Like Tree7Likes
Old 07-19-2016, 01:54 AM   #16
Trader Rating: 24 (100%+)
Bringing this back from the dead... Anyone have experience with the JFT S foams, and suggestions on which shore for the grey crc carpet? Was thinking of starting with 35/35?
fenton06 is offline   Reply With Quote
Old 07-19-2016, 02:11 AM   #17
antlockyer's Avatar
Both Dave Spashett and Ollie Payne used S35 front and rear at Chesterfield this weekend.
antlockyer is offline   Reply With Quote
Old 07-19-2016, 08:24 AM   #18
Trader Rating: 15 (100%+)
S35 fronts and S30 rears are a good combination to start with on the CRC grey carpet. If it feels like the car has too much steering, go to the S35 rears.
Fair warning - the S compound tires are incredible on the old CRC carpet.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 07-19-2016, 08:53 AM   #19
JimmyMac's Avatar
What class? 13.5 or 17.5 I would say Green rear and Blue fronts. In my testing BSR Green rear and Blue fronts were faster, but not all CRC grey carpet is created equal. We have since moved to CRC Black and the S compound works great.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 07-19-2016, 10:25 AM   #20
That's the goal!!!
Old 07-19-2016, 01:06 PM   #21
CristianTabush's Avatar
FWIW, at our place, on grey carpet the S compound does not work. They get too tacky.
However, the C Compound is magic. From my experience the higher the humidity, the less effective the S compound becomes.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 07-19-2016, 01:10 PM   #22
I am open to all options! I'm planning on ordering them from you, but I do not see the C foams on your site. What shore ratings for the C compound would you recommend Cristian?
Old 07-19-2016, 01:57 PM   #23
Jorge T's Avatar
JFT makes rear C25 yellow, C30 green and C35 light blue.
Front C30, C35 and C40 dark blue
I run mostly 13.5 and use C25 rear C30 front when traction is low on our old CRC grey.
Rear S25 yellow and frt C30 green work almost as good.
I also like A32 magenta fronts with S or C25 yellow rears or C30 when the bite comes up.
S30 or S35 will work for 6 laps and then get tacky and become undrivable, like C.T. posted.
RSD MS
Jorge T is offline   Reply With Quote
Old 07-19-2016, 03:07 PM   #24
C30 R and C35F works almost anywhere. If I was going somewhere, this is what I would bring. Question is what are the track conditions? Do tires get tacky? Does anything work at your track?
Old 07-19-2016, 03:09 PM   #25
Originally Posted by SLOWINSLOWOUT View Post
Do you know if the Yokomo CRT tires are the same as the JFT C foam?
Not from my knowledge. Jft C compound has only been available from JFT from my knowledge, even my Japanese buddy had never seen them before here. JFT is not very popular in Japan because they are expensive over there. Most people mount their own foam in Japan in his part of the country.
Old 07-19-2016, 07:34 PM   #26
My fastest lap times were on the CRC spec tires after being told they wouldn't work. I typically run CRC greylows in the rear and chromes in the front. My tires haven't gotten tacky as far as I can remember, but it's been awhile since I've been able to drive my 1/12 unfortunately. Looking to get a bunch of different tires and seeing what works!
Old 07-20-2016, 10:47 PM   #27
If you run Stock, don't get a bunch. Most races next year will be spec tire.
sdunnmcp is offline   Reply With Quote
Old 07-21-2016, 01:00 AM   #28
AFAIK, my normal track won't be running spec tires. Thanks though!
Old 09-10-2016, 12:47 PM   #29
JFT tire is not expensive tire in Japan. Actually it is one of low cost tire in Japan but Japanese RC driver is more to religious side. If you use Yokomo car then they use Yokomo tire, if you use CRC then they use Kimihiko tire because they follow Factory driver set up. Factory driver are like Guru in Japanese RC market
Teru is offline   Reply With Quote
Old 09-11-2016, 07:01 AM   #30
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
I see that JFT has released a new compound, the 'R'. Does anyone have any info on this? Still looking for a compound that works well, tried the 'C', and it just got very gummy, was great for the first minute, but after that, undrivable. This is for the grey CRC carpet, using SXT 3.0. Is there a different odorless sauce that works better with these tires maybe?
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
