Old 02-03-2003, 06:47 PM   #1186
fasterdanu's Avatar
hey guy's does anyone know if a company makes sway bars for corally c4.1's or if you ve made your own hybrids what part's did you use and how i want to try some out and have a play with see if it makes me any faster
fasterdanu is offline   Reply With Quote
Old 02-03-2003, 11:07 PM   #1187
Cookie's Avatar
Firstly: No! There aren't any Corally or aftermarket sway bars available.
I have found that the car doesn't really need sway bars when running on foam tyres. I didn't run any at the Summer Nats and I believe that both Ari and Jakey took theirs off or went to a soft bar.
But if you are keen to make some still then talk to Ari or Jake or get some photos of their cars. I think they used some TA03 parts and various turnbuckles etc ...... they looked good though.
Cookie is offline   Reply With Quote
Old 02-04-2003, 12:22 AM   #1188
fasterdanu's Avatar
thanks andy i'll look into it futher have you seen what jakes done to his corally i heard that he shortened the wheel base a little i would of thought it would have been easier to just pick up one of the c4 euro edition's a much shorter wheel base they go for 300 dollars i have one and there very good indors on a small track but the momnt you start going down to 10's 9's and 8's on a fast track it becomes a little twitchy but you can pick it up a little on the infeild like at the eastern creek nat's although i didn't use it there
hey mabye if jake read's this post he can tell me what he's done to it
Old 02-04-2003, 02:05 AM   #1189
Fasterdanu - who is this?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-04-2003, 03:46 AM   #1190
che
che's Avatar
Good Luck to all the Corally drivers who are able to make it to Snowbirds this week!!
che is offline   Reply With Quote
Old 02-04-2003, 11:53 PM   #1191
Cookie's Avatar
The wheelbase mod I developed a few months back and told Ari and Jake who both tried it and liked it (I think!)
The idea was not solely to simply shorten the wheelbase. The C4.1 is an improvement on the C4 euro so it would be rediculous to use an old car for this reason!!
The real reason for changing the wheelbase is in the static weight distribution. Most people who have shortened the C4.1 wheelbase have moved the rear arms forward but what this also does is move the weight distribution more over the rear wheels and away from the front, which is a bad idea I reckon when more on power and high speed steering is desired!
What I did was move the front arms backwards so that the weight distribution is moved more over the front wheels.
By moving the arms back ~6mm the weight dist. becomes about 50% front/rear which I found was way better on the track. The kit layout/wheelbase before this mod leaves about 30 grams more on the rear end than the front, this is about a 2% change but seemed to make a big difference to the steering ability of this car.
BTW I have taken some pics of my car including this mod so hopefully will get them sorted and formatted and on my site soon.
Old 02-04-2003, 11:59 PM   #1192
fasterdanu's Avatar
Originally posted by Besercoe
Fasterdnu - who is this?
my mum say's never talk to strangers and never tell them your name
put it this way i race mod got a gold car (at the moment) and like corally's alot
Old 02-05-2003, 12:07 AM   #1193
fasterdanu's Avatar
so andy did you just file back the rear of the arm then use the same spacers that are used for adjusting castor and stick one or two at the front that way when you want to change back to the original you just slip the spacers behind the arm. (hey that wasn't to hard to figure out )
1 question because the bottom arm where the shock is mouted has been moved back should the shock be left alone or should it have a couple of washers put in front to keep the same geometry.
2 will his also adjust the amout of castor you can and can't get
Old 02-05-2003, 09:18 AM   #1194
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
With the pan cars, and that "bag of goo" (at least thats what RCCA called it) is there supposed to be like a cover you put on it or something? just curious. btw, check out my avatar (its Speedy Cerviche from Samurai Pizza Cats)
trackdesigner71 is offline   Reply With Quote
Old 02-05-2003, 09:29 AM   #1195
LouisB's Avatar
Yep, there are 2 rubber boots. It still attracts carpet fluff though!
LouisB is offline   Reply With Quote
Old 02-06-2003, 12:04 AM   #1196
Cookie's Avatar
faster -
Basically yes. I actually cut the rear portion of the arm carefully and used this as the spacer but the castor spacers would do the same job, probably better.
I also cut the rear off the top arm as well so the castor adjustment remains the same.
1. I placed some spacers between the bottom of the shock and the arm so the shock angle remains the same.
2. Given what I said above the castor adjustment remains the same. I try to run about 4 degrees usually.
Note: The droop tab on the right lower arm has to be removed to clear the diff pulley, and the droop screws would now miss the cross tube anyway, which means droop adjustment must be achieved by other means.
Old 02-06-2003, 12:34 AM   #1197
johnbull's Avatar
Hi guys. Greetings from Malta.
Another weekend of total Corally domination in the 8th round of the National championships.
Beginners Stock Class - touring cars 190mm:
1st Jean Vella - Yokomo MR4 using Corally motors and cells.
Pro stock Class - touring cars 190mm:
1st Joe Anastasi (that's me) - Yokomo MR4 - Corally motors and cells.
Modified Touring cars 190mm:
1st Joshua Anastasi (my son) - Associated TC3 - Corally motors and cells.
A bit of a clean sweep, don't you think.
Josh now has 8 wins from 8 starts this season and leads the Malta championship comfortably.
With my 4th win this weekend I too have extended my lead in the Pro Stock class.
Still a long way - 7 rounds to go.
regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 02-06-2003, 02:26 AM   #1198
LouisB's Avatar
Has anyone seen these pics?
Old 02-06-2003, 05:19 AM   #1199
johnbull's Avatar
Strange that Corally UK should have these pictures on their site even before the actual factory site in Holland.
Nevertheless, what a beauty. Corally engineering is still the ultimate.
Point is - will it assasinate!!!!!!!!!!!
Regards
Old 02-06-2003, 08:20 AM   #1200
Default <<<<<<<<<>>>>>>>>>>>>>>>>
Thanks for the link we have not had a chance to see the new updates on the car. The updated parts where not available in time to get them to Corally USA to run at the Snowbird Nationals. Rob made a few adjustments on his own and had some sway bars made for his prototype. I watched him in one of the practice heats last night and his car was very fast and cornering very well. He was running 19t spec with the direct drive set-up.
ECHOLogic is offline   Reply With Quote
NEW CLUB OPENNED IN SOUTH AUSTRALIA - NORTH EAST MODEL CAR CLUB VintageFrog1 Australian Racing 2226 08-17-2009 04:47 PM
ATTENTION CORALLY RDX OWNERS hotwheels1 R/C Items: For Sale/Trade 2 08-22-2006 08:26 PM
club vs club race at larry's coming soon!!! al jones Racing Forum 5 07-05-2003 12:11 PM
Corally owners octavio Electric On-Road 1 05-15-2003 06:30 AM
Aussie Corally Owners... black-knight Australian Racing 25 03-30-2003 01:19 AM
