Like Tree7Likes
Old 02-18-2013, 02:58 PM   #1
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default JFT 1/12 tires
Has anyone run these yet?
Any feedback on compounds?
Looks like no one carries them stateside but xenon jp is selling them.
Let me know....
J.Gonzalez is offline   Reply With Quote
Old 02-18-2013, 03:26 PM   #2
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Haven't tried those, but Ulti tires are imported from Japan by KO
Top notch wheels, and foam
For stock motors
X-Hard Front
X-Med Rear
http://www.shop.kopropoamerica.com/i...th=177_276_277
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-18-2013, 05:04 PM   #3
Trader Rating: 35 (100%+)
Default hey
jamie , ask mark he ran some sunday
nazman01 is offline   Reply With Quote
Old 02-18-2013, 08:34 PM   #4
Carl Giordano's Avatar
Trader Rating: 20 (100%+)
hey Jamie, nice find, too bad i switched over the Josh's Z4 rims not too long ago, although still don't know where I'm going to get replacements once my inventory gets low... I will ask Robert at KO about what he would suggest for 13.5 blinky.. I'm currently running Z4 pink/purple combo front and rear...
new carpet tracked opened in NJ.. about 30 minutes from GWB... small as were turning 8.0 sec laps in 13.5... see you soon
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 02-18-2013, 08:54 PM   #5
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Carl,
You can get them through BSR now. They own the rights to the Z4 wheel and hubs and have them in stock. They were the ones mounting all the rubber for Josh when he was selling them also.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-23-2014, 10:56 AM   #6
Hi,
Is there a difference between the white and the grey wheels in stiffness?
Or is it just a different color?
Claude
toroloco is offline   Reply With Quote
Old 11-23-2014, 12:42 PM   #7
JFT tyres are excellent. Wheels are well made, the glueing of the foam is very good and the compounds work well. Front wheel bearings fit exactly and the rears run true every time.
'C' foam is the equivalent of Yellow and Black Jaco - artificial rubber; 'A' Foam is the equivalent of Pink and Magenta-type tyres - natural rubber. In the UK we use 'A' foam - 30 rear (pink) and 32 front (magenta) on 13.5. If your club mainly uses yellow and black you'll need C foam. HTH
SlowerOne is offline   Reply With Quote
Old 11-23-2014, 01:41 PM   #8
CristianTabush's Avatar
Actually, this is not entirely accurate. A foam is in fact the pink/ magenta family (otherwise known as Japanese Rubber) but the C Foam is actually the new Japanese Foam that has been popping up lately known as blue/green and double blue. JFT goes further with a softer rear than green which they call yellow, but is nothing like the synthetic type Jaco Yellow. They also have a green front. When our track gets really tacky and fuzzes, yellow rear green front is very good.
The C foam breaks down like this:
Front: green (30 shore)/ light blue (blue bsr- 35 shore)/ dark blue (double blue bsr- 40 shore)
Rear: yellow (25 shore)/ green (bsr green - 30 shore)/ light blue (bsr blue - 35 shore)
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-24-2014, 01:28 AM   #9
Hi,
thanks for the answers but my question is not answered or maybe I didn't formulated it the right way.
There are two colors for the rims white and dark grey and I want to know if there is a difference other then the color ?
Thanks and sorry for mixed wheels and rims.
Claude
Old 11-24-2014, 07:27 AM   #10
From my knowledge there is only 1 color rim, Gray. If you are looking at the OEM Pictures, they are not the greatest, the shadow makes the fronts look almost white and the rears look like dark gray. However, the color is gray for both.
Old 11-24-2014, 07:42 AM   #11
Trader Rating: 15 (100%+)
Actually, JFT does have white wheels. Teru had some at MHIC this past spring. I ran them at the same time as I ran the grey rims, and noticed no difference between them.
I believe Xenon is also releasing some new soft rims sometime soon, in the same colours, and these new rims were on display at AOC at Yatabe this past weekend.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-24-2014, 07:43 AM   #12
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Do you know if the Yokomo CRT tires are the same as the JFT C foam?
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is online now   Reply With Quote
Old 11-24-2014, 07:46 AM   #13
I have no idea on the CRT foams, have never ran them. However I have seen them advertised as Magenta/ Pink/ Etc... So Chances are they are the same as the A Type?
Thanks for the heads up on the wheels. I had not seen the white anywhere...
Old 11-24-2014, 08:22 AM   #14
CRT-S tires are like JFT C foam.
CRT tires are like JFT A foam.
Old 11-24-2014, 08:32 AM   #15
Hi,
Thanks for the input Christian.
Does anybody know the difference between Ulti Tyres X compound and the JFT C compound maybe the same foam from the same factory?
Claude
