Old 12-02-2013, 11:29 PM   #211
roger999's Avatar
Thanks guys with help about spur gears.
What about quality V2 ver?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 12-03-2013, 04:09 AM   #212
blackshark3's Avatar
Originally Posted by nazman01 View Post
fyi. in case anyone was wondering , like i was . the cso double jointed axles are excellent quality. but the are labeled 44mm unlike xray ones that are 50 or 51. there prob either made different or measured different. but fit perfect.
I am using the CSO double carden shafts on all sides because they are so cheap (I heard 3Racing ones are even cheaper)! They worked well for me, though I heard some people bent them at the first pack without any major crash. I once bent a pair of VBC double carden shaft, and just the dogbone replacement part cost more than the whole set of CSO ones...
And yes, 44mm Tamiya/Yokomo double carden shaft is the same length as 50mm T4, have no idea how they measure them
blackshark3 is offline   Reply With Quote
Old 12-11-2013, 02:07 PM   #213
roger999's Avatar
Is that normal if rear diff has play on each side? I mean it doesnt fit tight... Do you have same or its just on my kit?
Old 12-12-2013, 12:26 PM   #214
malcnz's Avatar
Mine is nice with no play..a bit of play isnt a biggy or you can shim it out most likely and its better with a bit of play than to tight.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 12-13-2013, 07:21 AM   #215
roger999's Avatar
Here we go...
Old 12-13-2013, 08:59 AM   #216
roger999's Avatar
Old 12-13-2013, 10:35 AM   #217
roger999's Avatar
Old 12-13-2013, 11:15 AM   #218
roger999's Avatar
Old 12-13-2013, 11:43 AM   #219
malcnz's Avatar
Looking good...I see the shape of the front and rear towers are different but not sure if the mounting holes different or its just the shape from v1 kit?
I have just upgraded mine to v2 upgrade kit and get to run it tomorrow and it does feel like it will have a bit more grip as the new chassis/top plate and spur mount/engine mount creates more side to side flex....best and cheapest kit on the market by far
Old 12-14-2013, 02:49 AM   #220
roger999's Avatar
Old 12-14-2013, 07:53 AM   #221
roger999's Avatar
Old 12-14-2013, 10:01 AM   #222
roger999's Avatar
Car finished. The only problem i found was no thread on one side of turnbuckle and had to polish internal shims from gear diff and use shim to fit gear diff tight in bulkheads. Overal quality of materials and also finish is very very good. Car is not tweaked and plastics are very hard.
Old 12-24-2013, 12:56 AM   #223
roger999's Avatar
Just wondering, any parts available somewhere for V2?
Old 12-24-2013, 04:08 AM   #224
Have you tried hotlapracingusa.com for parts?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 12-24-2013, 10:59 AM   #225
malcnz's Avatar
RC Mushroom have parts as arms, hubs etc same as v1.
