Like Tree10Likes
Old 08-27-2014, 04:55 PM   #466
Originally Posted by Mitamiya View Post
I am hoping it is a TT-02 Sport and includes the ball bearings and other bling like oil filled shocks and maybe an aluminum shaft or other blue goodies.
I hope so too but then they already have the drift spec with those items... Doesn't make sense to closely align them so I think this model could either have significantly more, less or different to the drift spec...
Cheers,
Crouch
Camocrouch is offline   Reply With Quote
Old 09-06-2014, 08:17 AM   #467
Slashracer1998's Avatar
Default What to order?
Ok so I'm almost 100% positive that I'm going to get a tt02. I'm just not sure exactly what I need and should get right away. I plan on mainly using it for drifting (I know I need drift tires) and driving it around with my buddy. And maybe I might try racing once or twice, but not for a while at least.
I plan on getting this edition of it (On ebay it is $130 shipped for me from R/C Mart instead of about $143)
http://www.rcmart.com/tamiya-58566-t...c-p-36974.html
A kimbrough servo saver (from ebay $7 shipped)
http://www3.towerhobbies.com/cgi-bin...&I=LXND49&P=ML
A futaba S3003 servo (again from ebay $6 shipped)
http://www3.towerhobbies.com/cgi-bin...&I=LXH288&P=ML
^Sorry I couldn't give the real item links. Look at the prices I listed. That is how much I have to pay. I just didnt want the ebay links to expire.
Then from AsiaTees I plan to get
GPM steering Tie-Rod Set
http://www.asiatees.com/display?id=7...ya&model=TT-02
Boom Racing Bearing Set
http://www.asiatees.com/display?id=6...ya&model=TT-02
and the low friction step screws
plus $6 shipping from Asia tees.
Is there anything else I should get right away or anything I don't need? Thanks for all of the help guys.
Race: 3 Traxxas Slash 2wd, Sc10 2wd, Team Associated rc10l oval, Silva Concepts X-Factor (rc10l4 oval), Maverick '04 chassis, F-14 Tomcat, F-14 Classic, RJ Speed Spec Mod
Other: Traxxas Stampede 2wd
CHECK-IT RACING
Slashracer1998 is offline   Reply With Quote
Old 09-06-2014, 04:02 PM   #468
Djchow85's Avatar
Locked diff for drifting?
If racing get a damper set, I'm using a 55mm set from yeah racing
You may want to get better traction so find out the ideal tire needed and you may want various shock oils for fine tuning.
Djchow85 is offline   Reply With Quote
Old 09-06-2014, 04:48 PM   #469
Thanks Dj. I didn't even think of that.
CHECK-IT RACING
Old 09-07-2014, 01:21 PM   #470
Hi,
Can anyone confirm the dampers on the tt-02d are indeed 50746, the 50mm ones? I read this somewhere but the seem quite long on the stock photos.
Thanks,
Hugo
HugoW is offline   Reply With Quote
Old 09-07-2014, 01:38 PM   #471
Originally Posted by HugoW View Post
Hi,
Thanks,
Hugo
They are the correct ones, they are the super mini dampers.
All other damper versions are to long.
addicted2blue is offline   Reply With Quote
Old 09-07-2014, 08:04 PM   #472
[url]http://www.rcmart.com/tamiya-58566-tt02-mercedesbenz-wesc-p-36974.html
I'd consider getting the drift spec chassis and a separate body if you can.
The drift spec will have your bearings, oil shocks, etc already, plus a faster motor. It might even have a smaller pinion suited for delivering the power earlier.
The supplied drift tyres are a good starting point too.
A rear diff locker as DJ suggests is also good.
Have fun!
Crouch
Old 09-09-2014, 03:34 AM   #473
Djchow85's Avatar
After not doing any rc for about a month my rc fun factor was dropping. I had just ditched some crusty bearings and got some after a two week wait, they were missing 1x 1050 bearing but lucky I had 2 decent spares!
Inspired by addicted2blue and the help of Qatmixs blog I went for some weight reduction. I've shaved off at least 100g using a shorty and will go back to my lancia body, lot easier to navigate at my local track.
-switched to tt02d knuckles
-car runs lot straighter as my previous rubber bearings were uneven, drag on one side.
-will set it to 0degree toe for indoor
-car feels quite punchy but also because the shorty is 65c discharge vs 40c and lighter too. Bearings may have also helped.
-opted for velcro to hold down the battery, the stuff from hobbyking is strong! Didn't want to dremel or use battery tape to go for the cheap option even though shoe goo holding down the velcro may have added another 50gm. Last night took over 10seconds to separate the battery from the velcro, not sure if it was due to it warming up etc but I was trying to traction roll the car to see what if it would stick. I'm confident the battery will stay put.
- car weighs 1200gm with all electrics. Will look forward in testing it with a lighter TC body.
Aim: beat a mate running a 6.5t in a serpent 411 while I use my 9t tt02. Will be challenging I think.
Old 09-11-2014, 12:08 AM   #474
TT02- S Cad pic
http://www.thercracer.com/2014/09/ta...-high-res.html
Looks like they have also fitted the Tamiya LW suspension etc much like some of the third party kits in Japan.. Excellent
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-11-2014, 01:16 AM   #475
Originally Posted by Qatmix View Post
TT02- S Cad pic
That looks promising, the suspension arms look like the long type reversible suspension arms.
I also think there is a new suspension mount for the rear and front
This will definately improve the performance and handling of this chassis.
Old 09-14-2014, 09:50 AM   #476
MD
MD's Avatar
Trader Rating: 106 (100%+)
We'll be running a TT02 in a 4 hour endure. Do think the kit motor will get too hot with the cover over the motor?
MD is offline   Reply With Quote
Old 09-14-2014, 09:50 AM   #477
MD
MD's Avatar
Thanks.
Old 09-14-2014, 11:13 AM   #478
I would remove the plastic cover and fit a fan on the motor to keep it as cool as possible.
Also check the running gear is free I would shim the diffs as it makes a massive difference.
Here are some tips
http://www.thercracer.com/2014/08/ta...-and-tips.html
As an aside, got back from racing the TT02 today. (I race it outside in a Summer championship), and I managed to get FTD and also claim the win by nearly a lap.
Old 09-14-2014, 11:43 AM   #479
MD
MD's Avatar
Here are some tips
Thanks for the advice. In this enduro we are building the car at the track and then racing. There are restrictions on changes you can make. I wish there was a TT02 series in our area. It would really keep racing costs down. Congratulations on your win.
Old 09-14-2014, 01:58 PM   #480
I wouldn't even do the efford of mounting that motor cover/fan mount.
This will get the temps of the motor higher then normal.
Depending on motor type it's even better to mount a fan behind the motor, this is more effective to cool the motor then a fan above the motor.
But this depends on type of motor you are going to use.
If you are using a standard kit supplied silvercan mabuchi motor it's better to cool the motor on top of it, but when using a silvercan johnson motor then it's more efficient to cool the motor from behind.
Cause the fan is able to blow directly into the motor wich keeps the motor cooler.
When building the car make sure you have a set of 5mm shims to use for the the suspension arms (lower&upper) and for the wheel axles to remove some slop.
And make sure you mount the carton motor plate between the motor and motormount, especially for endurance racing.
