Orion V2 8 X 1 motor >
Old 04-27-2005, 02:48 PM
KREATOR1's Avatar
Default Orion V2 8 X 1 motor
i just bought this Orion V2 8X1 motor
i need sguestion on the gear ratio to start with.
i hear that alot people burn thier ESC with the mod motors.
KREATOR1 is offline
Old 04-27-2005, 03:05 PM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You'll only burn up an ESC with a motor if that ESC isn't rated for mod motors. What ESC do you have? Also, gearing is very track and layout specific as is timing. With a little info about the track I can point you to a good starting point for you to work from.
Jon Kerr is offline
Old 04-27-2005, 04:13 PM
JimmyMac's Avatar
Also, don't forget a good or alot of schotky (sp?) diodes. You'll definately need them with a hot mod. That's one way I fried one of my ESC's. I forgot to toss one on the motor. You'll need it for heavy braking like when you use a spool or diff.
Gearing? Hmm, I haven't used an 8 turn in years. But since Roar is back to open mod... I'm gonna start using them again. I forgot what I geared mine too. But like Jon said... alot depends on the track size, layout, car, motor timing, etc...
JimmyMac is offline
Old 04-27-2005, 04:26 PM
SuPerDraGon's Avatar
Hi
You can start at around 8.6~8.8 at timing on the 3rd line.
Feel the speed down the straight and adjust the ratio.
SuPerDraGon is offline
Old 04-27-2005, 07:08 PM
Jon Kerr's Avatar
Be careful about using schottkey's. Most ESC's, yes, you'll need them. But if you're using a Keyance, you don't want to use them.
Jon Kerr is offline
Old 04-27-2005, 08:35 PM
KREATOR1's Avatar
thanks guys,
by the way Jon im using a GT7 with Ko pro shocky diod
this is a picture of the layout,
KREATOR1 is offline
Old 04-27-2005, 08:45 PM
Jon Kerr's Avatar
GT7 really must have a Schottky. With a layout like that, I'd start around 8.5-8.7 with 18-20 deg of timing.
Wish I had a track like that to race at. I'm jealous.
Jon Kerr is offline
Old 04-27-2005, 09:03 PM
KREATOR1's Avatar
will try it out this weekend.
this is my 1st time runing mod. motor. how many Amp the batt. should be charged?
Jon , its the best track so far in Malaysia. and its very smooth too.
KREATOR1 is offline
Old 04-27-2005, 09:30 PM
highwayman's Avatar
i charge all my matched packs at 5amps...
i found that my 8x1 orion motor liked it better when the timing was reduced, rather than the 18 deg that came with the motor... 8.5 to 8.7 final drive seems right.
highwayman is offline
Old 04-27-2005, 09:45 PM
Jon Kerr's Avatar
Yeah, 5 amps is about right. But they should be charged at that from the start. I've used lower timing on the V2 motors on smaller layouts to get more grunt out of them on the bottom end. On a big layout like that, you can go with a little higher timing to get some good top end.
Jon Kerr is offline
Old 04-27-2005, 10:01 PM
highwayman's Avatar
i agree, i once experimented with different charging rates, like 6amps for stock, 4amps for mod, the packs deteriorated quite quickly... i feel thats packs should be charged the same everytime, whether it be 4, 5 or 6 amps or even stepcharging, as long as you do it over and over again...
... our track is relatively small, around 9.2 to 9.4 final drive on the 8x1 orion.
Old 04-27-2005, 10:06 PM
Guys, i forget, what does each tick on the v2 equate to? 6 deg?
thanks
Johnnytc3 is offline
Old 04-27-2005, 10:11 PM
highwayman's Avatar
thanks
around 4 deg.
Old 04-27-2005, 10:13 PM
thanks hiwayman, i had it pretty low all this time...
Old 04-27-2005, 10:43 PM
F. Alonso's Avatar
It's 6 degrees, not 4.
F. Alonso is offline
