Old 09-29-2014, 11:53 AM   #496
Manny's Avatar
The TT02s looks really nice. They have more detailed pics on Tamiya Blog. It looks like it doesn't use the LW suspension droop adjustment. Maybe so they don't over complicate the adjustments or a way to sell an optional bottom plate?
Manny is online now   Reply With Quote
Old 09-29-2014, 02:52 PM   #497
You can always do that by adding spacers in your shocks to limit its travel.
Tamiya - Awesomatix - Orca - Orion - LRP - Protoform - Sanwa - Futaba - NASA - Ride
Minami is offline   Reply With Quote
Old 10-01-2014, 02:51 AM   #498
miles514's Avatar
new suspension system for TT-02S
Tamiya TT02 Thread-bybnyvlciaavxku.jpg   Tamiya TT02 Thread-bybnzsscuaev-yz.jpg
AE SC10 FT, RC10 Worlds Car, 3Racing Cactus, HPI Rally, Tamiya MF01X Jimny, Tamiya M05 Pro V2, Tamiya group C, Wild Willy 2, CC-01 Bronco, F103 Le Mans, F104Wgp, Subaru Brat, Wild One, Sand Scorcher.
miles514 is offline   Reply With Quote
Old 10-01-2014, 03:17 AM   #499
TB03Racer09's Avatar
It looks like Tamiya is trying to get rid of their older trf416 style suspension parts by chucking them on the tt02.
TB03Racer09 is offline   Reply With Quote
Old 10-12-2014, 01:11 PM   #500
David Home's Avatar
Questions?? TT02 Gearing
Is it possible to fit the TT01 55t spur to a TT02? Trying to get my TT02 to have FDR of 5.70. Any help much appreciated. Thanks
David Home is offline   Reply With Quote
Old 10-14-2014, 12:52 PM   #501
asw7576's Avatar
Yes , it is possible. Please read page 2 to 7 again .... you will find some creative racers who use TT01 55T spur gear into TT02. You need removing some materials from 55T in order to fit into the gear shaft.
Old 10-15-2014, 05:46 AM   #502
miles514's Avatar
can I use this part with my TT-02 without any binding? just to make sure before I order.
http://www.rcmart.com/tamiya-assembl...2-p-11703.html
also this one
http://www.rcmart.com/tamiya-toein-r...73-p-6823.html
thanks!
Old 10-15-2014, 10:52 PM   #503
Tamiya matching guides Says yes. You'll need the smaller gearbox out drives too.
I've tried eagle racing TT01 uni's in mine - some fitted and some did not but that was depending on length / how much camber you run with.
Many sellers on eBay have the universals sold under both TT01 ans 02 as well.
I don't think the rear uprights will fit though, the design is too different. I'm using yeah racing rear toe-in uprights and am very happy with them.
Hope that helps.
Cheers,
Crouch
Camocrouch is offline   Reply With Quote
Old 10-16-2014, 04:28 AM   #504
miles514's Avatar
thanks for your fast reply Sir Crouch.
I ask about the rear upright because I've already converted my rear upper arms into adjustable turnbuckle type.
btw what angle of yeah racing uprights did you use?
Miles
Old 10-16-2014, 09:35 PM   #505
No worries Miles.
Given that your using upper turnbuckles there's a chance the lower attachment points might fit (sorry, don't have a TT01 to check) but there's the additional difference that with the TT02 the rear uprights are reversible to give you different ride heights, so you could run into issues there.
With the upper turnbuckle attachment, I've toy'd around with getting a set of adjustable (for camber) upper arms and then using a turnbuckle-end to attach it to the chassis, thus allowing the use of normal uprights but with a ball end attachment to the chassis. Not sure if that's something to consider.
Also worth noting that the yet to be available Type S may provide some additional options.
My YR rear uprights are 2 degrees. I don't have much experience to compare it to but they were a good change from stock.
Cheers,
Crouch
Old 10-17-2014, 04:57 PM   #506
miles514's Avatar
noted Sir Crouch! now Im gonna edit my rcmart cart. Thanks!
Old 10-18-2014, 03:27 AM   #507
JohnyT's Avatar
I've had a couple of evenings on the track with my TT-02D and one of the front knuckles have cracked already. Didn't take much of a knock to do it. I'm wondering if the grey A parts that come with the 'D' are weaker than the standard black parts.
Think I'll be using aluminium ones from now on.
JohnyT is offline   Reply With Quote
Old 10-18-2014, 03:54 AM   #508
I'm pretty sure that your steering block broke on the underside of the steering block, am i correct?
To avoid that i've done the following.
I build my TT-02 as a rally version, meaning that you flip the rear uprights upside down and at the front replacing the spacer from the bottom to the top of the steering knuckle.
This can be done along with some TRF mini dampers or with some super mini cva dampers.
So far i haven't broken a standard steering block anymore, it's because of the spacer that sits for onroad racing bellow the steering block that it brake's to easily.
It's causing a weak spot to the steering block, that's just my experience with the TT-02 steering blocks.
Just my 2 cents opinion
addicted2blue is offline   Reply With Quote
Old 10-18-2014, 06:16 AM   #509
JohnyT's Avatar
Here's a shot of it. I think it ties in with what your saying. The break is exactly round that spacer.
Old 10-19-2014, 10:27 AM   #510
Everyone that has broken a steering knuckle from a TT-02 looks Always the same as your broken one.
That's why i changed it.
SEO by vBSEO 3.5.0
