Old 07-03-2013, 07:45 AM   #166
locked's Avatar
Originally Posted by Dan View Post
So I wonder if you could buy the CSO chassis and suspension mounts and swap it over on a T4. Only skeptical about the CSO CF quality though...
The suspension is different, so you can't use those mounts on a T4 bottom chassis without drilling new holes(which might be too close to current holes).
I'm pretty sure you could use a T4 top deck though.
locked is offline   Reply With Quote
Old 07-03-2013, 07:20 PM   #167
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
I'm talking about using the CSO-1 chassis itself, purchasing the mounts, and seeing if it all bolts into my T4.
Dan is offline   Reply With Quote
Old 07-04-2013, 10:55 AM   #168
locked's Avatar
Oh. Sorry, I misunderstood.
I think that would work. I'll take a closer look this weekend at some of the local guys' CSO cars and reply back here. There's quite a few of them around and I have a couple of T4s to compare them to.
Old 07-05-2013, 01:28 PM   #169
Dan
Dan's Avatar
Thanks, much appreciated!
Old 07-07-2013, 08:00 PM   #170
guys! my first training CSO-one, broke the gear of rear geardiff!
The original Xray of T4 are compatible, anyone know?
314ck5h33p is offline   Reply With Quote
Old 07-07-2013, 10:26 PM   #171
locked's Avatar
Looks like everything, except for the suspension mounts, are identical to the T4. So yes Dan, looks like you could get a CSO-1 bottom chassis and the suspension mounts and use everything else from a T4. CSO bulkheads have a nub between the two screw holes that slots into the chassis, so they wouldn't be able to work on T4 chassis without grinding off those "keys", but T4 bulkheads should be able to mount onto the CSO chassis fine. One other difference is they use a T3 bumper instead of the smaller T4 bumper.
314ck5h33p, an XRAY gear diff should fit fine. Just the internal gears will probably work as well. The diff looks identical to an XRAY diff, but the materials used and the tolerances are not the same.
Old 07-07-2013, 10:48 PM   #172
Dan
Dan's Avatar
Thank you for checking for me! Now to see where I am able to buy the parts online...
Old 07-07-2013, 11:35 PM   #173
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Ha! I see where your going with this. just wait for the T5 version and maybe, just maybe they might get rid of those plastic arm mounts. But if CSO works then hell go for it now!
Josh-n-ya is offline   Reply With Quote
Old 07-08-2013, 12:50 PM   #174
Smile Gear Diff
tks!
The Internal gears of gearDiff Chassis Capricorn Lab TE 01, also seem identical, who will be equal?
tks for help me!
Old 07-12-2013, 02:32 PM   #175
The internal GearDiffs of Capricorn Lab TE01, is perfect for CSO!
Old 07-20-2013, 12:02 PM   #176
How the car works?
Zooberg is offline   Reply With Quote
Old 08-15-2013, 02:49 PM   #177
KHoff7's Avatar
If anyone is looking for CSO parts that are stocked in the U.S. my local hobbyshop set up an online inventory for anyone to buy from. Check it out!
www.hotlapracingusa.com
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 08-26-2013, 04:25 PM   #178
malcnz's Avatar
Another great day with my CSO 1 in our stock(21.5 turbo) class and managed TQ and the win and also a new track record as we have a new drivers stand which is higher than our old so helped my old eyes a bit.
CSO-1 1/10 190mm Touring-dscf1683.jpg
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 09-20-2013, 08:59 AM   #179
yokemad's Avatar
Hey All
is this kit comes with a Proper Carbon Fibre Chassis Or Fibre Glass mixed in middle layers ?
Cheers
yokemad is offline   Reply With Quote
Old 09-20-2013, 10:24 AM   #180
Carbon Fibre
SEO by vBSEO 3.5.0
