Old 07-26-2016, 04:09 PM   #376
Thumbs up
Originally Posted by koval View Post
Hello ,
i made 1/5 tire adapters and 1/5 size motor mounts for inferno cars .
Here is a photo with the adapters installed on inferno mp9 ,compatible also with gt2 ,st ,neo etc.
http://brushlessmaniac.blogspot.gr/2...pters-for.html
Just note that these tires are aproximately 15mm larger diameter than the 1/8 gt tires , they are almost the same diameter with 1/8 buggy tires
For this reason you need to trim the body for the larger wheels.
Just realized I have one of your motor mounts and it's great!
irish177 is offline   Reply With Quote
Old 07-26-2016, 04:17 PM   #377
Hello, I wanted to make side body post. So the body won't "butterfly" flap.. I've seen ofna's with it. Let me know what you guys think please??????
Old 07-26-2016, 05:33 PM   #378
Guys I need a soldering iron. Someone said the name of a reasonablely priced one, can't find his post. I was looking at the Weller WLC100. 5-40a and it cost $45, is that good for RC needs? Thanks
Old 07-28-2016, 06:04 PM   #379
No one else out there wants to make GT/2's faster?
Old 08-08-2016, 12:17 PM   #380
Default Diff fluid?
I'm sure I asked this already: I have an inferno GT2 and I done some hop ups. Running a spool. Was told to run 60,000wt diff fluid front/rear.... Any input? Can use as much as poss!!! Thanks
Old 08-08-2016, 03:49 PM   #381
I recently sold mine after wrecking it. At the time it was the world's fastest Kyosho at 143 mph. I ran stock diff fluids.
tc4basher is offline   Reply With Quote
Old 08-11-2016, 05:16 PM   #382
Default Diff
Street drag racing is a little different... Big ass power and trying to keep it straight... Very hard but, fun as hell
Old 08-13-2016, 10:30 PM   #383
koval's Avatar
Photo's of the 5th scale square hubs installed on the gt2....
Grp tires installed !
Max width on the front wheels 34cm !
koval is offline   Reply With Quote
Old 08-21-2016, 12:21 PM   #384
Default 5th scale weels
I street/drag race 300ft. Can the drive train hanle all the traction? I was thinking it would tare everything up! Hope it holds! Love it
Old 09-12-2016, 10:36 AM   #385
In other words no running the stock body? A scalpel 300m or buggy body is needed? Looks a lot like rc hornet adapters.
Uguessedit is offline   Reply With Quote
Old 10-04-2016, 04:49 AM   #386
If you want to do a lot of high speed runs or drag racing. a lot of guys put a small heading lock gyro in there 8th scale gt cars. It makes It more easier to control when the car Is barreling down the street over 100 mph.
modojojo is offline   Reply With Quote
Old 10-20-2016, 03:41 AM   #387
Default Xo1 vs inferno?
Ummm because the inferno is a far better platform in engineering and far greater stability and speeds can be accomplished. The xo1 is just a stretched traxxas slash. Woohoo. I Have an 8a slash that will handle better than an xo1. They are difficult to control and keep grounded. Lots of reasons why besides the kyosho is an awesome 1/8 scale car. And again there is far more tou can do with the kyosho.
Originally Posted by erion racer View Post
Maybe the wrong forum to be asking but why would someone chose the GT2e over the traxxas xo-1 for similar pricing?
Old 10-24-2016, 05:53 PM   #388
Just had a buddy help me convert my GT1 to a GT2 Brushless. Cant get the Protoform C7 body to sit low enough due to the front upper shock mount. Am i missing something or is there an option part i need to be looking for? Thanks
h82lose91 is offline   Reply With Quote
Old 04-11-2017, 07:39 PM   #389
I see not a lot of use on this thread but i got a old gt1 that I want to convert having trouble getting everything wondering if could get some help advice. Do I stay 2 speed or convert to single had alot of trouble finding a spindle speed center diff but found 2 speed pinion adapter with gears. Thanks
teo1213 is offline   Reply With Quote
Old 04-11-2017, 10:55 PM   #390
Talked to koval got me set up thanks!!!
Tags
gt2 ve, igt2, inferno gt2 ve, kyosho
