Old 01-28-2014, 03:50 PM   #916
Trader Rating: 57 (100%+)
I feel the only upgrade this car needs now is an aluminum steering upright set. Even the carbon ones are pretty horrible as far as that plastic nut threading into it.
PROMODVETTE is offline   Reply With Quote
Old 01-28-2014, 07:59 PM   #917
metalnut's Avatar
Trader Rating: 36 (100%+)
My complaint about the uprights is that they split right at the top, so the top of the hole that you screw the pillow ball retainer into. I've had 3 crack there, and unless you notice it, the ball will pull out on the next hit.
The only thing I don't know is if was the original plastic or the carbon plastic that did this. I have both and I mixed them up in my box. I think it may have been the regular plastic, but I would think that the carbon would crack easier?
I'd probably buy an aluminum set.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 01-29-2014, 10:22 AM   #918
Solara's Avatar
Trader Rating: 16 (100%+)
Is that where it crack...? please confirm....
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-29-2014, 10:25 AM   #919
Solara's Avatar
Aluminum upright does not work because there is a king pin screw in into the upright. To keep that pin tight you might need to use lock tight for that pin and using lock tight in that pin is NOT a good idea because it has the suspension travel on it.
I am re-doing the solid work of the block and beef it up to about 0.2mm around the whole ball cup area...but I would like to see exactly where others are cracking it at....I need the actual spot that where it crack, at least from those who cracked the block I want to know mainly from which spot....
Old 01-29-2014, 02:57 PM   #920
metalnut's Avatar
Yes! That is precisely the spot!
- Ricky Bobby
Old 01-29-2014, 03:22 PM   #921
coxbros's Avatar
That is the spot..please please fix it!
coxbros is offline   Reply With Quote
Old 01-29-2014, 11:47 PM   #922
I've had 3 right-hand ones crack like that
Ian_R is offline   Reply With Quote
Old 01-30-2014, 04:35 PM   #923
jrp
jrp's Avatar
Trader Rating: 17 (100%+)
Default Fragile...
car is good except for those pillow-ball spindles. I have been cracking them like they are made of glass. Just about any tap with the wheels turned nets a broken front-end. I'm at the Snowbirds now and am on my last one. If it breaks, then the SP-1 will be retired...
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 01-30-2014, 05:19 PM   #924
How soon could we see new uprights?
429racer is offline   Reply With Quote
Old 01-30-2014, 05:28 PM   #925
I had one of the original plastic ones pull the ball right through the upright. After I replaced that I haven't had a problem since. I'm still running the older plastic ones. With all these new stiffer and stronger aluminum parts I figure the front end needs a little give somewhere or it will keep breaking.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 01-30-2014, 09:23 PM   #926
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Jimmy,
When are they running the mains?
I can express you a Tamiya front end down there that will bolt on to the SP1 until we get this problem resolved
Let me know
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 01-30-2014, 09:51 PM   #927
Solara you could use aluminium for the steering blocks. If you are worried about the king pin backing out, use a grub screw through the threaded portion of the axle insert to pinch the king pin.
ryeman is offline   Reply With Quote
Old 02-03-2014, 09:16 AM   #928
Solara's Avatar
hmmmm, that is possible....good idea.
Old 02-03-2014, 09:36 AM   #929
I would think then you would want/need an insert of some type, on the backside, for the pivot ball to rotate against to prevent galling/sticking as the chrome plated pivot ball rotates against the softer aluminum.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 02-03-2014, 09:38 AM   #930
Solara's Avatar
Congratulation to Fernando Gordinho and Jim Piersol to bring the SPEED PASSION SP1 F1 to the A-main of Snowbird....well done guys.
SEO by vBSEO 3.5.0
