Like Tree12Likes
Old 05-01-2014, 10:14 PM   #316
Djchow85's Avatar
Originally Posted by CapTob View Post
It has alot of tamiya hop-ups. But it could't help completely fixing the steering slop.
is the issue that it doesn't run straight on full throttle?
im new to this as well but one interesting thing I found was using rally blocks vs on road tires is that the difference in trim was +6 points. I assume only that the blocks are a tad wider hence the need for extra trim...
Have you also added shims? I've added them as well to the front wheels which reduces play...
Djchow85 is offline   Reply With Quote
Old 05-02-2014, 01:12 PM   #317
A little bit of steering slop is fine, I have a lot of cars and they all have some slop (even the top end cars) My TT02 has the aluminium arms and I shimmed it a little and I have very little slop now, its precise and sharp on the track.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-02-2014, 04:17 PM   #318
Okay thank you for the informations.
I bought the Carson steering set... but it was crap so I put back the stock one but with the Tamiya 54550 Low Friction Screws. Fixed a little play.
Then I noticed play on every tire. Basically, there is play between the shafts and the rear and front uprights. So I bought aluminum front and rear upright, but it still didn't fixed the problem...
So I bought nylon shims to put between the outer shaft bearing and the small metal "stick" that holds the bearings in place... Breaks my tire so that the car won't drive anymore... Put a lot of grease and now it's okay.
3 more posts and I will be able to show you nice pics of my yellow Lancia and every piece that has slop or play.
Thanks a lot guys. One day I'll fix this with your help.
CapTob is offline   Reply With Quote
Old 05-02-2014, 11:57 PM   #319
You can shim the axle movement with Tamiya shims you need Tamiya 53586 4mm Shim Set. You only need a few between the axle pin and the bearing. You can also put them on the inside of the axle at the base of the axle going into the inside bearing. you still want a little movement to ensure they spin freely.
Old 05-03-2014, 01:21 AM   #320
Thank you very much for the Tamiya shims Reference, I'll order them right now. As I told before, I put 9mm Nylon shims between the axle pin and the bearing but they really break each wheel.
Do you guys feel like there is play between the shafts and the front and rear uprights? I mean that the axle are slightly to thin for the bearings?
A few more posts and I'll show you with pictures and co.
Old 05-03-2014, 01:59 AM   #321
No, I have no movement between the axles and the bearings, the shimming will help.
remember though, a little bit of movement is fine, a car with no slop is usually binding or shows up any other minor imperfection in the rest of the components.
Old 05-04-2014, 01:53 PM   #322
Default Has anybody purchased the TT-02D?
It comes without a body but that's okay since I'm not totally happy with the rally based body choices in kit form.
djfourmoney is offline   Reply With Quote
Old 05-04-2014, 03:40 PM   #323
Djchow85's Avatar
Has anyone upgraded their front knuckles to aluminium ones? After about 25 or so cartwheels/front flips, face plants of my tt02 I've finally busted my left front knuckle... i've opted to order the standard parts as they're cheap.. but thinking now maybe I should've gone aluminium ..
If so has anyone had issues of the aluminium knuckles bending under stress from bashing etc?
Old 05-04-2014, 11:59 PM   #324
Currently I have been using the reenforced plastic ones. These are on the a parts sprue for the TT02D you can buy the A sprue separately. It's well worth it as you get a lot of the key components (steering, towers and hubs) all in the harder plastic.
I have also bought the aluminium front parts from jaz hobby on eBay. They seem good value but they are in my spares bundle atm as I prefers plastic where possible.
If rallying then I would have no problem swapping the out to these parts.
Old 05-04-2014, 11:59 PM   #325
If rallying then I would have no problem swapping the out to the alum hubs.
Old 05-06-2014, 04:47 AM   #326
Djchow85's Avatar
Wouldn't have thought they'd change the plastic just for d spec!
Old 05-06-2014, 06:19 AM   #327
Only the A parts, they are very good.
Old 05-06-2014, 03:47 PM   #328
Djchow85's Avatar
yeah i got the jaz ones. They were the cheapest and included the collars etc which the others don't!
I'm already eyeing a buggy for xmas... good learning experience since the tt-02 is my first!
Old 05-14-2014, 09:20 AM   #329
Smile's Avatar
Do you have a part number for those by any chance?
Smile is offline   Reply With Quote
Old 05-15-2014, 01:47 AM   #330
Part number is 19000614
Saying that I have just broken one of the front hubs (Although I whacked a board at full tilt)
Basically it comes with harder plastic versions of the towers, upper bulkheads, Front and rear hubs (and spacers) and it also comes with the steering arms. So most of the key parts you want to be stiffer are there.
You will still need to file down the limiters on the front uprights if you want a lot of lock though.
I am now going to try the Jaz hobby hubs to see how they work.
