Old 11-28-2013, 08:12 AM   #781
zephuros's Avatar
Now that the carbon reinforced bits are available I guess this is gonna seem silly, but I managed to stiffen up the standard side links pretty damned easily.
Cut out a piece if lexan about 15mm shorter than the side link and about 4 mm wide. Using CA, glue it down the side link. I tried this and it bloody works like a charm haha. No option parts available in Malaysia just yet so this was a cheap and nasty but quick fix.
http://www.flickr.com/photos/22860269@N07/11096007974/
awww bollox....
zephuros is offline   Reply With Quote
Old 11-28-2013, 09:27 PM   #782
adriang79's Avatar
So my SP1 arrived this week, started building it today.
Anyone had any trouble with the 5mm Pivot balls in the 1st step? Mine seem to have about 1mm of slop when I tighten up the 3x6mm Flat head screws, even split a pivot ball trying to tighten it.
www.stmcc-hobart.weebly.com STMCC Secretary
Team Associated TC7 - Hobbywing V3.1 Stock spec -Team Powers Actinium 13.5
http://stmcc-hobart.weebly.com/rcmaker-tas-challenge.html
adriang79 is offline   Reply With Quote
Old 11-28-2013, 09:32 PM   #783
nrtv20's Avatar
It seems as though when they stamped the hex in the pivot balls it crushed the threads. I cut down my screws or you can use associated pivot balls. I started to drill and tap them but it's tough, only did 2 and gave up.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 11-28-2013, 09:39 PM   #784
adriang79's Avatar
I best use the 5mm screws I have for my TC6.1 then. Thought it was to do with the hex in the top
Old 11-28-2013, 10:04 PM   #785
metalnut's Avatar
Trader Rating: 36 (100%+)
Those stock pivot balls are complete garbage. Do not waste your time. Get the AE ones I recommended earlier in this thread.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 11-28-2013, 10:07 PM   #786
If you want to use the kit pivot balls, buy a tap, and clean out the threads before use.
Shawn.
Shawn68z is offline   Reply With Quote
Old 11-28-2013, 10:17 PM   #787
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
anyone after a SP f1 kit ?
i have one kit wan to let go...usd150 shipped..
Kit + shell + 1 set of used Ride tyres Preglued.
+ 2 nib pair arm, 1 nib knuckle
condition of the car is 8.5/10
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-29-2013, 12:46 AM   #788
adriang79's Avatar
Would they be Part #: 4637 ?
Old 11-29-2013, 01:28 AM   #789
zephuros's Avatar
ye... i raised my sde links slightly with a 1mm spacer underneath them, and then used the standard kit pivot balls... that worked well too...
awww bollox....
Old 11-29-2013, 06:11 AM   #790
Yes, the swedging process to create the hex is the culprit. You can use a 3x5 FHS for kit build or 3x6 with a 1mm shim to lift the side links. Or, as mentioned, swap out for Associated. The football will have the same issue.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 11-29-2013, 06:38 AM   #791
zephuros's Avatar
Has anyone experienced the car turning in nice and sharp into a corner and then feel a little wobbly through and out? I seem to be experiencing that now. Unsure if it because of the side links or something else. Too much slop maybe? I run on med grip asphalt with a Ride R1s.
awww bollox....
Old 11-29-2013, 09:30 AM   #792
metalnut's Avatar
Yep, those are the ones.
- Ricky Bobby
Old 11-29-2013, 09:37 AM   #793
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by InspGadgt View Post
Awesome...adding them to cart now...no front pivot balls yet?
Burt,
Just saw your post. I actually have the pivot balls, I just haven't listed them on the store yet. Your package is on the way already otherwise I would have included them
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 11-29-2013, 11:55 AM   #794
No problem Brad Thanks for the fast turn around!
Old 11-29-2013, 11:58 AM   #795
I've ran into the same problem with the AE ones. I had to tap those as well. Get yourself a 3mm tap anyway...there will be other times you will need it. The 3mm locknuts that I have seen from several brands lately have the nylon ring too small so they spin when trying to tighten down the football...just run a tap through those too and you will find assembling the car to be much easier.
