Old 11-06-2001, 12:29 PM   #331
MikeR's Avatar
Trader Rating: 15 (100%+)
Oh! i'm just fine and dandy for a dude that wears a cape!
Here's more for my wish list- maybe axles that have a more effecient geometry so that when the knuckes turn the 'bones' don't pivot back and forth? Smaller lighter diff balls? Front droop screws you access from the top? A molded dual plate front foam bumper mount? Heat fins milled into the bulkhead that holds the motor?
The atlas layout is a perfect example exept offset the diffs slightly more so that the battery can be in a few extra millimeters and of coarse a single belt. You can still use dual ball diffs and fly...
MikeR is offline   Reply With Quote
Old 11-06-2001, 12:40 PM   #332
Regional Moderator
Darkseid's Avatar
MikeR: once again I almost agree with all of that. I like large diff balls. Schumacher diffs have proven that large diff balls are the way to go. Theirs is the most reliable diffs around, and the longest lasting.
TLR 22...Tamiya F104...
Old 11-06-2001, 05:59 PM   #333
AE_Racer's Avatar
Send a message via AIM to AE_Racer
I bought Trips's C4.1 and I should have it tomorrow, I finally will own a Corally, YAY!!!!anyway, im curious as to what setup you guys are using on asphalt? I run on asphalt that is smoothed out with tar(permanent track), was just redone and this Friday will be our first race(I think) on the new track, so im gonna run it..I will probably put a basic setup on it with the same springs I run on my schumacher and work from there...Thanks for any help you can give!
AE_Racer is offline   Reply With Quote
Old 11-06-2001, 06:17 PM   #334
Trips's Avatar
Trader Rating: 16 (100%+)
The Corally likes to run fairly soft... I'd keep the springs that are on there to start and see how you like that first.
One thing I have to mention... I used Associated spring perches at the bottom of the rear shocks to get the ride height down. The original Corally spring perches are in the box with the car, I felt that with the longer rear springs the Corally perches were holding the rear of the car too high.
Any questions, please don't hesitate to PM or email me...
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 11-06-2001, 07:09 PM   #335
AE_Racer's Avatar
Ok, I have blue, yellow, and red schumacher springs, at the moment those are the only ones I have..which would be best?
im running yellow on my axis2..im also running the front and mid oneway(tried with diff and couldnt run it.)Thanks
Old 11-07-2001, 12:44 AM   #336
Trips's Avatar
Right now the car has Serpent orange springs up front and white in back. There also four Serpent yellow springs in the box. To my knowledge, the oranges are the lightest, next come the whites, and the yellows are the heaviest.
I'm not sure how Shumacher springs compare, but I think they're alot stiffer than Serpents. I always ran my AGLE version on orange front and white rear, so I went with those on the 4.1. All the setup sheets on Corally's webistes showed ornages up front and whites in back too.
Trips
MARSHAL!!
Old 11-07-2001, 08:24 AM   #337
Regional Moderator
Darkseid's Avatar
AE_Racer: Hold up, hold up! Bad idea! I too run Corally and Schumacher. First off, I don't think the spring fit the serpent shocks that Corally uses. You would have to cut them to do it, and trust me it doesn't turn out too well. Not that I've tried it or anything...(sound of innocent whistling )
Theres another issue as well. Cars like the Schumacher and most other tourers like to be set up with an even set up all around or a stiffer front than rear, but NOT the Corally. It requires a softer front end than rear. Yeah I know it sounds odd after running other tourers, but trust us, thats what it takes.
Forget the schumacher springs and start with the orange up front and white in the rear. I use two holes open on the pistons with 35wt oil. I know this once again sounds odd when compared to using 80-100wt oil in the schumacher, but again, trust us, the car runs well when soft. Heres the full set up of what I run on our asphault.
Darksides setup:
(FRONT)
castor: medium clip in front, large and small behind the upper arm
toe-in: 0 degrees
camber: -1 degrees
Ride height: 4mm
shock tower mount: hole 3
arm shock mount: lower hole
spring: orange
(REAR)
toe-in: 1 degree total (.5 each side)
camber: -1.5
Ride height: 5mm
shock tower mount: hole 5
arm shock mount: only stock arm hole
inner camber mount: hole four
anti squat: .5 degrees
spring: white
Along with this set up I ran the kit tires that came with the car(take offs C27 I think) and always had traction and plenty of steering.
Old 11-07-2001, 09:28 AM   #338
MikeR's Avatar
Yes I agree with the Darkside. Use the kit supplied springs as mentioned! Definitely start with that set-up before trying anything else then you can go from there. You may well be surprised! Only thing I might try that is different from Darkside is leaving less clips on the backside of the front top arm to move castor back. My car has tons of traction so I increased castor to eliminate any on power push and help settle the car down the straights.
Also, since you are in Florida try giving Superior Hobbies a call about set-ups because those guys are hard core Corally drivers.
Old 11-07-2001, 09:45 AM   #339
Regional Moderator
Darkseid's Avatar
MikeR: Thats odd, because my car usually shows no signs of on power push with this set up.
I'll try less clips behind the arm and see what that does.
Old 11-08-2001, 07:52 PM   #340
AE_Racer's Avatar
Darkside - thanks for the setup.I will probably run what is on the car now(orange front, white rear), although I have not checked to see what all the measurements are on it now.
Mike - Superior is almost 4 hours away!
Old 11-09-2001, 07:05 AM   #341
Regional Moderator
Darkseid's Avatar
AE_Racer: be sure to let us know how it goes.
Old 11-09-2001, 08:58 AM   #342
Send a message via ICQ to blue 3:16 Send a message via AIM to blue 3:16
Hi there! Just wondering if anyone is using or had tried to overdrive the C4 using the option 16teeth one-way center pulley? What was the effect like? Thanks
blue 3:16 is offline   Reply With Quote
Old 11-09-2001, 09:34 AM   #343
MikeR's Avatar
I've tried overdrive when I used to drive an FSR car to an ok effect- just made the motor supper hot though so I took it back out.
Old 11-10-2001, 09:16 AM   #344
Regional Moderator
Darkseid's Avatar
Got my 2002 catalog yesterday. Its pretty good. Not as thick as the older catalogs have been, but it had plenty of stuff in there. All with their coresponding part numbers.
Old 11-11-2001, 03:41 PM   #345
King-G's Avatar
Send a message via ICQ to King-G
Hey guys..
just reporting on the weekends Victorian State titles...after what started out a real promising event for me, turned into disaster on day 2..
In qualifying, I slotted in a 3rd fastest run of the meeting in my fourth run, which promoted me from 5th in Mod to 3rd, (behind 2 tc3's)
the mod B qualifyer was then run, and I was confident of keeping my 3rd place, during their last qualifyer, it started to rain lightly, and It was decided that our run would be dropped as we didnt run in the same conditions as the B class....
the next day was the worst conditions I have ever raced under, and would normally have been a wash out, but we persisted, and I found myself on a dry track to begin 2 of the 3 finals, only to have a down pour, and be stuck in the wet on dry slicks!!!..
the 3rd final the conditions improved, and I got a clean run running 3rd place for the entire run, only to dump on the last corner and be passed on the line by 1/10 by my team mate also driving a c4.1...
after the run I was found to be underweight by 7 grams????..which was confusing as I had been 20 grams over all weekend...
I later realised that the corally 12 single, and lighter inserts were to blame, and I lost the last final result, dropping me to a lowly and dissapointing 7th overall..
the car was absolutely dialled...and I now have managed 20 laps on 2 occasions...beating my previous p.b by over 6 seconds!!..
more to come from the car, the setup has great potential.
King-G is offline   Reply With Quote
NEW CLUB OPENNED IN SOUTH AUSTRALIA - NORTH EAST MODEL CAR CLUB VintageFrog1 Australian Racing 2226 08-17-2009 04:47 PM
ATTENTION CORALLY RDX OWNERS hotwheels1 R/C Items: For Sale/Trade 2 08-22-2006 08:26 PM
club vs club race at larry's coming soon!!! al jones Racing Forum 5 07-05-2003 12:11 PM
Corally owners octavio Electric On-Road 1 05-15-2003 06:30 AM
Aussie Corally Owners... black-knight Australian Racing 25 03-30-2003 01:19 AM
