Old 02-13-2014, 05:58 PM   #961
Trader Rating: 17 (100%+)
Can anyone tell what what the front stock spring is close to when using associated springs? Also I have Tamiya rear side springs, which one would be close to the stock side spring? I got the car second hand in a trade and did not come with the stock front springs or rear side springs. Any help would be great, Thanks!
429racer is offline   Reply With Quote
Old 02-13-2014, 07:35 PM   #962
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by TryHard View Post
How many shims are you running under the steering posts? I was looking at this the other night, trying to figure out a way to make the steering links flatter. Settled on flipping over the bell cranks, and putting 3mm under the posts, as well as running the drag link underneath the rack (so as to keep the longest servo horn length). Links did look a lot better this way, IMO.
I have 3 mm under the posts right now. I cut the middle out the center plate and run my servo horizontal. No clearance issues at all, steering is still balanced and very smooth.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-13-2014, 08:06 PM   #963
BadPanda818's Avatar
Is there any updates on when the steering uprights will be back in stock. I broke my left one at TQRC and luck would have it, I found a pair all the way on the land down under (Australia). I see that most of the spare parts are easily attainable except for the upright. I've read this whole thread and didn't seem to come across steering upright shortage. thanks
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
Old 02-14-2014, 05:04 AM   #964
TryHard's Avatar
Thanks for that John... had a play around tonight, and ended up going a slightly different route on the servo.
http://www.thard.co.uk/sp1-steering-setup/
Old 02-14-2014, 05:37 AM   #965
Love the write up! The reverse mounting of the ball stud is perfect and flipping the uprights gives you a nice lowering effect on the steering arm ball stud. And I too will fiddle with the steering link to get my car to turn left and right at the same rate without jacking with the left or right end point on the transmitter.
Old 02-14-2014, 05:47 AM   #966
Stock front spring is pretty good, might want to try the AE .22 or .20. Side springs I would say are close to the AE 5.00 lb 12R5.2 kit springs, pretty stiff, and you'd want to go a step or 2 lower in the stock position. If you use the wide carbon brace and mount the springs outboard, get the 3.75 set.
Old 02-14-2014, 11:18 AM   #967
Hi, I have a huge problem with this car, my problem is that in fast corners the car seems like they do not step on the front. That I can do to fix this?. Thanks and sorry for my poor English
topansky is offline   Reply With Quote
Old 02-14-2014, 01:18 PM   #968
robk's Avatar
Trader Rating: 22 (100%+)
Front springs are like a tamiya silver or ae .016. I'd try tamiya silver side springs
Old 02-14-2014, 05:19 PM   #969
No steering or too much steering? What tires are you running and on what surface?
Old 02-14-2014, 06:11 PM   #970
Thanks Rob and Liljohn.
Old 02-15-2014, 07:17 AM   #971
The wheels are used front and rear ride s1. The track has little grip and asphalt. The problem is that in the fast corners the car, gives the feeling that the front wheels do not support and tends to understeer
Old 02-15-2014, 09:46 AM   #972
OK, more information.
What is camber, caster, front spring rate (hard, medium or soft), side spring rate?
Usually an on power push at initial turn in is too much front spring, not enough camber or too hard a tire.
Old 02-16-2014, 01:15 PM   #973
Caster angle 10
Camber 0
Toe 0
The front spring is the standart, and placed with factory setup
Old 02-16-2014, 03:01 PM   #974
Caster angle 10
Camber 0
Toe 0
Add camber 1 to 1.5 degrees. Try a known good set of front tires from a friend if possible.
Old 02-16-2014, 03:33 PM   #975
metalnut's Avatar
Trader Rating: 36 (100%+)
I've been thinking... do you guys add weight to the front of the SP-1? I have a Juststock ESC in the back and a shorty up front, almost right against the servo plates. The car is VERY light in the front, though. Do you guys add weight to try to achieve more 50/50 weight balance?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
