HPI Sprint 2 slipper clutch conversion >
Old 02-02-2013, 07:57 PM
vxlmaster821's Avatar
Questions?? HPI Sprint 2 slipper clutch conversion
I would like to put a slipper clutch or slipper spur gear on my direct drive Sprint 2. When a pebble gets stuck in the transmission, I don't want it to harm the motor. Can anyone help me convert my sprint 2 from direct drive to slipper clutch or slipper spur gear?
vxlmaster821 is offline
Old 02-02-2013, 08:20 PM
Marv's Avatar
I have never seen a direct drive HPI Sprint 2...
Got any pictures?
Marv is offline
Old 02-03-2013, 08:24 AM
Hmmmmm... Maybe I have my rc terms mixed up.
Old 02-03-2013, 08:25 AM
Old 02-03-2013, 10:22 AM
Marv's Avatar
A direct drive would be something along the lines of what the Bolink Legends and the RJ Speed Legends use =
Not sure, but I think it's called a ball diff...
http://www.rjspeed.com/rjspeed/2010ex.pdf
Marv is offline
Old 02-03-2013, 10:28 AM
Marv's Avatar
Easiest way to keep pebbles out is:
A) Only drive on indoor tracks
B) Use a leaf blower & clear the area where you are going to play
C) Use a school tennis court that's been recently resurfaced but use the leaf blower also...
Out by where I live the shit heads tagged one HS tennis court so all in the area are now under lock & key so no one can use them...
OR you can...
Marv is offline
Old 02-03-2013, 07:34 PM
I plan to go rally driving.
Old 02-03-2013, 07:36 PM
Pebbles in the belt are nearly unavoidable with basically stock transmission when rally driving.
Old 02-04-2013, 08:17 PM
Bump?
Old 02-05-2013, 05:48 PM
I happened to be thinking of this earlier today and came up with a half theory as long as you are about modding parts to work...
This is the composition of a slipper clutch:
This is the slipper clutch assembly for the Traxxas Grave Digger:
Here is a different one in a nitro truck:
In theory all you need is the appropriate gearing and mod a shaft to work with the mid shaft of the sprint 2 yet hold the slipper clutch assembly together while spacing the motor slightly deeper in the mount(would probably need cut and an adapter plate made). Or mate the slipper clutch to a modded pinion with an e-clip like in the installed pic.
Slobalt7 is offline
Old 02-06-2013, 05:49 AM
Hmmmmm... So I just need to find a way to put a longer shaft in?
Old 02-06-2013, 08:02 PM
Seems that way but you ofcourse need to make sure you have the appropriate threading and spacing too. Spacing will probably be your biggest issue if you figure something out.
Slobalt7 is offline
