Old 04-16-2013, 10:53 PM   #31
Originally Posted by 2012RCTECH View Post
Thanks for your very quick response!!
More details + pics would be great
Like, what foam your are using + what kind of glue...
Many thanks!
May be shoe goo your body will help as well. Check this link
http://www.youtube.com/watch?v=VTe-m...e_gdata_player
gosha is offline   Reply With Quote
Old 04-16-2013, 10:55 PM   #32
Originally Posted by FLoJo View Post
maybe check your drive shafts , or could be the diffs
havnt really messed with mine yet still new in the box only one run on it
Yep. Looks like it was the problem. Was playin with diff shimming. Set it to factory settings. Thanks.
Old 04-16-2013, 11:12 PM   #33
Originally Posted by ikalon View Post
Thanks for the answer FloJo.
Well, it's easy, all is stock right now on my car, so the motor/controler is a...Let me take back the official stuff : Team Orion Brushless System : Vortex R8 Splash Proof(Compatible up to 4S Li-Po /
Water Resistant) ESC(Constant/Peak Amp : 130A / 760A) and Votex 8 / 4 pole / 2000KV
Brushless Motor. ESC has heat and safe protection.
As i'm quite new in RC, the choice of motor is maybe the most difficult thing for me. Even if I understand the principle, there's so many kind of it that i'm quite lost.
As for all the others possible upgrade, hey...Let's be honest, i'm french and in france there's virtually nothing for the GT2 and I don't know which website to choose to buy upgrades, if you can advice me on that i'll be glad
Fort he tires I saw that speedline one seems good, i'll check on that.
It's all function of money. Depends how much you want/can spend.
I have two nitro GT2s converted to brushless. One already converted. Second in the process.
First one has Tekin RS8 ESC and Tekin T8 2000kv motor, savor servo for steering, front CVDs, center front and rear CVDs, Sweep Racing 50 tires.
Send car will have Castle Creatins Mamba Monster ESC + 2200kv motor, savor servo, front CVDs, Alpha Racing mid compound tires...
May I will also upgrade top plates on both to carbon-fiber...
Old 04-17-2013, 07:31 PM   #34
FLoJo's Avatar
Your right , its all about the money . Ive dumped buncha cash into this gtp2 while my gt2 is sitting in a box waitin for upgrades lol
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 04-18-2013, 07:40 AM   #35
That's a shame
Old 04-18-2013, 10:27 AM   #36
Default as promised here are the pics
of the foam thingy to prevent the body from flapping, and the LED setup. Im using a pico switch to control the rear brake lights on ch 3 (mixed with throttle/brake).
The Kyosho Inferno GT/GT2 VE Race Spec ELECTRIC on road 1/8th thread-img_0373.jpg   The Kyosho Inferno GT/GT2 VE Race Spec ELECTRIC on road 1/8th thread-img_0372.jpg   The Kyosho Inferno GT/GT2 VE Race Spec ELECTRIC on road 1/8th thread-img_0305.jpg   The Kyosho Inferno GT/GT2 VE Race Spec ELECTRIC on road 1/8th thread-img_0307.jpg   The Kyosho Inferno GT/GT2 VE Race Spec ELECTRIC on road 1/8th thread-img_0374.jpg
aquaanox is offline   Reply With Quote
Old 04-18-2013, 12:29 PM   #37
Nice...
Old 04-19-2013, 01:22 AM   #38
Many thanks!
I took a different approach meanwhile- I extended the bumper towards the front, I made a complete new bumper out of PE-Foam, didn't drive it yet, but seems to be working...if not, I will try your solution!
You car looks great with the Leds!
What tires/ wheels are these again- sweep?
RC8.2e FT
2012RCTECH is offline   Reply With Quote
Old 04-19-2013, 01:27 AM   #39
Also, shim the entire car, there is a lot of vibration in this out of the box (diffs, hubs, driveshafts, dogbones etc etc).
I noticed that vibration too- not good- disappointing I must say!
I started to balance the wheels, but I didn't help much.
Where did you start to shim- where did you found the most play, so I can start there...
Thank you!
RC8.2e FT
Old 04-19-2013, 11:15 AM   #40
Nice body. did you paint it yourself?
Old 05-01-2013, 12:15 PM   #41
Default Mechanical Brakes
Greetings!
I was preparing to pick up a GT2 RS VE roller in a little bit and I was wondering if anyone has modified their stock setup to use mechanical brakes. The mod looks fairly easy - use rc-monster dual servo tray, add 2nd servo, and add the nitro model's brake linkage and disc hardware, etc. - however, I was wondering if there is anything else I may need for this?
Also, slightly off my initial topic, I've seen that the GT1 chassis have been prone to flexing and even warping in some instances. Is this a problem for the GT2 RS chassis and should I be looking to upgrade to another Kyosho chassis (i.e. ST-RR) immediately?
BTW, I plan on doing speed runs and mild bashing, but if the local track starts racing this class then I'll mod accordingly.
festusss is offline   Reply With Quote
Old 05-02-2013, 02:51 AM   #42
H0LESH0T's Avatar
Anyone here ever heard of someone converting a Inferno Buggy into a GT (minus the 2 speed). Was looking at doing it a few years ago but sold the kit and got something else.
H0LESH0T is offline   Reply With Quote
Old 05-02-2013, 09:39 PM   #43
Thank you!
I had to shim the hubs, all 3 diff housings, spur, balance the wheels and now its smooth as butter.
Old 05-02-2013, 09:40 PM   #44
Thx. Yes. Just some tamiya paint.
Old 05-02-2013, 09:41 PM   #45
Many thanks!
They are the ofna v spokes with the ofna tires
Tags
gt2 ve, igt2, inferno gt2 ve, kyosho
SEO by vBSEO 3.5.0
