GP's explosion
GP's explosion
DON'T EVER CHARGE A PACK WITHOUT BEING THERE. (WATCHING THE TEMP).
DON'T OVER CHARGE. NEVER OVER 10 MV DELTA PEAK (THRESHOLD) PER CELL.
NEVER CHARGE OVER 6 AMP.
NEVER CHARGE OVER 120 DEG TEMP.
NEVER USE A METAL BATTERY HOLD DOWN AS THEY HAVE BEEN KNOWN TO SHORT OUT BATTERY PACKS.
ALWAYS WATCH THE TEMPERATURE OF BATTERY AND CHARGER.
NEVER CHARGE ON A METAL SURFACE THAT CAN SHORT OUT CELLS.
THESE BATTERY ARE POWERFUL AND BY NOT BEING CAREFUL YOU CAN AND WILL HURT YOURSELF OR SOMEONE YOU LOVE.
was taken from power push web site.
Thanks, Tony.
Thanks, Tony.
what the hell happened, a lot of of battery explosions recently... 2-3 weeks ago i also shortened two gp3300 packs and 5 cells went to heaven
isnt 10mv peak rather high ??
i set my orion advantage and pitbull at .03 for gp 3300's
oops, doublepost
Re: GP's explosion
Thanks, Tony.
Thanks, Tony.
STAY AWAY FROM FALSE PEAK LOCKOUTS!
I used to get some scary cell temps from the Pro-Trak using the lockout - just too easy to forget to discharge. Peak detection is there for a reason after all...
Anyway, people have always been blowing up cells, it's been happening long before IB and GP got into the RC market - I managed to short circuit a pack of 1/18th batteries last year which was quite spectacular - good thing I had an open window with a concrete path below it nearby. And there are people at my club who seem to blow up packs a couple of times a year... but then again, if you let all the shrink get split off your cells, you kind of deserve it...
i have charged packs at more then 6 amps (12amps before)
and they didnt blow up, just peaked faster, and got warm fast! but once got to 130f there were peaked
Fast in stock!
Fast in stock!
I always charge 4amps for mod, 5amps for stock.
The lower the charging amps the longer your pack should last.
My 2years old GP still used in race.
Is there any sign before the cells boom ??
Will there any smoke, flame or any other sign that is more obvious than a small "KA" sound ??
A spark, as its shorting out on something.
you hear the "Ka" followed shortly by "Fluggin Boom!"
You might hear a sizzling sound before hand, as the cell is trying to vent. But its proabaly a clogged vent that causes the cells to burst.
Strange that more than one cells is going up at once. Must be very overcharged....
