Old 04-20-2013, 06:45 PM   #136
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
I hope that met everyone's picture requirements.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 04-20-2013, 07:14 PM   #137
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Build looks like its going well, I fumbled around with the front end for quite a while, finally got it together
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 04-20-2013, 07:41 PM   #138
fleetmaster's Avatar
Picking up where I left off. When putting in the upper ball retainer, do not over tighten and strip it. I had to CA the wrench to the part, turn it out, break it off the wrench and then notched both of them to be able use a screw driver just like the CRC cars.
Inline was my choice.
Add more shims here to decrease the ride height. You'll need more than 3 for the F104 tires.
Installed! The front end is done. I found that the recommended gap for the front tie rods @ 23 + mm is wrong, too much toe in. Mine are currently at 21.7 or so and now have a little toe out.
Great build thread ! Thought I may suggest that the steering rod length is probably longer for the 200mm width option.....
fleetmaster is offline   Reply With Quote
Old 04-20-2013, 08:49 PM   #139
Car Breaker's Avatar
agree with Fleetmaster, the upper ball holder is really weak , SP should change the material of that part. the football joint in the middle also too soft, they can hardly hold the nut in place to fasten, and the ball will pop out when hitting the wall. other than that it is a nice car to drive and build.
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 04-20-2013, 08:55 PM   #140
Yes it is, around a 26mm gap per the book.
Also be very careful at step 12. If you are running the F104 tires you use 2x2mm spacers under each lower arm mount point. The tip is buried in the left hand column where the parts for the step are listed and easy to overlook. I did and had to go back and fix it. Also, you'll have to use 2x10mm screws instead of the 2x8mm, they are not long enough when you add the extra spacer and the 10s are too long when only using 1 spacer as that is where the caster mount screws into the same hole from the top. The empty chassis is now sitting at 5mm front to rear on Sweep tires.
John Higgins
Old 04-20-2013, 09:02 PM   #141
This was a fun build and I did make mistakes and correct them, but learned a lot along the way.
John Higgins
Old 04-21-2013, 01:14 AM   #142
After talking with Brad this am I added a 3rd 2mm spacer under the arm during my build and it was too much. I need to go back to 4mm under the arm in the am.
Pillow balls I had the same issue on the first one. Stiffer material or an aluminum screw would be nice.
Nice kit to build parts all went together well and quality vs price/value can't be beat. Can't wait to get this on the track and do some testing.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 04-21-2013, 03:21 AM   #143
I had the same problem with the AE football when I put it together for my F1R...To me the nuts seemed a lil too tight on screw so I will probably pre-thread mine with a tap once my car arrives.
Old 04-21-2013, 07:39 AM   #144
+1 Those nylon inserts at lease need the screw to run through them a couple of times or they spin in the football.
John Higgins
Old 04-21-2013, 07:44 AM   #145
Placed my F60 body on the car for giggles and slid a spare front wing in place. All the mounting holes lines up. That was pretty cool. The rear posts seem a little short though and need to be shimmed a couple of mm. There is also a spot in the back that will have to be trimmed to clear the upper pod plate as the body sits right on in. I have a new body on order and will detail that when I have it in hand.
John Higgins
Old 04-21-2013, 08:44 AM   #146
Default Same here..
I did the same thing, but the roller is together and I am taking a short break to post this. The car will be track ready by the end of the day (accept for the body). Hope this thread keeps going so that we can share thoughts.
TWILL is offline   Reply With Quote
Old 04-21-2013, 10:29 AM   #147
sugs's Avatar
Hey Solara, diggin the new cars. Do you know if the LM-F is designed to compete in the World GT class or Pro10 class?
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 04-21-2013, 07:09 PM   #148
NutDriver's Avatar
Trader Rating: 14 (100%+)
@sugs, from what he's told me, the wheels and tires are different from the F1 cars and it is believed that the car is going to be 235mm.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 04-21-2013, 07:48 PM   #149
sugs's Avatar
Thanks NutDriver, it looks like it is on the wider side from the picture. Hope its a class that takes off around here, I love the LMP cars.
Old 04-22-2013, 10:18 AM   #150
Solara's Avatar
No...it will be a totally different classs due to the body is wider and longer then WGT, and it will be run mainly in FOAM over Asia and AOS but RUBBER TIRES in USA/Europe ETS series.
And it will be 2 cells with 21.5 or the most is 17.5 blinky...
Right now....I am looking at my brand new LM-F sample and going to paint up the body. My current task is....should it be called LM-F (LeMans Formula) or LM-1 (just like SP-1). I created the name LM-F but cooperate wants it LM-1 similar to the SP-1...easier for them to input information on database.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
