Old 05-11-2013, 10:11 AM   #256
theatriks's Avatar
Does the UF1 series keep track of constructer wins .....meaning to they have a stats page to show what companies cars are winning the most ....I.E tamiya, speed passion , vbc, kyosho, yokomo....etc
Mod Mod Mod...I love Mod.....and scotch!
theatriks is offline   Reply With Quote
Old 05-11-2013, 02:02 PM   #257
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
The chassis with the most wins in the last 2 years is the Exotek F1R.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 05-12-2013, 12:26 AM   #258
Hi guys, what's the biggest spur and pinion I can use without changing stuff other than spur and pinion?
local F104 guys use something like 36t/92t pinion/spur. While biggest pinion I can use is 23t.
TLR 22 | FGX | XI DH | TS4 | EB48 | DESC410V2 | SP-1 | DEX410V3 | DESC210
nicholasxuu is offline   Reply With Quote
Old 05-12-2013, 01:54 AM   #259
Drop to a smaller spur and you can fit much bigger pinions. On my F1R I ran a 78t or 80t 64p spur. I believe I put a 78t on my SP-1.
InspGadgt is online now   Reply With Quote
Old 05-12-2013, 02:30 PM   #260
Originally Posted by InspGadgt View Post
Just ordered me the Qtec clamping hub for the F104 for my SP-1...with that I should be able to use axle spacers to widen the rear instead of the washers in the wheel.
Originally Posted by liljohn1064 View Post
I'm so... dense sometimes. I have a couple of those too, NOS from my F103 parts box and one of the 3Racing F104 in my current F1R spares box.
My Qteq hub came in yesterday so I've been messing around with getting the right spacers for the axle. I found with the fat old F103 rear bearing and the thin F104 rear bearing put me within .5mm of the stock left side hub + spacer + 2mm spacers. I had some old blown out bearings from my F103 and F104 days so I just used the inner races as spacers.
Old 05-12-2013, 06:58 PM   #261
I think I'm going to try to get a hold of some of this tubing and use my small diameter tubing cutter. http://www.hobbylinc.com/htm/k+s/k+s9806.htm
John Higgins
Old 05-12-2013, 09:12 PM   #262
That'll work so long as your tube cutter cuts square...I don't trust myself cutting that by hand. Although I did see an arrow shaft cutting jig I was thinking on getting for archery which would do that quite nicely.
Old 05-13-2013, 07:54 AM   #263
The tubing cutter is from my garage tools for making new brake/fuel lines. It cuts very square. It would work for archery shafts too. You just have to use a deburring tool to clear the end. You just have to be careful and cut slowly so you don't pinch the tubing. I've already used mine to cut a CRC torpedo tube to make a custom length short damper.
John Higgins
Old 05-13-2013, 09:47 AM   #264
Solara's Avatar
I think I should share some of the work that I did about 3 months ago on this car that we are going to make option parts on...and some idea about what I think it will make the SP1 handle better on outdoor....since we are not running indoor anymore until winter, so outdoor setup is what I am chasing after...
I will provide some data about using Pit Shumizu, TCS rubber, Tamiya stock rubber and Pardus rubber tires specification and setup on the SP1 soon. The only tires that I cannot provide info are the new RIDE, they are all coming with +3mm offset rim and that made the width way wider then 190mm that would not be legal in USA racing.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-13-2013, 10:48 AM   #265
Ericjooopuntnl's Avatar
With the Ride-tires the front width is indeed 195mm, 10mm more than a legal F104, the rear is 190,5.....only 0,5mm wider than a F104 with Ride-tires.
I'm currently working on a F104 front-conversion on the SP1 with the use of the upperarms and wheelhubs of the SP1. Unfortuanally the great steeringrack has to go to make the car ETS-legal.....
I will post a picture when it's done.
Ericjooopuntnl is offline   Reply With Quote
Old 05-13-2013, 05:25 PM   #266
Solara is one crazy dude. That is a lot of work!
John Higgins
Old 05-13-2013, 11:19 PM   #267
Old 05-14-2013, 01:34 AM   #268
Ummm yeah...no...lol That would crack my carbon arrow shafts
Old 05-14-2013, 06:42 AM   #269
Very true. I still have oversized thin wall Eastons. no overdraw. I'm about 10 minutes from Little Jon's Archery World.
John Higgins
Old 05-14-2013, 06:54 AM   #270
I measured my front and rear as assembled just for giggles.
185mm rear with no washers or spacers. Front was 186mm with 2* negative camber measured at the top of tire.
The Front was 196 with 2* negative camber measured at the very bottom of the tire.
The car is approximately 190mm up front with 0* camber.
I'd rather put a 2mm spacer on the diff side axle, a customer length spacer on the other and a clamp hub to get to the right width. Messing with shims inside the wheel just doesn't suit me. Else I will narrow the front to 185 mm as I don't know if the camber adjustment will make the car illegal width. I'm not going to run it @ 0* camber.
John Higgins
SEO by vBSEO 3.5.0
