Old 11-15-2001, 07:19 AM   #391
Regional Moderator
Darkseid's Avatar
Originally posted by black-knight
People who show up with 50-60 armatures, should learn how to use a comm lathe!
I don't think its neccesary either, but we've all seen the pictures in the magazines. I think the picture I saw(in Car ACtion or RC Car) was of a Reedy TC race before the motor limit was put in. The Orion support guys had a armarature board that had a good 30-40 armaratures on it. I guess that was for all their drivers there.
TLR 22...Tamiya F104...
Old 11-16-2001, 05:09 AM   #392
black-knight's Avatar
R/C Tech Charter Subscriber
Just bumping the Corally thread to the top.
By the way i hae some of the new 6 spoke Serpent/Corally rims, very nice!
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 11-16-2001, 07:17 AM   #393
Regional Moderator
Darkseid's Avatar
Black-knight: which "new" wheels are those? You know where I can catch a picture of them.
Are they light, firm, high quality?
Old 11-16-2001, 03:16 PM   #394
Remember on telast Corally news letter, it mentioned new 6 Spoke rims...
I will take some pics later on today, and i will post them here (in a few hours).
Old 11-16-2001, 03:36 PM   #395
Regional Moderator
Darkseid's Avatar
Oh, okay. Now I remember.
Some pics of them would be great.
Old 11-16-2001, 05:01 PM   #396
can't postpic of my own car ..my digital camera won't work with Win XP.
But... i have got some product pics of the wheels..here they are;
There is one small prob with the wheels.. the corally washers that go behind the wheel screw are a tight fit.
I currently using some of these wheels with trued and glued foam. I've got some yellow 6 spoke rims ready for some rubber tires.
Old 11-17-2001, 01:15 PM   #397
Hi guys,
i am glad to have finally found a decent thread for Corally drivers. I own a C4.1 which I use in our Stock class championship.
We use Corally 21x1 sealed stock motors in our class.
I am very happy with the car, but I just have some small problem.
The car, out of tight right-handers, is kinda slippery. I have tried to adjust the spring length but it still remains the same. Can anyone help? We race on grippy tarmac...asphalt and the track is made up of a long, fast straight, a fast chicane, to fast corners and about 5 to 9 slow hairpins, according to the track configuration.
I also seem to loose most in tight corners (when compared to TC3 or MR4tc). I can't make the car go fast enough in corners. Any help on that also?
Sorry to post this question, which you may find stupid , but which is the best charging current for 3000mA batteries, for best power?
Can anyone suggest some good setup for a track like ours please?
10x to all.
regards from Sunny Malta .... although nearly winter!!
speedmaster is offline   Reply With Quote
Old 11-17-2001, 03:50 PM   #398
Originally posted by speedmaster
Hi guys,
Your car may have some tweak,so you should check the following:
1. Make sure all of you shocks are as equal as possible (very importaint). Double check the springs as well some times two Corally/Serpent springs of the same colour can be slightly different.
2. Check for bent hinge pins
3. Check you droop screw settings
4. Make sure your camber and toe is equal on front and rear
5. Give you car about 2 degrees of rear tow in.
Charging 3000's?
I always charge my 3000's at 4.0amps
Sanyo's @ 4.0amps with 15-20mv cut off
Pano SMH @ 4.0amps with 8mv cut off
Old 11-18-2001, 08:15 AM   #399
Regional Moderator
Darkseid's Avatar
Speedmaster: I would suggest you check your rear hinge pins for straightnes. Even if they look straight on the outside, pull them out and roll them on a glass table to ensure their straight. This was my problem when the car was kind slippery turning one way but not the other.
Second do a tweak check. Just like BK(Black-Knight) told you to. But, to expand on what he said, you should loosen all your top deck screws, press the chassis down firmly on a table, and tighten them back down in an cris-cross pattern. That should take care of any additional tweak that might have worked its way into your chassis.
Old 11-18-2001, 08:19 AM   #400
Regional Moderator
Darkseid's Avatar
BK: those wheels are nice. I think I like the standard C4.1 wheels better though. You know the kit wheels with the 9 spokes(three solid spokes three spit spokes)
The wheel of choice for me is still the Proline Gumby rims though.
Old 11-18-2001, 11:37 PM   #401
When using rubber tires i like to use the Proline Inch-Up Velocity, they fit the corally well..and look good!
Old 11-19-2001, 06:33 AM   #402
Regional Moderator
Darkseid's Avatar
BK: Yeah, thats why I like the Proline Gumby. It fits the car well, and looks great when mounting low profile tires. Also, it gives the proper off set to get me to 190mm, without the need to screw the pivot balls way out.
Old 11-19-2001, 09:18 AM   #403
MikeR's Avatar
Trader Rating: 15 (100%+)
Hey all- How are we?
I'm really starting to appreciate my C.4 after attempting to run a different car this weekend
Practiced and qualified with a substitute car and never really felt good in the corners although the other car was fast on straights. So for the main I decided to switch back to the C.4 since I was qualified last in the Mod a-main. The C.4 didn't fault once and I managed to work through traffic and finished 2nd after starting dead last. I'll be selling the other car soon.
MikeR is offline   Reply With Quote
Old 11-19-2001, 09:33 AM   #404
Trips's Avatar
Trader Rating: 16 (100%+)
Is the Gumby's offset different from any of the other ProLine rims? It's one of my favorite rims too.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 11-19-2001, 09:54 AM   #405
MikeR's Avatar
I used to use Proline rims till Hpi came out with the R-5. Just as light but a whole lot less flex.
Speedmaster- Just like the fellow C.4 runners mentioned check your tweak and hinge pins. Do you know how to check your droop-set tweak with a ride hight guage? Let me know if you don't and i'll explain. As far as your other looseness (car kicking out at mid corner?) in tight corners droop, ride hight, and shock angles and of coarse tires are the main culprits. For the rear increase droop & make sure the chassis isn't bottoming or scraping but also not too high. For the front decrease droop and try moving the front top shock to the outter hole. Try running the car and see how it feels- if it feels close then try moving the back shock tops out or in to hopefully nail the set-up. Also use the basic set-ups that Darkside listed a few pages back.... good luck.
NEW CLUB OPENNED IN SOUTH AUSTRALIA - NORTH EAST MODEL CAR CLUB VintageFrog1 Australian Racing 2226 08-17-2009 04:47 PM
ATTENTION CORALLY RDX OWNERS hotwheels1 R/C Items: For Sale/Trade 2 08-22-2006 08:26 PM
club vs club race at larry's coming soon!!! al jones Racing Forum 5 07-05-2003 12:11 PM
Corally owners octavio Electric On-Road 1 05-15-2003 06:30 AM
Aussie Corally Owners... black-knight Australian Racing 25 03-30-2003 01:19 AM
