spintec I.C.C charger
#916
Originally Posted by smokerules
Any body willing to make a battery chart?
Something that would help ALL of us out?
Battery Type.
Cell count-(4 or 6)
Charger settings that work well.
I have a hard time figuring out what works, everybody's different I know!
I just was looking for a guide line to start with.
It's a little hard to keep these cells from venting, and false peaking(not finishing the complete charge in mAh.
Thanx for any help, this site is the BEST!
I learn something new every time I get on here!
Battery Type.
Cell count-(4 or 6)
My Spintec is working perfectly (no false peaks, no cells venting) with the following settings for IB 4200 4-cell:
Charge amps: 6.0
volt cut-off: 2.0 mv
max temp: 105 deg. F.
min teim: 98 deg. F.
I have ver 1.06
#917
Am I correct in thinking that the lower the Delta Peak setting the more sensitive the charger will be to to batteries charge level.
In other words, if I lower the delta from it's current 3.0mv will the charger peak sooner?
My packs never peak at the minium temp (36 C) and seem to get pretty hot according to my temp gun.
Skiddins
Skiddins
#919
Thanx
Charge amps: 6.0
I have ver 1.06
Charge amps: 6.0
I have ver 1.06
I am looking for 6 cell also if anyone else has anything that works well for them!
#920
If you guys are getting false peaks, it's probably because you're takeing the cells down too far (possibly on a tray) before you start charging. Could also be the contacts (clean solder connections).
Without going into all the little details, overdischarging the current cells creates extra water in the cell. This extra water tends to screw up the balance inside the cell.
One other thing to note with the Spintec charger is that it doesn't pull enough current to turn on some of the bigger switching power supplies. If your charger boots up fine and then starts flashing the display, put more load on the supply. Tire warmers worked for me.
#923
It seems that no matter what temperature I set the charger to, it will only peak when the cells reach the 'peak temperature'
I have tried 3mv, 2mv and 4mv, and whatever the minium temp is, 35c I think. After comments about the inaccuracy of the temp probes I have tried maxiumum temps of 38, 39, 40, 42 etc and it always peaks at that temp. The actual temp appears to be about 10deg higher.
Why aren't they peaking 'during' the temp range I've set?
Should I try 5mv Delta peak, would this increase the chances of the pack peaking sooner or make things worse?
These are IB4200's and 4200 SHV's
Skiddins
Skiddins
#924
From what's happening here, I hope there is enuf software freedom to be able to let us calibrate the temp sensors. even a +X degrees simple offset calibration is going to be necessary, because the sensors are basically there, but not making sense.
Skiddins, do you mean the icc is always stopping because the temperature settings and not your peak detection settings?
#925
Skiddins, my first two ICC's did the same thing. My units were from the first production batch. My new ICC (Second batch) is better so far, most cells peak before the temp cutoff (45C, 2mv/cell) whereas before with the same settings every cell would peak on max temp every time.
It's still coming off hotter than 45 degrees according to my temp probe though, but not as bad as before.
#926
Skididns
#927
i havea dumass suggestion, set ur peak to 0mv. (i don't even understand how u can get 0mv peak detection) <-- how do you know a cell is finished charging if the voltage does not drop?
but set a ultra low peak, and like 45 degrees cut off on a "practice pack" and see what happens? i cannot do that... because i am working now... sigh... for another 8 months...
#928
Has anyone let the smoke out using the motor run? It does not seem to be well protect against over amp draw. Ashame for a charger of this price. The more I use this charger the more problems it seems to get.
Now I need to send the paper weight in to have the external output fixed.
Has anyone sent one in from the USA for repair?
#929
