Old 09-04-2013, 10:31 PM   #91
koval's Avatar
Preparing the new mp4 body for gt2
http://brushlessmaniac.blogspot.gr/
koval is offline   Reply With Quote
Old 09-05-2013, 09:05 PM   #92
FLoJo's Avatar
Kool , Gulf scheme?
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 09-05-2013, 09:50 PM   #93
koval's Avatar
Originally Posted by FLoJo View Post
Kool , Gulf scheme?
Thats right
Old 09-05-2013, 11:00 PM   #94
koval's Avatar
Painting done ,wating to print the decals
Old 09-12-2013, 02:44 AM   #95
koval's Avatar
Default Inferno gt2 8s castle 1717 34t project
Hello guys,
Here is a buid that i have started in my milling machine a few days ago ...
A conversion kit for inferno gt2 that will allow to use the big block motor of traxxas XO-1 (castle 1717) or larger motors like leopard 1/6 scale -high speed pinion gears up to 38t-8s lipo batteries.
An extreme set up for very high spedd passes under 100mph.
This is the aluminum motor mount
Old 09-12-2013, 03:54 AM   #96
FLoJo's Avatar
Make me one while ur at it thatount looks fresH
Old 09-12-2013, 04:20 AM   #97
koval's Avatar
No problem man pm me,
This is the first step of the conversion ,the second will be a redesigned battery tray for 8s lipo packs .
I ll update the thread with photos and infos in the next days.
Greetings, kostas.
Old 09-15-2013, 06:37 PM   #98
Questions??
I have an Inferno GT2 with a short IGT chassis plate. It was originally nitro powered and then I converted it last spring to brushless. It is mostly stock except for:
  • Leopard 2000kv 4082 motor (was a Kershaw Design "exclusive")
  • Hobbywing 150A ESC
  • Dragon Racing CNC'd chassis plate
  • Inferno VE battery/ESC tray
  • Sweep wheels/tires
  • Front sway bar kit
  • Sky 6S battery
  • 20/46 gearing
  • Protoform PF8GT body
The car runs great on 4s or 6s, however I have an issue of keeping it on the ground with 6s. Anywhere between 20-60% (estimated guess) throttle, I can hammer the throttle and it will wheelie which I've gotten used to and have adjusted my trigger finger accordingly after ripping the rear corners of the body from dragging on the asphalt. However, if I gradually give it throttle, around 80-90% throttle the car will still slowly come up off the ground and flip.I'd like to be able to do full throttle speed runs, but most of the time the car will lift off. Using the Scriptasylum page, this setup should be good for 82mph (theoretically).
The asphalt I've been running it on is about as flat as possible so I've ruled out hitting a crack or bump at speed and upsetting the car. I think it has more to do with aerodynamics and was hoping someone might have good suggestions. I was thinking about getting another PF8 body and modding the area between the tail lights and the rear bumper. Either some "speed holes" or maybe even removing some of that area like I used to do when racing pan cars in the early 90s. Or...I might try an Ipanema body if those would offer superior aerodynamics.
Any other suggestions would be appreciated!
Arrma Senton- Leopard 4082
Redcat Rampage Chimera- CY 27cc, Baja wheels, belt drive
Nitro Slash- Novarossi 2.5, Jato transmission, 17mm conversion
Duratrax Skyline- Nova Rossi .12 & Dynamite pipe
Dirk Squarejaw is offline   Reply With Quote
Old 09-15-2013, 09:21 PM   #99
koval's Avatar
  • Sky 6S battery
  • 20/46 gearing
This is a usuall problem with short chassis electric gt,my friend igt does the the same thing especially with good tires on a high grip aspsault.
What silicone diff oil you use in the center diff?As you reduce the thickness of the center diff oil the less weeling you get .
Also try to raise the height of the rear end of the car and reduce the droop effect .
Old 09-16-2013, 04:22 AM   #100
FLoJo's Avatar
I run my gt1 on 6s with pf8 body , never got blow over . Readjust your suspension , or add weights to front .
Old 09-16-2013, 10:03 AM   #101
koval's Avatar
+1
Old 09-16-2013, 10:25 AM   #102
koval's Avatar
Update
Motor mount placed on chassis
http://3.bp.blogspot.com/-CZ0RjAEPwX...0092013751.JPG
New battery tray
http://3.bp.blogspot.com/-aC5OVAiB8w...2092013845.JPG
http://3.bp.blogspot.com/-akHgSxJy2m...2092013856.JPG
http://2.bp.blogspot.com/-Q2QPrIwOZG...2092013857.JPG
Old 09-17-2013, 11:10 AM   #103
I'm running 100k in the center diff. I'll try raising the rear. I had to re-trim the wheel wells and raise the body a little for the Sweep wheels/tires as the OD is a little larger than the stock tires. Would moving the spoiler forward help? Mine is mounted so that more of it is off the rear of the mounting pedestal.
Old 09-21-2013, 03:03 PM   #104
koval's Avatar
Starting you must replace the silicone diff oil with a 50k on center diff ,raising the rear will also helps .
Old 09-21-2013, 03:49 PM   #105
koval's Avatar
Ready !!
The Previous Battery tray i have made was small for 1/5 scale esc so i designed it again .
http://3.bp.blogspot.com/-x6qqOH3lhd...8092013024.JPG
http://1.bp.blogspot.com/-mlPAUxz9Uw...8092013028.JPG
http://4.bp.blogspot.com/-pqhmQ3h9pF...8092013031.JPG
http://4.bp.blogspot.com/-Q0UnyGp-vu...9092013051.JPG
http://4.bp.blogspot.com/-p2LCLr5zVc...9092013048.JPG
And here is a video testing on the stand
http://www.youtube.com/watch?v=UFZTOouXQ9Q
Tags
gt2 ve, igt2, inferno gt2 ve, kyosho
