Old 04-24-2013, 03:48 PM   #166
Just wondering how the Pardus tires work outdoors?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay.
BullFrog is offline   Reply With Quote
Old 04-24-2013, 05:27 PM   #167
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I have not run them outside yet, but they were originally designed for asphalt, so they should be good. Of course most tires have a temperature limit, and I am not sure what that is for the Pardus tires
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 04-24-2013, 05:40 PM   #168
Originally Posted by robk View Post
The crc 1/12 front end is very similar...its possible their pivot ball retainer may fit if you have ruined yours.
Originally Posted by liljohn1064 View Post
I can check tonight when I get home.
Its possible but not likely. The SP-1 is predominately metric where the CRC cars are all standard. The threading is not likely to match.
Old 04-25-2013, 05:03 AM   #169
Zedsispeho's Avatar
I thought that metric was standard and imperial was not for most countries
3 Racing FGX, 21.5T sensored + Esc Hobbyking 80A Turbo.
Team Saxo F1-180 21.5T sensored + Esc Hobbyking 80A Turbo.
Yokomo YRF001 13.5T sensored + Esc Hobbywing 80A Turbo.
Zedsispeho is offline   Reply With Quote
Old 04-25-2013, 11:19 AM   #170
We don't call it imperial in the US...we call it standard
Old 04-25-2013, 01:30 PM   #171
Solara's Avatar
Trader Rating: 16 (100%+)
I have the CRC Gen X and I will give it a try tonight...
And this SUNDAY I will run the SP1 with Pardas at the 2012 Pavement National track at Leisure hours....of course, it will be a test run only, no prep on the track, so expecting alot of dust...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-25-2013, 05:33 PM   #172
A suggestion for a change in the instructions...In step 10 I would suggest assembling the steering bell cranks but only attaching the posts to the carbon fiber plate. The bell cranks get in the way in step 14. Once the suspension plate is bolted to the chassis then put the bell cranks on. Also in step 11 it should mention the servo mounts will need to be trimmed if you plan to set the car up at 185mm.
Old 04-25-2013, 08:02 PM   #173
liljohn1064's Avatar
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
The CRC retainers are smaller diameter. No go.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 04-26-2013, 03:13 AM   #174
Has anyone tried alternate mounting positions for the servo yet? I'm using a low profile servo and it looks like it might work well if I mount it it facing upright like many F104 cars do instead of the tall way. Especially with the bell crank steering mounting the servo differently won't change the ackerman. I'd prefer to mount it upright to keep the CG lower if possible.
Old 04-26-2013, 06:32 AM   #175
The front pivot retainers need to have a slightly larger hole as well as being aluminum or harder plastic. I can't get my 2mm wrench in to adjust camber as the 3mm opening is too small and doesn't line up with the pivot ball.
Like this: http://www.amazon.com/Duratrax-Pivot.../dp/B001LVARHI but at 4mm instead of 8. I believe these are the correct diameter. 7mm is too big as I has some from my ABC mini to try.
John Higgins
Old 04-26-2013, 07:59 AM   #176
Trader Rating: 15 (100%+)
Does anyone have comparison pictures of this chassis with a normal 2s pack vs a shorty 2s pack? Also, does anyone know how close the car is to minimum weight with a shorty pack?
Thanks for any help.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 04-26-2013, 11:43 AM   #177
Don't have specifics yet Lloyd but I believe any of the pan car style F1 cars are going to be well under weight with a shorty pack.
Old 04-26-2013, 12:32 PM   #178
the website says with long pack it's around 1160g. so it's around 1060g with a shorty pack I guess?
it really depends, like some people like beautiful body with everything (mirrors, T-bars, etc) on them; Regular servo v.s. low profile servo; some long pack is 320g and some are 280g; my shorty pack is 223g, some are 200g; ESC and Motor weights differently; some fast guys here prefers perfectly balanced cars, and their car are over 1200g (they race with long pack).
TLR 22 | FGX | XI DH | TS4 | EB48 | DESC410V2 | SP-1 | DEX410V3 | DESC210
nicholasxuu is offline   Reply With Quote
Old 04-26-2013, 03:13 PM   #179
Solara's Avatar
Actually, I tried my CRC Gen X retainer (on manual, it is called Slotted capture insert)...and that fits perfectly with the SP1 steering hub....in fact, I think it has a tighter fit then the original one which I really like.
I am not sure we are both talking about the same parts....but I know my retainer on my old GEN X fits perfectly with a flat head screw driver to drive it in....I am not sure CRC made the aluminum version of that.
And I believed the latest model XTi used the same slotted capture insert...it looks the same from outside but I do not have one and I cannot say that for 100%....see below pic from CRC site.
Old 04-26-2013, 03:34 PM   #180
seems the front is a bit tricky, especially the parts aren't up yet and upgrades will be even later.
Anyone can provide the list of parts needed for F104 front end conversion?
