Like Tree4Likes
Old 05-07-2013, 07:27 AM   #226
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The F60 wing sort of slides on, but the holes don't line up exactly. I could cut the lower part of the bracket down as it's not needed and that would eliminate the need for spacers all together. The top of the wing lines up with the top of the airbox and it looks right height wise in comparison with the other F1s I have, but a hair too far forward. One quick trip to the hobby store for screws and I'll have it nailed down one way or another. Still waiting to buy and F68 body, I'd really like to try one.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 05-07-2013, 07:55 AM   #227
Trader Rating: 29 (100%+)
I mounted my F60 rear wing with no spacers, and it looks real close to where it should be. My F68 body just arrived last night, they have them in stock on the speed passion website.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 05-07-2013, 10:27 AM   #228
Trader Rating: 16 (100%+)
Whats the best place in the US to order an SP-1?
www.5280Raceway.com | Racing. Elevated.
samsking is offline   Reply With Quote
Old 05-07-2013, 10:29 AM   #229
Trader Rating: 15 (100%+)
ahahahaha sucker
I ordered mine from f1paintlab. Was nice since Brad also carries a bunch of the other stuff I wanted.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 05-07-2013, 10:32 AM   #230
F1paintlab, or direct from Speed Passion USA. Unless you like red you can over pay and buy the Tresrey "red" version from Tresrey USA.
Old 05-07-2013, 10:53 AM   #231
I put the 2012 body set on my Sp1 and aside from 2mm of spacers under the body posts it dropped right on rear Wing and all.
Glad to report that despite a dusty pollen filled track the Sp1 was the smoother to drive car compared to the v2. Spent all day tweaking both cars on the same tire and set TQ and would have won the main aside from a ball stud that slipped from the servo arm, new car gremlins...
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-07-2013, 12:31 PM   #232
Maybe you didn't assemble the center uprights properly so it doesn't line up? Mine slid on just fine even without spacers...I just added them because the wing looked too far forward to me.
2mm seems about right for the rear body posts on the F60 body as well. I've been debating mounting the body lower as with a little trimming I could get it to clear without raising the rear posts...but I'm not sure I want to do that just yet. It would be much easier just to raise the posts.
Old 05-07-2013, 01:03 PM   #233
Marty Peterson's Avatar
R/C Tech Charter Subscriber
Dan
can you please post a picture of your electronics layout in the SP-1 Please.
Here for the fun of it!
Selling HPI F10 Front Knuckles and Complete Rear Axles W/Diffs Ball and Gear.
W/12mm TC Hubs & W/14mm F1 Hubs Good for std bearing Pans cars. STD Bearings!
eBay item number: 200947192161,200947193175,200947187493
Marty Peterson is offline   Reply With Quote
Old 05-07-2013, 01:25 PM   #234
It's a bit of a rats nest due to testing Sunday. We moved a few things around. I can post some up in a bit. I did mount the Reventon on its side behind the servo and the receiver on the right.
I might be flopping the layout and going to rear speedo after I get some scales to weigh a few things for balance.
Old 05-07-2013, 01:53 PM   #235
Wow I forgot all about that I sold my scale setup station. I would have kept it all if I knew I would be back into R/C again. This is starting to become one heck of a nut.$$$$$$ ya know.
Marty
Old 05-07-2013, 02:30 PM   #236
Unfortunately the TC setup stations don't work so well on pan car style F1 cars due to the different axle size...but they do kinda work. The setup stations for pan cars don't work because they are setup for standard sized bearings and axles. I'd love to get an adapter for my Hudy pan car setup station that takes the metric bearings of the F1 car. It wouldn't be too hard to do because it is basically just a threaded insert that holds the standard bearings...would just need to copy that and size the ID for metric bearings.
Old 05-07-2013, 02:50 PM   #237
For me not so much the setup station as weighing speedos wings and all the parts to keep as much consistent when changing parts or setups.
It's always good to have a few postal scales around for facts Rather than it feels lighter....
Old 05-07-2013, 09:18 PM   #238
Rear wing issue was assembler ignorance. I settled on a 3 mm spacer. Side by side with the F1R both look exactly the same assembled.
Old 05-09-2013, 08:08 AM   #239
Drove this car for the first time last night. Smaller carpet track, lower traction (although it started to come up later in the evening).
I have only driven a couple different F1 chassis before, but I am very impressed with this SP chassis. The car never felt tippy, even when I doped full fronts with 2 deg of camber. I have driven a couple other F1 cars that would want to traction roll, even in lower traction conditions. I was using Pardus tires, fyi.
Mid to exit steering is lacking, but I still haven't tried many other spring options. The car has a surprising amount of initial cut; I just need to figure out how to get it to follow up and keep turning.
Some random notes:
- looks like tc springs fit the center shock. I tried an xray spring last night and it worked really well.
- AE side springs fit
- didn't notice a huge difference between the 5 and 10 deg caster options, but will test again tonight.
- I hate the front ride height adjustment on this car.
Old 05-10-2013, 06:02 AM   #240
I and a couple of the guys at the club turned some laps with the SP1 last night. It was just plain hooked up. It was a little doggy when coming off the corners, but I think that might be more to me trying to soften the bottom end to keep rear wheel spin under acceleration down. It didn't matter what front tire I had on it, the steering was there with no real push or understeer. It was nice to have such a neutral car to start making changes to. The only complaint was that for some reason the off power steering felt slow to one of our better drivers. That being said, fast lap of the night was around 13.5 and the SP1 with nothing done but add camber, shock oil, change to a horizontal servo and Associated side links ran a 13.7 fast lap with many 13.9s and 14.0s to back it up.
