Old 05-20-2013, 12:20 PM   #286
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by Solara View Post
Spare parts are online right now...and will be ready by TOMORROW.
Very cool! Thanks.
John Higgins
liljohn1064 is online now   Reply With Quote
Old 05-20-2013, 12:48 PM   #287
Lloyd it's definitely tires. I had 2 on the track here in Washington with 2 entirely different setups and both were very good. We have mostly V2's for locals. Both cars being run mostly stock with just tuning changes. Pit 571/2 tires full sauced. Got a little time on the Pardus tires in the am but time was an issue and missed a full run them in the PM when grip and temp was up.
As Solara said throttle input off the turn is critical until you get the car squared up. I have sold 4 cars now to drivers for our upcoming asphalt series with another who I think tipped over the edge this weekend.
I ran a v2 also yesterday prepping for TCS and just couldn't get it as smooth as my SP-1.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-20-2013, 01:48 PM   #288
Ericjooopuntnl's Avatar
Originally Posted by LloydLoar View Post
Is this just a case of running the wrong tires? We were trying Trinity Tire Tweak as traction compound...maybe that played a role?
I ran all weekend on asphalt and the only thing i needed was front-grip, the rear was planted with Ride-tires and Tire Tweak. I understand the Pit Shimizu are great!!
Ericjooopuntnl is offline   Reply With Quote
Old 05-20-2013, 02:46 PM   #289
On the lower rear pod plate there are 2 countersunk holes that nothing mounts to in the instructions. They kind of remind me of the mounting holes for the diffuser on the CRC Gen Xti...so I'm wondering if that's what they are for?
Old 05-20-2013, 03:13 PM   #290
same here, local expert taught me to use no preload on side springs, and reduce droop in the main shock (still too much droop with the shortest ball cup).
TLR 22 | FGX | XI DH | TS4 | EB48 | DESC410V2 | SP-1 | DEX410V3 | DESC210
nicholasxuu is offline   Reply With Quote
Old 05-20-2013, 03:44 PM   #291
Solara's Avatar
Look couple page back for what I did on the side link...I use the most outside hole for the link and drilled a new one in between the front 2 holes and toe in the link for the outdoor setup....
I let the side pot spring sits on top of the carbon fiber and use longer screw. just look back couple pages for all the image.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-20-2013, 03:47 PM   #292
Solara's Avatar
I have zero complaint about the Pit Shumizu/TCS tires that I have....however, from what TQ RC Racing site, it said the TCS tires suppose to be the same as the Pit, but it said the TCS tires are HARD rear and SOFT front...? Is that right..?
I remember when I was racing F103 with rubber tires running RIDE or Pit, they were already HARD front and SOFT (super soft sometimes) rear...
If TQ is correct and if TCS is really HARD REAR and soft front...that is really weird then (possible the insert made the different?) but no matter what, the outcome yesterday with the TCS/Pit was AWESOME...car was on rail.
Old 05-20-2013, 03:59 PM   #293
Solara's Avatar
After yesterday racing, the setup that I posted couple page back is very good on prepped track....my equipment was Reventon PRO with STOCK0 software placing at the back of the car, shorty Speed power lipo the most forward position. MMM 21.5 with yellow board at 36* timing...gearing from 19/72 start, ended up 25/72 and motor was 140* after 6 minutes 90* track temperature.
And overall result...Just need a little bit more turn in. I only sauced the inside edge of the PIT and PARDUS tires (full at rear)...and I am sure couple things I can do, I can add 0.5* more camber, toe out 0.5* more, possible 1 level lower of the softer spring....but overall, I think I will set the dual rate HIGHER first...the easiest fix..LOL.
Old 05-20-2013, 04:56 PM   #294
I'm not talking about the holes in front where the links connect...on the back of the pod to the left and right of the balance/center-line hole
Old 05-20-2013, 05:00 PM   #295
robk's Avatar
Trader Rating: 22 (100%+)
Pit's nomenclature is weird and doesn't really reflect the tires hardness in reality.
Old 05-20-2013, 07:23 PM   #296
Here's the holes I was talking about:
Old 05-21-2013, 04:01 AM   #297
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
The explanation that has been made to me on the Pits is that there are 2 compounds, 1 and 3. The soft, hard, medium refers to the sidewall stiffness. The TCS tires are the 571/572 combination that has been popular in the UF1 series in California
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 05-21-2013, 08:21 AM   #298
Solara's Avatar
Thanks Brad...that explains it. Beside, the 571/572 combo, the rest of the shore are much cheaper...
Does anyone know the PIT tires, are they only work with the Tamiya FOAM rims? Do they work with those regular rim with ribs?
Anyone tried the SWEEP TIRES yet..?
Old 05-21-2013, 08:44 AM   #299
Solara's Avatar
Those are for the upcoming underbody air diffuser....option parts. And you are correct on that...
Old 05-21-2013, 09:16 AM   #300
NutDriver's Avatar
Trader Rating: 14 (100%+)
I had read that there were issues with the Sweep F1 tires not performing up to expectations that the rears, especially, didn't provide enough grip. I had also read that Sweep was addressing the issue. Unfortunately, I can't recall where I read it. It may have been on the Australian RC F1 site.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
