Old 03-04-2014, 12:04 PM   #1006
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by JayL View Post
the rear axle crescents:
for pit rubber tires do they go at the top or the bottom?
That depends on what ride height you want. Try different ones in the two orientations until you reach your desired height. I believe mine are "upside down" to get 4.5mm.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 03-04-2014, 06:06 PM   #1007
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Bottom for rubber tires, top for foams.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 03-04-2014, 06:24 PM   #1008
j.d.roost's Avatar
Trader Rating: 27 (100%+)
Looking to get 4mm f/r ride height with pit rubber tires.
Before I spend a few hrs. searching the thread...can someone please share their front and rear spacer settings? Most important is the front kingpin/shims under the lower arms.
Thanks in advance for the help.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-04-2014, 06:36 PM   #1009
hanulec's Avatar
Trader Rating: 23 (100%+)
i think we want this--
http://www.rctech.net/forum/12804462-post825.html
this sounds important too--
http://www.rctech.net/forum/12971489-post931.html
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-04-2014, 06:44 PM   #1010
Trader Rating: 29 (100%+)
If anyone is looking for a SP-1 I have mine for sale.
For Sale Speed Passion SP-1 F1
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 03-04-2014, 07:12 PM   #1011
j.d.roost's Avatar
Originally Posted by hanulec View Post
F1
Roche usa
R.I.P. Jon Williams
Old 03-05-2014, 06:13 AM   #1012
j.d.roost's Avatar
Originally Posted by InspGadgt View Post
I don't remount my servo...it is glued to the chassis with shoe goo and I just use some thin double stick tape on the sides for support. I just peel the mounts off and move them up or down with the plate. To me it is much easier than fussing with the bell crank height every time I want to change ride height. How often do we change ride height anyway? Once we get it set we pretty much don't touch it again unless we switch brands of tire.
Everything moves together when you move the plate with the servo mounts so you don't have to change a thing on the upper arms. If you change the ride height using the arms you then would need to re-shim the upper arms as well since only the front upper arm mount moves with the arms.
For me moving the plate with servo mounts is a much more logical system since the whole suspension moves together. What SP should have done was tie the rear upper arm mount to the plate instead of the servo mount...then ride height adjustments would be very straight forward.
Just got done building a roller. With the stock settings the front sits like a monster truck with rubber tires.
Trying to get the front under 4mm ride height is going to take a bunch of shims.I was worried about using more than 4mm under the arms or 3mm under the knuckles...as I am not sure what it does to the upper arm geometry. Shimming the plate seems like the most logical approach. EVERYTHING. .gets moved but the servo.
I assume you shim the backside of the servo holder the same amount you shim the plate?
Also.. will I run into any issues with the servo horn being " too low" now that everything else is that high off the chassis?
F1
Roche usa
R.I.P. Jon Williams
Old 03-05-2014, 10:15 AM   #1013
Yes I shimmed all 6 screw locations under the plate and the back of the servo mounts. I moved the ball stud in the servo horn up to the top hole to compensate. The trickiest part is the screws under the bell cranks...you've got to find just the right length so they don't hit the bell cranks. Pit Shimizu tires are easier to get the ride height down...Pardus tires are much taller. So depending on what tires your running will affect how much shims you use.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 03-05-2014, 02:44 PM   #1014
j.d.roost's Avatar
Ok great.. I assumed I was going to need the upper hole on the servo horn. I will be running pit tires.Will keep an eye out for the bell crank snafu. Thanks for the help.
F1
Roche usa
R.I.P. Jon Williams
Old 03-07-2014, 04:10 PM   #1015
metalnut's Avatar
Alright guys, I need spur gear advice once again. I've been using Xenon VSS spur gears but I have two problems
1. They're too tight when inserted over the axle, so I've been having to sand the inside to make them smooth. This is a less-than-perfect process.
2. Superior Hobbies is basically out of stock on the range I've been using, I can't find any other good supplier
So, in 64p, what gears are you all using. I'm sad to say that the new Exotek spurs don't fit the SP-1 axle properly, there is a TON of slop.
- Ricky Bobby
Old 03-07-2014, 04:17 PM   #1016
Trader Rating: 57 (100%+)
I put a xray pancar spur on mine. Fit perfect.
PROMODVETTE is offline   Reply With Quote
Old 03-07-2014, 05:32 PM   #1017
JayL's Avatar
When are replacement front uprights coming???? Of any type......
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 03-08-2014, 03:42 PM   #1018
big_ads's Avatar
Trader Rating: 74 (100%+)
Send a message via MSN to big_ads
I am wondering that also. I broke one today and am supposed to go to a race out of town next weekend. Can they be replaced by another brand even?
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Team Genesis R/C Products - Motiv R/C - Big Head Racing - Team PRCP
big_ads is offline   Reply With Quote
Old 03-09-2014, 09:07 AM   #1019
hanulec's Avatar
thanks to JD for helping finish my build, and Dan Garber of Speedwerkes for helping me get a lot of the parts/body/tires. after only a small build failure and stripping the too small ball stud on the servo rack this car went on to TQ (+ fail -- traffic) against a big batch of F1 racers all working towards TCS @ Horsham RC yesterday.
car drives really nice. just not sure if i'm going to keep the steering rack, or go to a more traditional servo saver design.
Old 03-09-2014, 08:54 PM   #1020
metalnut's Avatar
Do you mind posting your setup?
- Ricky Bobby
SEO by vBSEO 3.5.0
