Old 01-11-2014, 10:18 AM   #256
kkchung's Avatar
My CSO-V2 2014
kkchung is offline   Reply With Quote
Old 01-13-2014, 01:51 AM   #257
howardshum's Avatar
Originally Posted by kkchung View Post
My CSO-V2 2014
Well, it's look like more CSO V2 fans here...
howardshum is offline   Reply With Quote
Old 02-08-2014, 09:20 AM   #258
roger999's Avatar
My setup from last club rd, 13.5 pro stock. Car was very easy to drive, plenty of grip and good steering.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 02-16-2014, 05:54 AM   #259
spacendeman's Avatar
Send a message via MSN to spacendeman
Hi Guys,
As I am looking to this car and see it in the shop at RCmarket, the car is blue aluminium?
The spare parts for suspention ( such as suspention mounts ) are all normal color? Can't find blue there?
Also how is that kit fit? Any nessesary options that are needed to buy?
Thanks!
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 02-16-2014, 06:33 AM   #260
roger999's Avatar
Originally Posted by spacendeman View Post
Hi Guys,
Thanks!
Yes is blue, is hard to find blue suspension mounts as the car is still fresh. you can buy all suspension mounts in gold at the moment from first ver.
Try RC Racing pro shop, they have loads of CSO parts.
I didnt have any problem with assembling. You may only need to sand arms (they pretty stiff in mount) and gear diff (internal gears and shims). Rest was just great to build.
Old 02-16-2014, 12:00 PM   #261
malcnz's Avatar
Had another good win in our stock(21.5 turbo) class yesterday(sunday)..won first final and blew motor while leading second and then finished first in last race after TQ so was prity happy with that and car was flawless all day...ran the steel outdrives on the spool and held up fine with no split plastic blades to worry about.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 03-02-2014, 02:07 AM   #262
howardshum's Avatar
Hi Guys,
Thanks!
This one : [IMG][/IMG]
[IMG][/IMG]
Old 03-02-2014, 03:16 AM   #263
Hi,
I have a project and i would like to know if someone could give me the spacing 1 and 2 bettween the motor mount holes (from center to center of holes).
Also the total height of the pulley mount and the height of the single post in the front of the mount.
Thanks you
CoCoLapin is offline   Reply With Quote
Old 03-02-2014, 04:03 AM   #264
howardshum's Avatar
Originally Posted by CoCoLapin View Post
Hi,
Thanks you
I am not a expert but I try my best to let you know how to do. You may assebmle the motor and spure gear into the kit, then you may use one A4 paper insert between motor gear and spure gear, you may tighten up all the screw and pull out the paper, that is ok.
Old 03-02-2014, 06:52 AM   #265
cyba888's Avatar
anyone have any experience with the Steel Hardcoated Double Cardan joint Shaft? Can it take a beating and does it have a lot of slop?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-02-2014, 08:16 AM   #266
howardshum's Avatar
May I suggest you show some picture for reference?
Old 03-02-2014, 08:24 AM   #267
cyba888's Avatar
http://www.ebay.com/itm/CSO-Steel-ha...p2054897.l4276
Futaba 4PX
Old 03-02-2014, 08:50 AM   #268
howardshum's Avatar
Yes, I had try and overall performance is ok! It was 44mm length.
Old 03-02-2014, 11:00 AM   #269
Thanks you but you don't answer my question. I am not asking how to set the space between pinion and spur gear.
I would like to know in millimeters the space, the lenght there is between the holes of the motor mount.
Old 03-02-2014, 10:25 PM   #270
howardshum's Avatar
the length is 1cm, this data consult from Destributor. I hope I can answer.
