Old 05-28-2013, 05:06 PM   #346
Originally Posted by stonely0 View Post
Wow!!! I'm worried now when i saw this after just placing my order for this kit. I'm not a racer so do i need to do all the above modification? Does this kit even run decent assembling them as per the instruction guide without mod straight out of the box?
Don't worry...the kit goes together very well so you shouldn't have any problems. Since you are not a racer you don't need to be concerned with the modifications outlined by Solara. Those are mainly for racers who are racing with Pit Shimizu tires and are restricted to 190mm in width. The Pit Shimizu tires are slightly wider in off-set then the older Tamiya style tires so they push the car out to 192mm wide which will not pass if the race is a stickler about rules. The only thing you will want to take note of is the spacers for the rear wheels so that the rear is the same width as the front. Without the spacers the rear comes out more narrow than the front.
Old 05-28-2013, 10:32 PM   #347
Hi may i know which spacer you are referring to? The instruction manual does not say putting any spacer in the rear wheel axle. There are however 2 spacer (5x7x0.5mm) each side for the front wheel.
stonely0 is offline   Reply With Quote
Old 05-28-2013, 11:19 PM   #348
There is a small amendment sheet somewhere in the instructions that show them. The kit doesn't actually come with the spacers though so you'll want to find some of your own. The spacers they show go between the wheel and the hub though not on the axle. Personally I put spacers on the axle instead but I also changed out the left side hub to one I really like a lot so I'm not sure if axle spacers would work with the stock hub.
Both the manual and amendment are on Speed Passion's website here:
http://www.speedpassion.net/us/produ...SP000282&c=CAR
You'll need to create an account there and then click on the link. Or create an account and go to the SP-1 page and you'll see the download tab there.
Old 05-29-2013, 06:27 AM   #349
Trader Rating: 29 (100%+)
I had a little bag with 4 spacers in my kit, along with the amendment to the instructions. I'm thinking the spacers made it in some kits and not others.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 05-29-2013, 07:59 AM   #350
Trader Rating: 15 (100%+)
Hey Solara, do you know how long it will be until the US Speed Passion warehouse has more spares in stock? Right now I can only see the damper tube and rear axle as spares on the international website, where everything is significantly more expensive...
For instance, the body post set is $3.99 on the US website but $6 on the international site.
I had a traction roll about a week ago that resulted in pretty severe damage to the car, so I have since been trying to track down the following:
- bodypost set
- rear axle assembly
- damper tube
Anybody know where I can get these parts to get my car up and running again?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 05-29-2013, 11:26 AM   #351
b20btec's Avatar
I need a rear axle too, mine came bent from the factory. I have a races back to back and can't even get it on the track.
b20btec is offline   Reply With Quote
Old 05-29-2013, 11:47 AM   #352
I have 1 kit in stock right now I'll break open if you guys want parts right now.
Feel free to pm me to work out details.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-29-2013, 03:05 PM   #353
Solara's Avatar
Trader Rating: 16 (100%+)
- bodypost set
- damper tube
As much as I wish we can supply the parts for our customer, the demand and supply from us is just not catching up....sorry.
However, there is a solution....to be honest, our car, will fit almost most of the parts from Tamiya F104....in your case, body post set...you can use anything from anyone. I used a Team Magic one that I ordered from A-main for like the same price....but it does come with a body flapper that I like it very much. The Damper Tube.....F104 one will work. You can get that from TQRCRacing or F1Paintshop. Or...upgrade to the real oil damper like the AE 12R5 one. I think someone on the thread did that, please check 2-3 pages back there is a red version Tresery SP1 used a blue oil side damper (I am not sure that is a AE version or the Tamiya version).
Rear axle....please contact our office via phone 1-888-928-1328 and contact Albert and request the axle parts and he will be able to take care of the parts. We do have some of the axle parts around but they are not listed on the website. Call the office and he will handle the parts ordering separately.
Thank you everyone for the input....
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-29-2013, 03:08 PM   #354
Solara's Avatar
Please contact our office 1-888-928-1328 and talk to Albert and explain your situation....we will send the replacement parts under the warranty.
Old 05-30-2013, 04:42 AM   #355
b20btec's Avatar
Old 05-31-2013, 08:36 AM   #356
Trader Rating: 14 (100%+)
anybody know where i can get a left rear bulkhead? Mine bent last night in a light tap on sweeper off.
www.5280Raceway.com | Racing. Elevated.
samsking is offline   Reply With Quote
Old 06-01-2013, 09:28 PM   #357
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
SP1 parts arrived today, while I dont have everything that you are all looking for, what I have I have good quantities of
http://f1paintlab.mybigcommerce.com/spare-parts-1/
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 06-10-2013, 02:28 PM   #358
b20btec's Avatar
Still waiting on my axle. It didn't make it in time for my UF1 race. Ran that sucker anyways. I do like the car but may swap back to f104 due to parts support. Tamiya fits with a little trimming.
Old 06-12-2013, 12:55 PM   #359
Trader Rating: 21 (100%+)
This is a good little car for the price.
At first I thought the stock front end was pretty trick. But then when I started looking it over and over for the tire set up. I started to not like it very much. The front wider then the rear even with the 190mm setup. The guys at Speed Passion need to sit down and revise the kits for the US. Include all the shims needed for it to be 190mm...
I got rid of the front end just because it turned out to be too complicated. I added a f104 front end with hopups from an f104 I bought. Just for simplicity.
Parts from the f104 will work. Ive gotten away with using a 3racing dampner, Ive put a Tamiya ball diff/axle in there and it worked. It just wasnt track tested. I dont think any of f104's motor mounts will work.
RS_ZACH is offline   Reply With Quote
Old 06-12-2013, 01:28 PM   #360
Can you list out the parts from F104 front end, please?
I'm just waiting for my stock front suspension to break, to get the f104 set.
nicholasxuu is online now   Reply With Quote
