Tamiya TT02 Thread
#1036
oh, that is a bummer ...
Do you know if something like this would work:
http://www.rcmart.com/yeah-racing-tt...h=595_744_1585
worst case I just take the dremel to the current plastic part that hangs off the back ...yet was looking for a cleaner solution.
#1037
Eric - thanks for the links to these wheels and tires. Love the look of the 6mm offset under this body!
#1038
-I was hesitant at first ...but they seem to be as good quality as name brand wheels i've purchased. I actually went ahead and bought more in other styles. For the rubber I am sticking w/ some brands that I am familiar w/ and are true and tested (hpi and assosciated treaded ones).
Your body looks fantastic!
I may have to pick one of those Tamiya kit bodies up.
Still working on my TT02 build and body ...soooooon. (also prepping for my next race on the weekend). -hence why i haven't had much time on this build as I'd like.
#1039
Steve_pss, ...did you paint that body? If so I like how you did the red and black.
#1040
After spending many (many) hours putting all the decals on (the hood itself is like 20 decals) I wish I had painted it. The black is actually a dark grey metallic (shows up nice in the sun). Splitter and other parts are straight black. The rest is all a hair dryer, windex and a sh*t ton of decals supplied with the kit.
#1041
the decals look really nice, good work.
#1042
Originally Posted by eR1c View Post
Nope, my kit didn't come w/ the hardened parts (lighter grey color).
I ordered the TT-02D type S kit. ...it came w/ a lot of goodies, but not the hardened parts.
So, I am going to order that part, ...going to hunt it down. (I hate the large bumper piece sticking off the back).
It will not fit on the type-S as you have a different arm mount holding the suspension pins.
#1044
#1045
Your looking some kind of protection for the chassis area?
what about using a pair of black nylons ...just cut both ends and wrap around the chassis.
#1046
Since the weather will be hotter (here in Southern Italy temperature is 30-35°C), I'm thinking about installing a motor heatsink. I check motor temperature every 5 mins with an IR thermometer and I read about 40-50°C. Do you think I'll need an heatsink? Is it normal that it is hotter near the pinion?
#1047
if you are driving it in the street your ESC fan shouldn't need extra protection
In my tt02 I ran a 9t motor geared around with a 22 pinion. If you're concerned put on a heatsink + fan for it. You can get many from Rcmart. When I took my TT02 for rally on an off road track from memory it stayed around 60c with air temp in the low 20s within a 10 minute run.
I've never had issues with the ESC fan get caught with debris etc. Only had a fan die on me probably from shock when I ran indoor 4wd mod buggy... (the buggy hit the wall many times)
#1048
okay, so this isn't complete, ...yet wanted to get a few photos up of my work in progress TT02.
I plan to put side mirrors on, an exhaust and a driver figure.
stay tuned.
stay tuned.
#1049
The TT02D Type S and TT02 Type S have identical suspensions, look at the regular TT02 and TT02D manuals and you'll see they're much simpler than the Type S variants.
#1050
