Old 07-11-2014, 10:43 PM   #1156
zephuros's Avatar
Originally Posted by robk View Post
answers in blue
Hi Rob.
I'll go with the stiffer centre spring next. I'm liking this as the car is getting better each time I drive it. Also, I'm running it on a huge track used by 1/8 GP racers, and with my FDR down to 2.7:1 it's very very quick and stable.
Yes, the steering mod removes the slop in the plastic bell crank and servo link. I guess the SP ball cups on my car are a little worn which pronounces the slop.
Changing away from them has made everything nice and crisp. I'm now running tamiya soft rear springs and yokomo super soft fronts. Am going to experiment with changing those at the track tomorrow.
Thanks again for your help. Will update findings tomorrow.
awww bollox....
zephuros is offline   Reply With Quote
Old 07-11-2014, 11:45 PM   #1157
zephuros's Avatar
Hey Rob, here's a picture of the steering mod. Still playing around with Ackerman shims which explains the gap between the studs and servo horn
awww bollox....
Old 07-12-2014, 07:13 PM   #1158
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by blwaz23 View Post
I was wondering what are the positives and negatives of the SP1. What parts break the most and is there any brand that sells upgrades for this car. Last how well does this car handle stock and is it an easy car to tune.
No real negatives. Speedpassion has excellent option parts. There are currently no third party parts intentionally made for the car. The key is finding tires that hook up and a setup you can drive.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 07-12-2014, 09:03 PM   #1159
zephuros's Avatar
Agreed. And as I discover how to make best use of these parts the car seems to only get better. Sadly here in Malaysia we're stuck with using Ride R1s, which give excellent rear bite but the fronts are just a bit too hard for decent steering.
I just bought another SP1 kit for parts but have decided to build it up as a standby car instead!
awww bollox....
Old 07-16-2014, 07:06 AM   #1160
adriang79's Avatar
Drove my SP-1 for the first time this week, will post pics later.
The only pinion I had that would fit was a 19T, gave me 3.79:1. Rather be closer to 3.0:1, what is the biggest pinion I can fit with the standard 72T spur still fitted?
www.stmcc-hobart.weebly.com STMCC Secretary
Team Associated TC7 - Hobbywing V3.1 Stock spec -Team Powers Actinium 13.5
http://stmcc-hobart.weebly.com/rcmaker-tas-challenge.html
adriang79 is offline   Reply With Quote
Old 07-16-2014, 09:48 AM   #1161
Super Moderator
racer1812's Avatar
Trader Rating: 29 (100%+)
I'm in the same boat, I would have to double check but I think a 19 is about it, MAYBE a 20t. I know you'll need a smaller spur to get close to 3.0 (72 / 24 = 3.0) that will never fit.
Stop the hate! 'White Wheels Matter'
racer1812 is offline   Reply With Quote
Old 07-16-2014, 10:12 AM   #1162
Switch the rear spur to a Kimbrough 69. Then run a 21 to 26 pinion set.
I ran mine again last night at practice with very high grip and was running very good lap times. It felt like I was running foams. No odd kick out or under steer. I was trying to get a better scuff on my 571/575 tires and was what I would call extremely successful. I hadn't bothered to put in a PTX, so no idea what the times were. I was having a lot of fun so I was out with the car a good 20 minutes. The car was great everywhere. The only recommendation I got was to take a couple teeth off the pinion. I'm at 69/26 at the moment. Car wasn't hot, timing was good on the Trackstar 21.5. The theory he said is move the working power band down. It should generate similar lap times and use less battery doing it, but I may have to detune it a bit if torque is too high. I'll give this a try next time around as we ran out of time. Just as a background everyone at our track has a tendency to overgear the motor to make it more linear in feeling, so that's what I did. I personally think that regearing to 2.8 to 3.0 will be a good thing.
Happy motoring!
Old 07-16-2014, 10:26 AM   #1163
I did that with my LM-1. Now I have spares for years, 2 LM-1s and an SP-1. Last hopup is here, Alu servo bracket!
Time for custom parts! Just ordered a 6mm x 1m titanium rod ($75 US shipped). Time for some custom rear axles. One option is to cut it to the length of the carbon axle and drill out the pin hole for the inner hub. I just need the ends of some carbon axles that have been broken. The other option is to take the steel axle in and have the machining duplicated for the threaded end on the titanium rod and have the pin hole drilled for the inner hub. This will use a lot more stock. I should have enough stock for 5 or 6 and some scrap either way (extras!). I'm then switching to the Qtec left clamp hub. I have never trusted set screws. I don't like dimpling carbon axles, they always dig in and split or go loose on me. I'm running one of the clamp hubs on my LM-1 graphite axled car and wouldn't go back. I'll post the cost back and which option made the cut.
Old 07-16-2014, 06:40 PM   #1164
zephuros's Avatar
Titanium axle!!! That will rock for sure. I've bent yet another steel axle and I'm not too fond or the carbon ones. Let me know how it goes with this one. I might need to do some experimenting of my own. How does the Qtec hub clamp down on the shaft? Never seen one of them.
awww bollox....
Old 07-16-2014, 07:04 PM   #1165
I use the Q-Teq hub on my SP-1...really like this hub. I then space out the hubs to get to 190mm rather than adding spacers inside the wheel.
Q-teq hub found here:
http://www.reflexracing.net/QTEQ-Tam...ack_p_995.html
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 07-16-2014, 07:22 PM   #1166
Like a collet. It has a 6mm inner diameter with 4 equal splits/cuts @ 90*. It has a progressive threaded pattern that rises from the edge of the collet. The clamping nut has the same angled threading and as it is is tightened, it compresses the split sections onto the axle. The tire slips over a mounted titanium bolt, not aluminum. The compression nut is 12mm.When completely clamped down I get just under 1 mm sticking out from the hub past the compression nut.
In the pictures you can see the slots. The taper starts at about 8mm and ends at around 7mm. (Too lazy to grab a calipers). These come in black, blue, gold and silver. The examples are from Banzai Hobby in Japan. If you can wait for your order, this place is a bargain. Shipping international can take up to 30 days now unless you order Speed Post which wipes out the bargain.
Clamp Hub, 5.5mm spacer, .5mm of shims = dead on for a 185 car.
Old 07-16-2014, 07:25 PM   #1167
+1 best way for sure!
Old 07-21-2014, 08:07 AM   #1168
zephuros's Avatar
Looks great. I think I might pick one up the next time I do some online shopping. Bent a rear axle today so I'll be needing one of them too. It was so badly bent that it stripped my Xenon spur down completely. Sigh.
awww bollox....
Old 07-22-2014, 10:37 AM   #1169
Super Moderator
racer1812's Avatar
FYI, I was wrong. I have a 22t on mine. Might fit a 23t but that would be about it.
just wanted to correct my bad info.
Old 07-25-2014, 08:55 PM   #1170
adriang79's Avatar
I managed to squeeze a 23t onto it, but certainly won't fit anything more than that.
My motor mount is currently with a friend who has a milling machine to have the motor screw holes made a little bit longer, hopefully fit another tooth or two on the pinion.
