Old 05-16-2002, 08:51 PM   #841
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by shrekair
can u guys post the setups ur currently running w/?
Track: Asphalt / 26 degrees ambient temp
FRONT:
White spring, 40 wt oil, 4hole piston, position 2 on front tower
5 mm ride height
0 toe out
2 deg camber
7deg caster
Tires: 40deg Eagle Foam / or Jaco Purple/Orange 24mm
REAR:
White spring, 40 wt oil, 3 hole piston, position 5 on rear tower
5.5mm ride height
2 deg toe in
2 deg camber
camber position 1
0.5 deg antisquat
Tires: 37deg Eagle Foam / or Jaco Double Purple
Other info:
split top deck
front oneway diff
smooth rear diff
layshaft oneway locked up
transponder up front
no re-active caster
steering block pos 1
New Protoform BMW M3 Coupe body (2 door) mmm...
rtr weight c1505g (without transponder)
Motor: Orion Core 10x3 / Orion 10-30 41007 brushes
Rollout: 27.25mm
Cells: Corally SMH / Ultra Metal - 5amp, 10mv cut off.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 05-16-2002, 08:56 PM   #842
for more good information on the Corally have alook at www.cookieitsallgood.com this is Andrew Cooke's website, Cookie is currently at the Worlds racing with (or against) the other Corally guys, and no doubt having fun!
Old 05-16-2002, 09:11 PM   #843
Avink1's Avatar
Send a message via AIM to Avink1
Does anyone have a set-up for the C4.1 on ozite carpet with rubber tires and a stock motor? That would be a lot of help, thank you.
Avink1 is offline   Reply With Quote
Old 05-18-2002, 12:12 AM   #844
ahibj8's Avatar
Default Setups
At the moment my set up for a tight Concreate orTar track very dirty and no surface prep
Front Plastic body
Orange spring, 30w, 4 hole open, top Hole 2, lower 1
Toe in 0deg, Caster 2mm, Camber 1 deg, width 190mm
Rear Plastic body
White spring , 30w, 4 hole open, top hole 5, lower 1
Toe in 2deg, Camber 1.5 deg, width 188mm
inner Camber location 4, shock tower B
5mm front/rear ride height, next run up to 6mm in rear
Rear anti squat 3deg
center one way approx 70%
Take off cs27 all round, Take off medium insert
I have the new Corally tyres not used yet
HPI Stratus shell
1995 Trinity Midnight stock 27t 24deg LOL still going strong (well untill the new Core motors get here)
DaDaDaDaDa
Scottj
ahibj8 is offline   Reply With Quote
Old 05-18-2002, 05:24 AM   #845
Default Re: Setups
Core stocks are in so hassle uncle G.
Old 05-18-2002, 07:36 AM   #846
I'm currently building my new replacment C4.1, i'm trying afew new things with this car, can anyone spot a change?
Old 05-18-2002, 04:32 PM   #847
ahibj8's Avatar
uncle G I will call you on Monday :-)
Scottj
Like the shocks on the on the new car :-)
Old 05-19-2002, 04:29 PM   #848
shrekair's Avatar
Trader Rating: 9 (91%+)
tc3 shocks huh?
shrekair is offline   Reply With Quote
Old 05-19-2002, 06:48 PM   #849
Who/Where was the top finishing corrally touring car?
Besercoe is offline   Reply With Quote
Old 05-20-2002, 01:22 AM   #850
Corally at the worlds;
22 Sakke Ahonneimi
24 Simo Ahoneimi
47 Andrew Cooke
there was atleast one other Corally but i forget who was driving it???
Old 05-20-2002, 01:24 AM   #851
tc3 shocks huh?
yep they work well and i feel the respond better to spring changes.
Old 05-20-2002, 02:43 AM   #852
ahibj8's Avatar
Cool
How close are the springs to the Corallys, could you use them ? The uneven spring lengths are what bug me LOL in this day and age you would think that Serpent would do some quality control on them
Old 05-20-2002, 03:33 AM   #853
you can use Associated or Yokomo springs without issue, gives you a much wider choice.
Other possibleoptions are:
Serpent pre-tension springs: http://www.mytsn.com/products/desc.asp?prid=2226
and
Non adjustable pistons (needs new keyed shafts)
http://www.mytsn.com/products/desc.asp?prid=2385
Old 05-21-2002, 06:46 AM   #854
my new c4.1 95% complete...
Old 05-27-2002, 11:05 PM   #855
ahibj8's Avatar
Thanks for the info Black Knight, I am going to use Associated springs on the 4.1.
Gee are we quiet or what LOL :-)
NEW CLUB OPENNED IN SOUTH AUSTRALIA - NORTH EAST MODEL CAR CLUB VintageFrog1 Australian Racing 2226 08-17-2009 04:47 PM
ATTENTION CORALLY RDX OWNERS hotwheels1 R/C Items: For Sale/Trade 2 08-22-2006 08:26 PM
club vs club race at larry's coming soon!!! al jones Racing Forum 5 07-05-2003 12:11 PM
Corally owners octavio Electric On-Road 1 05-15-2003 06:30 AM
Aussie Corally Owners... black-knight Australian Racing 25 03-30-2003 01:19 AM
