Old 08-20-2014, 12:58 PM   #1186
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by JayL View Post
John: what's up with your Ti axle?
Puttering with a Pro10... I have the material, need to make a couple calls for machining.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 08-21-2014, 01:01 PM   #1187
List your whole setup. I had a similar issue and I put the whole ROBK setup posted in this thread and wow best car on the track now
Here is the setup only thing i didnt know was the front and side springs i am assuming stock front are gold, side are a chrome but do not know the rates on them.
tbamsey is offline   Reply With Quote
Old 08-21-2014, 01:23 PM   #1188
JayL's Avatar
Here is the setup I switched to and works super well, but you are running ride tires, I have never tried them we all run pit 571/572
http://www.petitrc.com/reglages/spee...Hours20130714/
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 08-23-2014, 10:41 AM   #1189
Thanks got the 1 car switched to that setup will try it out today.
Old 08-25-2014, 11:07 AM   #1190
It got a little better i think it is the tires causing the problems it seems like it floats down the high speed parts going into the hairpin turn not real stable at higher speeds its a beast on the lower speed corners ordered new tires will try this weekend
Old 08-25-2014, 11:19 AM   #1191
JayL's Avatar
Yep, that's been my experience with Ride tires, the car doesn't feel like it's 'in the track'
also another note:
I replaced the steel rear axle and the heavy off diff side optional 'Wheel adapter V2' with the stock parts and a Carbon rear axle, WOW punch and still as grippy and stable. Beat previous fast lap with the car by .4
Old 08-25-2014, 11:27 AM   #1192
antonio_cadiz's Avatar
hello!
friends, I need a softer spring for the rear shock any references to do well to shock. I need the reference number.
thanks you
antonio_cadiz is offline   Reply With Quote
Old 08-25-2014, 11:42 AM   #1193
Trader Rating: 18 (100%+)
I'm still having major issues with the front pivot balls and uprights. I'm not seeing that anyone else is dealing with the issue, so it must be my pivot balls. I've now tried many sets of the carbon reinforced and standard uprights - all are incredibly tight, and won't allow the steering to center, no matter what I do. I've had to resort to using a helicopter ball end reamer to free things up at while at the track - quite the pain in the butt on race day. Aside from this issue, I love the car - probably 85% dialed at this point.
I'm also curious how many people are running their shorty packs to the rear, and ESC's up front now. When I first built my car, it seemed that most people were opting for batteries up front, with the esc mounted in the rear of the battery area. My car has more steering than I know what to do with, so I'm thinking of making the change.
Sorcerer001 is offline   Reply With Quote
Old 08-28-2014, 09:49 AM   #1194
hello!
nobody changed to a softer rear spring?
Old 08-28-2014, 10:42 AM   #1195
JayL's Avatar
Nope, I run the kit spring
BUT, in my other F1's I run a softer spring, An Associated non bigbore front buggy spring the green one cut down
Old 08-28-2014, 09:43 PM   #1196
TryHard's Avatar
I've been running my car with Kit centre spring and front spring, and Tamiya gold side springs. Actually been very happy with the car recently. Since going to straight, rather than angled in side links, car has been much better, and the biggest change I made last time out was using a 3mm ackerman shim. Suddenly the steering is far more predictable and the car down right easier to drive... This is on Pit 571 front, Ride R1 rears.
I was going to try ditching the rack, and running a wiper style servo setup... but given how much better the car felt with more ackerman shims, never bothered!
Ed
TryHard is online now   Reply With Quote
Old 08-29-2014, 10:27 AM   #1197
JayL's Avatar
I was thinking of going laydown shorty servo,like the tamiya guys, but to put it far forward enough, for ackerman, it only has a small ledge of the front arm mount plate to sit on, not very stable.
Old 08-29-2014, 10:41 AM   #1198
fmm
Talking
Hi all,
Finally I build my car. After few hour playing around with the wires (between the esc and the motor) to make the fit with the body, I ended up in the layout of the photo.
Do you see any problems on this setting? The suspension seems to move freely, but I don't know if someone has tested it successfully or it might interfere the suspension.
Thank you very much in advance!
fmm is offline   Reply With Quote
Old 08-29-2014, 04:55 PM   #1199
TryHard's Avatar
I just cut the brace out of the arm plate so I could slide the servo forward whilst still on the chassis. If I can find some spare time after our state titles, I'll give it a shot.
Old 08-31-2014, 10:52 PM   #1200
also another note:
Will order those rear axle parts, my bone stock car i clipped the out side wall and did some damage well more like carnage
the one with 10 deg front end and steering upgrade started good First round tq 21 laps ride r1 all around 2nd round 17 laps with the pit tires could not apply any power car would just come around mains tried the tamiya 54198/54199 just couldn't put power down would come around. I went through car today couldn't find anything wrong with it nothing bent or binding.
one thing i noticed different on car with aluminum 10 degree block there are 3mm or so spacers on top of it and on stock plastic one they are under the plastic block i went through the instructions and could not find this in there anywhere is this something the previous owner did that is wrong i will try and get a picture of it tomorrow i am comparing both cars to the instructions and this is the only real difference besides ride height.
SEO by vBSEO 3.5.0
