Like Tree64Likes
Old 02-26-2014, 05:32 AM   #286
bigfatslob's Avatar
So similar to the TT01, I guess Tamiya felt the need to freshen up its entry level chassis. I suspect that soon it will have comparable levels of bling available. Nice Ferrari body but, I've also seen it with a Zakspeed Capri body ! http://www.sussex-model-centre.co.uk...peed-Capri.jpg http://www.majhost.com/gallery/bigfatslob/cars/1.jpg
Vintage is the way we roll : XXXS & TT01
bigfatslob is offline   Reply With Quote
Old 02-26-2014, 05:50 AM   #287
Originally Posted by ic-racer View Post
Starting to get a little frustrated with the TT02 I'm setting up for my 8-year old. The problem is we are making this a waterproof rain car because we have so many cars (mostly Tamiya) that we wanted to try something different.
I replaced the stock servo saver and thought that would cure the car's tendency to not go straight.
But, I had the car out yesterday in the driveway testing it for my son and it still veers off course unexpectedly.
The problem is I want to KEEP the nylon and plastic parts! Maybe I'm asking for the impossible. I'll update if I can find some solutions. Maybe ball bearings that are really sealed from water. Or what about ceramic? Are they waterproof?
Hi,
I had the same problem on my Lancia Delta TT-02. Fixed it doing the following:
1) Reduce steering servo course. (from 100% to 66% in my case)
2) Put a 3mm piece of well greased sillicone hose between the dog bone and the shaft of each wheel to reduce slop.
3) Enjoy !
I'm not allowed to put URLs cause I'm new here, otherwise I would have shown you pics of my TT-02 Lancia Delta tweaks.
Tamiya's TT-02 is a great car. I mounted a Brushless Neon Combo 17T on it which gives me a lot of fun on and off-road (I bought two sets of tires, one for each surface)
I'm planning to buy the HPI BMW 2002 shell. Will it fit the TT-02? Any adjustments needed? Special Rims? How much offset?
Thx in advance.
CapTob is offline   Reply With Quote
Old 02-26-2014, 06:04 AM   #288
Originally Posted by CapTob View Post
Hi,
3) Enjoy !
Thx in advance.
The HPI bmw2002 won't fit the TT-02 chassis, cause it's for an m-chassis and the wheelbase is only 210 or 225mm and that's to short for a TT-02. Plus it will be to narrow to.
addicted2blue is offline   Reply With Quote
Old 02-26-2014, 10:09 AM   #289
Ok, fine. I'll never get this size thing. Would the Hpi DeTomaso fit then?
Old 02-26-2014, 01:21 PM   #290
Djchow85's Avatar
the wheelbase is the distance between the front and rear wheel? It's explained in the instructions?
The TT02 can be adjusted from 251-257mm... do you know the wheelbase of the DeTomaso? And even so, what's the width?
I put on a 180sx body (for drifting later) which had a wheelbase of 260mm... it fits.. but its a wider body so its a bit awkward looking...
Djchow85 is offline   Reply With Quote
Old 02-26-2014, 02:01 PM   #291
DeTomaso Pantera's sizes AV.200mm/AR.210mm/EMP.255mm (front, rear, wheelbase)
TT-02 is 257mm, the 2mm difference won't be a problem right?
Edit: Found a website telling me to put 0mm offset in the front and 6mm in the rear...
Old 02-26-2014, 06:07 PM   #292
Djchow85's Avatar
Yeah it fit ok. Im waiting for my te37's to add to it.
Has anyone taken their tt02r to an off road track? Do you feel the rally tyres are sufficient or are lacking? Im wondering if anyone knows of any alternatives
Old 02-26-2014, 09:43 PM   #293
I ran in a forest on wet ground with leafs. Rally tyres were at the limit of their potential, hard to keep on the small paths you can find in a forest. I mostly run on snow, it's just absolute fun.
I recently bought the Kyosho DRX TRT21 tyres, I'll try them out soon and give a feedback.
Any good advice for tyres, I mean generally?
Old 02-27-2014, 12:24 PM   #294
Djchow85's Avatar
banzaihobbys has quite a range. Just don't know what's good
Old 02-28-2014, 07:03 PM   #295
Djchow85's Avatar
For the TT02R owners, has anyone used these?
http://www.ebay.com/itm/Kyosho-OEM-R...item51ab7934ba
Wondeirng how they compare to the tamiya rally block tyres for off road racing?
Also has anyone also used the generic rally tires from chinese sellers on ebay such as ...
http://www.ebay.com/itm/4PCS-Rubber-...item27d6184052
Old 03-03-2014, 01:59 PM   #296
Djchow85's Avatar
i ordered some speed mind soft rally block tyres from dinball/rcmart. Will post back with a review
Old 03-09-2014, 04:25 AM   #297
Hi Guys,
I'm in the middle of making a very tuned TT02 with some custom parts. I also managed to try out the new steering step screw hop-ups.
http://www.thercracer.com/2014/03/ta...tion-step.html
They are not as awesome as the steering set, but they are so cheap they act as a good upgrade if you do not want to spend the cash on the aluminium steering set-up.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 03-09-2014, 04:48 AM   #298
that looks good. I think I will add them on my list of new parts to upgrade my car.
Also I have been running the TT02 against some friends. I will be racing it soon at a local onroad club. The car has the kit motor, should I leave that in and get used to the track or should I buy a new motor? I did use to race but that was a long time ago.
shaftboy is offline   Reply With Quote
Old 03-10-2014, 05:55 PM   #299
Thanks for the reply. My TT01 is great also, so I'll go back over the TT02 looking for problem areas. It is basically acting like the servo saver is still bad but I have a metal TRF servo saver on it.
Found the problem. When building the TT02 I thought I'd take the play out of the steering by over tightening the plastic balls; squeezing them to make them expand. This was a bad idea because it caused binding in the steering. All is good now that I have loosened it up.
We had it out in melting snow and had a great time with it. It has a waterproof Traxxas servo, and waterproof XL5 speed controller and waterproof Traxxas radio box. I just washed the car off under running water when we were done for the day.
ic-racer is offline   Reply With Quote
Old 03-10-2014, 11:07 PM   #300
Djchow85's Avatar
is anyone still using the stock servo? I'm having no issues with it.. or maybe there could be a lot more potential with the high torque servo saver which I tried to setup but failed.
Im using the yeahracing adjustable tie rod and my trim now is at 4 points to the right out of 30 (used to be about 20 with the stock part!)
