could you post your SP-1 setup? the one that got posted here was wierd inverse through a mirror
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 08-09-2013, 07:12 PM   #441
robk's Avatar
https://docs.google.com/file/d/0B4jX...52RXF6RGc/edit
Old 08-09-2013, 08:25 PM   #442
Originally Posted by antonio_cadiz View Post
hello
thanks
Are you counting the inner and outer holes? I was referring to the outer holes only.
Old 08-09-2013, 09:15 PM   #443
robk's Avatar
18 balls in the outer holes ...picture coming soon
Old 08-09-2013, 11:31 PM   #444
Wow...now we just need that in 64 pitch...
Old 08-10-2013, 04:47 AM   #445
hotrod1933's Avatar
Default spurs
From memory rcmart or rcmarket have some.
pretty sure they a kawada super spur. or kawada ?? i got a couple but have tossed the packets.
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 08-10-2013, 05:55 AM   #446
hello
but 16 or 12 holes is good for sp1???
the diff ring have one diameter for 18 balls. fewer balls is smaller diameter.
sorry for my english
Old 08-10-2013, 12:13 PM   #447
Any amount will work...the more diff balls you have the less pressure it takes with the diff nut to keep the diff from slipping. With less pressure you get a smoother diff. So the more diff balls you can use the smoother you can build a diff.
Old 08-10-2013, 07:52 PM   #448
robk's Avatar
No doubt, the diff is pretty awesome with this spur. 64p and a couple smaller tooth counts...
Old 08-13-2013, 09:55 AM   #449
hello!
where there are shops of all replacement parts and options??
what paint is most real for tamiya f1 f2012 ps-2 or ps-34.
thanks
Old 08-14-2013, 09:55 AM   #450
Trader Rating: 37 (100%+)
hello!
thanks
You can shop directly with Speed Passion or keep an eye out for TQ RC Racing http://www.tqrcracing.com/ as they should be stocking parts and kits very soon.
Nexus is offline   Reply With Quote
